ctech4285
routerboard drops packages when latency goes over 1500ms
Thu Sep 17, 2009 11:45 pm
hello,
i got a routerboard, a wireless client, and a gateway. when the gateways latency goes over 1500ms nothing get throw anymore. i can still ping from the the router throw winbox if i set the time out high.
is there a timeout setting i can change somewhere?
churungu
Chupaka
Re: routerboard drops packages when latency goes over 1500ms
Fri Sep 18, 2009 1:01 am
isn't it wireless interface overload?.. why is latency so high?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
ctech4285
Fri Sep 18, 2009 2:01 am
when bandwidth throw that gateway aproaches the limit latency jumps really high
ping router <1ms
ping gateway <1ms
ping everything behind the gateway >1000ms
changeip
Fri Sep 18, 2009 2:15 am
basically you are out of bandwidth correct? Time to buy additional bandwidth or figure out who's hogging the existing (and deprioritize it).
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
ctech4285
Fri Sep 18, 2009 2:30 am
that would be nice but for various reasons this is not doable, my wireless clients are all throttled but i cant control some of the other users that are before the router. ideally i would get everyone to use a electric shock dog caller that translates bandwidth usage to pain.
changing the time out setting in the router os is the best way to deal with it.
changeip
Fri Sep 18, 2009 3:49 am
your ping utility is the app with the timeout. routeros has no timeouts (other than qos buckets), it simply drops a packet if it can't fit down the pipe. if you need appearance of good ping times then prioritize icmp packets so they get first priority. deprioritize traffic that isnt so visible to users, ie smtp.
ctech4285
Tue Sep 22, 2009 10:07 pm
i am providing wifi in matiguas nicaragua this is a pretty poor place and quality of service is not so important, if a client has to wait 5 minutes for page to load thats fine
so i guess changing the qos buckets time out would be the way to go but h
Users browsing this forum: iperezandres, pmurdock, sindy, Znevna and 103 guests
