normis
"no-mark" as default mark to all connections and traffic
Mon Sep 28, 2009 1:39 pm
In next RouterOS we will include small, but important change in firewall mangle. Every connection will have connection mark "no-mark" by default, and every packet will have packet mark "no-mark" by default.
This changes will greatly help to reduce complexity and efficiency of the mangle setups that require remarking of the connections and traffic. Traffic remarking will be avoidable.
For example with one rule it will be possible to ensure that this rule will mark only connections that was not marked before (connections with "no-mark" mark).
It will also allow to create queue for unmarked traffic, this way eliminating requirement that all traffic need to be marked in mangle to create proper QoS.
Chupaka
Re: "no-mark" as default mark to all connections and traffic
Mon Sep 28, 2009 1:59 pm
is this like adding hidden rules
/ip fi mangle add chain=prerouting connection-state=new action=mark-connection new-connection-mark=no-mark
/ip fi mangle add chain=prerouting action=mark-packet new-packet-mark=no-mark
can it help to reduce complexity in current version? :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
macgaiver
Mon Sep 28, 2009 2:48 pm
To Chupaka: it looks like only in your case you will need to reboot the router/conntrack to force all connections become new :)
One way or another it will help to get rid of at least 2 rules (more in more complex setups)
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
Chupaka
Mon Sep 28, 2009 3:20 pm
are you sure you don't need to reboot a router to upgrade it to the next version? ;)
omidkosari
Trainer
Trainer
Tue Sep 29, 2009 10:49 pm
Should we care before upgrade to next version ? will our configuration affected or it does everything automatically ?
macgaiver
Wed Sep 30, 2009 9:27 am
As far as I can see it it does nothing to your configuration, you can ether use it or not.
janisk
Wed Sep 30, 2009 9:40 am
if you are using mangle and marking connections the way you do that - it will not bring you any difference. because initial marks are without checking any mark, because of presumption that there are none, then, even if you set something, it will be overwritten.
Chupaka
Wed Sep 30, 2009 9:59 am
the things to be a bit more clear: now you are able to match connections and packets without marks in a native way. earlier you had to mark it with some temp mark to do that trick
changeip
Wed Sep 30, 2009 7:17 pm
it would be NICE to have an option to bypass this hidden process. I can imagine there are cases where you do not want this. What about performance, if I'm not even using packet marks at all are they now incurring additional CPU usage on the hidden marking process? Additional RAM usage?
PLEASE just have a checkbox / boolean flag on the mangle setup that allows you to turn it on and off. If you dont add it now, then you will just have confused a ton of people when you automatically start doing this, and in future versions I imagine it will be added and now more people will be confused. Make it an option, not a requirement.
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
Chupaka
Wed Sep 30, 2009 8:19 pm
I really HOPE that this is just firewall MATCHER improvement, not full redesign of whole conntrack system. if that's true - then no performance impact at all
janisk
Thu Oct 01, 2009 9:48 am
previously if packet had no mark, returned value was nil, value you could not match against, now, in same case if you want to macth, you can do that, because returned value is no-mark. So, if you look at it in that way - all packets are considered marked now, no value set is a actually value set.
Chupaka
Thu Oct 01, 2009 10:56 am
as I said, and as it should be :)
good work =)
changeip
Thu Oct 01, 2009 6:51 pm
connection-marks and packet-marks take up memory correct? I could be understand this wrong, but I just want to make sure that our really heavy loaded routers that we do not use any mangling aren't going to take a performance hit for marking and storing the value in memory.
This new change does not affect CPU or memory usage at all?
Chupaka
Thu Oct 01, 2009 6:57 pm
yes, no affect at all. just a bit changed logic
normis
Fri Oct 02, 2009 9:31 am
it's not really a mark. it's just a name for unmarked connections to make matching them easier.
Ozelo
Fri Oct 02, 2009 1:52 pm
Guess it is just a masked info. (nil = no-mark) As you may not be able to leave those fields in blank to have a match. This is great. Whenever you had a "blank" info, now ROS will show you that "nil = no-mark" without any variable attributions. Thanks!
MTCRE - 1104RE006
MTCINE - 1104INE001
celicas
Thu May 28, 2015 8:43 am
Very useful and it significantly reduces complexity :) . I just came across the need for a default routing-mark=no-mark as well which is not implemented as of now (v6.28) :(
pukkita
Trainer
Trainer
Thu May 28, 2015 2:31 pm
Wouldn't routing-mark=main be useable in your setup?
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
celicas
Thu May 28, 2015 4:10 pm
Yes you are right! This is equivalent to "no-mark" of connection & packet marks!
I can't hide that this is my first complex setup!
Thank you!
tomaskir
Trainer
Trainer
Thu May 28, 2015 4:25 pm
This post is from 2009.
This is already working as described in 6.28.
@MirkoTik - Please lock this topic.
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
Users browsing this forum: Ahrefs [Bot], Bing [Bot], cvalavik, Google Feedfetcher, Panbambaryla, sunakashi and 40 guests
