Mapik
PPPoE - MSS Correction BUG in 3.30
Tue Sep 22, 2009 12:34 pm
We have problems with MT 3.30 and MSS correction on PPPoE...
generated rules seems like this:
38 D chain=forward action=change-mss new-mss=1440 tcp-flags=syn protocol=tcp
in-interface=<pppoe-elektra-elvis> tcp-mss=1441-65535
39 D chain=forward action=change-mss new-mss=1448 tcp-flags=syn protocol=tcp
out-interface=<pppoe-elektra-elvis> tcp-mss=1449-65535
but not doing anything ...
after downgrade to 3.28 everything again OK
macgaiver
Re: PPPoE - MSS Correction BUG in 3.30
Tue Sep 22, 2009 4:39 pm
Are you sure it is not some kind of bugfix? Ehat problems did you had with 3.30?
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
Mapik
Tue Sep 22, 2009 5:56 pm
It seems like rule is not processed .... but counter in mangle is counting packets ... Basicly this works like if we have MSS correction disabled ... so no rewrite in header and users have problems with opening pages from servers using MTU 1500 ....
kabelfrei
Wed Sep 23, 2009 5:02 pm
Can anybody confirm this problem?
thanks and with best regards,
kabelfrei
Muqatil
Trainer
Trainer
Thu Sep 24, 2009 3:56 pm
Any update on this? :o
Renato Bernardi
skype: medtech5
McCJay
Wed Jun 30, 2010 1:10 am
We are expeiencing similar issues with mss correction on rb450g's.
this seems to help, but it's not very elegant:
1. disable auto mss correction on pppoe interfaces
2. add these to /firewall mangle:
chain=prerouting action=mark-routing new-routing-mark=to_pppoe-international passthrough=yes in-interface=LAN connection-mark=pppoe-out1_conn
chain=prerouting action=mark-routing new-routing-mark=to_pppoe-local passthrough=yes in-interface=LAN connection-mark=pppoe-out1_conn
Pada
Wed Jun 30, 2010 2:25 am
I'm not 100% if its due to the same "bug"...
I had to change my PPTP Client interface's max MTU (from the default of 1460 to like 1400) that was connecting to a server via a PPPoE connection in ROS v3.30. I can't remember that I've had to do that when the router was running ROS v4.5. I had the change TCP MSS left on default (enabled) in both versions.
Users browsing this forum: erlinden, Google [Bot], menakaurtbneha and 215 guests
