MUM Europe 2020
olmi
Bonding three channels with different speed
Tue Sep 22, 2009 7:50 pm
Dear gurus of a microtic prompt please in the theory what will be speed if to stick together 3 channels
The first channel of 2 megabits
The second channel of 4 megabits
The third channel of 6 megabits.
I use bonding rr, each channel monitoring arp.
All channels are lifted between two microtics Eoip tunnels.
In practice 6 megabit as at loading of the first channel loading of other channels goes too on no more than two megabit turns out.
kirshteins
Re: Bonding three channels with different speed
Wed Sep 23, 2009 8:18 am
Yes, this is how balancerr works. Same number of packets are sent out through each slave interface. So maximum speed is the slowest slave multiplied by the number of slaves.
olmi
Wed Sep 23, 2009 12:10 pm
How then to me to stick together 3 channels in one big?
Ibersystems
Wed Sep 23, 2009 12:22 pm
I think you can use PCC or NTH to redistribute packets in the 3 lines. The max speed will be 2 or 4 or 6, depending on the line used by this connection, but not 12 Mbps.
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
olmi
Wed Sep 23, 2009 2:29 pm
Multi GW? It works not so well, rupture of sessions icq, games etc.
Chupaka
Wed Sep 23, 2009 8:32 pm
not ECMP, but PCC
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
businesstg
Thu Sep 24, 2009 1:52 am
Check out www.sharedband.com ... somehow they are able to do this using from what I understand using VRRP. It works pretty decently too and bonds disimilar link speeds to get the aggregate connection speed. They however push their own bandwidth across the link. Their bandwidth is peered across several providers. So for instance you have comcast at 20/5 and Qwest DSL at 7/1 your speed would be aggregate about 26/5.5 (some cost in overhead) Don't really know how they do it? Works decently though, little extra latency is introduced.
Chupaka
Thu Sep 24, 2009 10:02 am
looking at their website, I think it's one more VPN solution + bonding (packet load balancing or something)
olmi
Fri Sep 25, 2009 1:06 pm
And if I make the following:
Through the channel of 2 megabits to lay 1 Eoip the tunnel
Through the channel of 4 megabits to lay 2 Eoip the tunnel
Through the channel of 6 megabit to lay 3 Eoip the tunnel
And all to connect in Bonding
I will receive 2+4+6?
Chupaka
Fri Sep 25, 2009 9:46 pm
omg! crazy idea, but seems like it should work!
please check and post here you result - it's very interesting solution =)
Users browsing this forum: antonme, MSN [Bot] and 81 guests
