triac
PPtP Client timeout...
Mon Sep 28, 2009 1:35 pm
I want know if it's possible to set PPtP Client connection timeout.
In other words, I have a CPE with two PPtP configured, the PPtP server have two DSL connections, the first for abitual work and the second for backup. All work fine but when the first DSL goes down the CPE start second PPtP after about 90 secs because first PPtP connection goes down after 90 secs in CPE... It's possible to modify this time? 90 secs are too long...
I hope You understand.. my english isn't good :(
tnx
Paolo
Paolo Torri
Chupaka
Re: PPtP Client timeout...
Mon Sep 28, 2009 6:52 pm
maybe just set 'Check gateway' on your routes?..
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
triac
Tue Sep 29, 2009 12:40 am
hi chupaka, tnx for reply.
The check GW in PPtP server (the only with two GW) is enabled, when first GW goes down the second start and the PPtP1 connection are killed immediately... on the server, but in the client the PPtP1 link remain up for about 90 secs... when it goes down the second PPtP link can goes up....
Paolo Torri
Chupaka
Tue Sep 29, 2009 11:23 am
can we have a drawing? I'm not sure I understand what is PPtP and what is PPtP1...
Users browsing this forum: No registered users and 120 guests
