HaQs
New Feature request: NSTREME- enabled, disabled, required
Thu Sep 24, 2009 12:16 pm
On ROS 2.x 3.x and 4.x rc NSTREME option is only enabled or disabled
But nice option is: ON CPE NSTREME enabled but on AP disabling NSTREME when is not requred.
Actual When NSTREME is enabled on CPE and disabled on AP then CPE disconnect :/
The good option is enabling or disabling NSTREME on CPE from AP
normis
Re: New Feature request: NSTREME- enabled, disabled, required
Thu Sep 24, 2009 12:31 pm
what will happen if each CPE has a different setting?
dada
Wed Oct 07, 2009 5:47 pm
1) I would change the keyword name from required to desired
2) if CPEs are not set correctly (all have to be in 'nstreme desired' mode, of course) it is a configuration bug. If Ap is in nstreme mode all CPEs with nstreme desired or enabled will connect. Rest will not.
3) I have tested a short script which is able to switch nstreme on/off if there is no connection to AP for some time. It worked fine - only the delay was longer.
Equis
Forum Veteran
Forum Veteran
Fri Oct 09, 2009 11:42 pm
This is a great idea!
NetworkPro
Sat Oct 17, 2009 8:45 pm
This idea is so good, I wonder how come MikroTik haven't put it into RouterOS in version 2.7 back in the day, how come they didn't think of it? :)
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
Users browsing this forum: amirakbarizadeh, Google [Bot], Gosman, jebz, Kindis, marisspringis, sindy and 86 guests
