HaQs
Clock Bug in ROS 4.0 rc1 on x86
Sun Sep 27, 2009 10:46 pm
In Ros 4.0 r1 clock is 10x faster :/ On x86
1 Real secound = 10 MT sec :/
hardware motherboard: FSiemens D1219 cpu intel P3 933
changeip
Re: Clock Bug in ROS 4.0 rc1 on x86
Mon Sep 28, 2009 1:44 am
I am using 4.0rc1 on a x86 p3 1000. Clock is okay on mine. Should probably submit a supout to support and give them more information.
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
uldis
Mon Sep 28, 2009 3:42 pm
it is because you are using nstreme. there is nothing what we could do about it as it is the hardware or BIOS problem that the PIT timer isn't working orrectly. Try to update the motherboard bios and check the bios configuration, maybe some setting will help you.
HaQs
Thu Oct 01, 2009 10:11 pm
OK, I tested this ROS version on other FS D1219 motherboard with this some BIOS version and CPU. And Clock are OK.
But why on this motherboard CLOCK is ok on ROS 2 ????
NetworkPro
Tue Oct 06, 2009 8:28 pm
Because older RouterOS uses different software clock. Replace the motherboard and move on.
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
dada
Wed Oct 07, 2009 3:53 pm
I have faced similar problems when installing 3.28 with wireless-beta on a link made on two older intel mainboards using nstreme. System time on the boxes was fast and link was unstable. After I installed regular wireless package the problem disappeared.
Is it the same issue?
Users browsing this forum: anav, Google [Bot], grusu, june8807, sid5632, tomaskir, Zacharias and 63 guests
