jone8880
dhcp server don`t see option 82
Tue Sep 08, 2009 1:17 am
maybe i do something wrong? in Lease agent circuit ID and agent remote id is empty.
Chupaka
Re: dhcp server don`t see option 82
Tue Sep 08, 2009 1:23 am
indeed, it's not shown in 'DHCP Lease' windows, but you can see it when you show 'Agent * Id' columns in DHCP Server - Leases tab.
won't write to support, but MT Staff, please keep it in mind - non-critical bug =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
jone8880
Wed Sep 09, 2009 12:10 am
'Agent * Id' columns in DHCP Server - Leases tab - was empty too.
Do i need write switch Ip address in DHCP server on Mikrotik?
Chupaka
Wed Sep 09, 2009 12:25 am
I don't see any 'Agent * Id' columns in your screenshot.
I meant the following:
If you don't see any - then there's no Option82 ))
jone8880
Wed Sep 09, 2009 1:14 am
i dont see nothing
but from switch go out option 82// i see it via wireshark
Chupaka
Wed Sep 09, 2009 1:26 am
hm... what version are you using? what switches?
jone8880
Wed Sep 09, 2009 8:20 pm
4.04b
edge-core 3526
Chupaka
Thu Sep 10, 2009 12:37 am
did you try v3.x?
jone8880
Thu Sep 10, 2009 1:44 pm
yes..today.. working on 4.04, on routerboard rb 450
not working on PC-based 4.04
but anyway id is unknow symbol
how to use it for dhcp with option 82? I want to get via dhcp static ip addrss for switchX+portY.
jone8880
Thu Sep 10, 2009 8:28 pm
pc-based working too with some switch tweak
Chupaka
Fri Sep 11, 2009 9:46 pm
what kind of tweak?..
smile__2006
Sun Sep 19, 2010 12:22 pm
Yes) Who can tell something about this task)
I think, must be ability to create rules on MT`dhcp server....
omidkosari
Trainer
Trainer
Sun Sep 19, 2010 1:34 pm
I hope to have this feature in pppoe too :( http://forum.mikrotik.com/viewtopic.php?f=2&t=42698
Chupaka
Mon Sep 20, 2010 1:07 pm
we're using RADIUS for DHCP - works fine for years
Users browsing this forum: 0012nish, asm0922, Google [Bot], msatter, Sinan and 188 guests
