AlexLV
SMP, one task can use only 1 core?
Fri Sep 11, 2009 12:41 pm
I had router on Pentium 4, simple queues+mangle utilize about 90% of CPU;
Than i upgrade it to Core 2, with 2 cores, than traffic is smaller than CPU usage is 30% if traffic is larger CPU usage is 50%, and cant go bigger (queues+mangle cant utilize more than one core?).
If i switch multi-cpu=no than respectively 60% and 100%.
Then i tested on Quad core, CPU usage always 25% (also queues+mangle can utilize only 1 core?).
Version 3.28, but this ploblem was on all 3.x.
So my problem is that i cant search CPU that will hold my load. As working only 1 core, now i plugged Core 2 E8600 3.33 Ghz, now my max load is 45%, but i worry than after few month my load will be greater, and problem comes back.
Chupaka
Re: SMP, one task can use only 1 core?
Fri Sep 11, 2009 11:24 pm
cluster ruleZ =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
hcidc
Sat Sep 12, 2009 8:29 pm
I also ran into this error
I also encountered this error
The network card are more. The mistake is more serious
I can not speak English.
hcidc
Sat Sep 12, 2009 8:34 pm
3.x has this bug
Chupaka
Sun Sep 13, 2009 6:14 pm
actually, it's not a bug. it's a feature =) or feature absence :(
hcidc
Mon Sep 14, 2009 5:38 am
linux has this problem itself ->all linux kernel
Chupaka
Mon Sep 14, 2009 10:04 am
even super-puper-mega-kernel cannot parallelize single thread
AlexLV
Mon Sep 14, 2009 1:31 pm
O.k i understand, second question:
Is mangle, firewall, queues, packet bridging, and passing througt PC from one interface to another, maybe routing too - one thread?
So as i understand second core may be used just for threads like DHCP server or NTP synchronizing? LoL ;)
And what i can do if the fastest Core 2 processor can't shape my 100 Mbps flow with one core?
But i plan to increase the flow at least to 200 Mbps..
janisk
Mon Sep 14, 2009 2:07 pm
it is possible, but it has to be quite optimised setup.
for example - PCQ instead of "1 simple queue per customer" etc.
Chupaka
Mon Sep 14, 2009 2:55 pm
Janis, isn't it planned to make multi-cpu optimization of routing, etc? in v4, for example =)
hcidc
Mon Sep 14, 2009 7:07 pm
When can this question solve? :lol:
600Mbps had problems time out..
CPU use 33%
omega-00
Wed Sep 16, 2009 10:38 pm
Perhaps we can hope for linux integration with 'Grand Central Dispatch' now that it's become open source.
This could solve some problems with multi-core systems and give Mikrotik some new options to look at :-)
Link: http://developers.slashdot.org/story/09 ... h?from=rss
omidkosari
Trainer
Trainer
Fri Feb 19, 2010 11:11 am
There are a lot of ways but the only problem is LAZY programmers :lol:
CUDA Programming
omidkosari
Trainer
Trainer
Tue Mar 02, 2010 10:31 am
Any news in running MUM about this topic ? seems v5 will available in two weeks ?
Users browsing this forum: Bowen73, Google [Bot], inteq, pukkita, Rahl, rezaf28, tomd, vecernik87, w0lt and 83 guests
