MUM Europe 2020
sjwrick
Total bytes not accumulating in queue | scheduler not proces
Sat Oct 10, 2009 4:30 am
Upgraded to ROS 3.30 from 3.10(???) x86
In '/queue simple' when I set max-limit to unlimited/unlimited no tracking or accumulation of bytes occurs. At all in any stat.
I set the max-limit to something huge like 50M/50M and accumulation works EXCEPT in the 'Total Bytes'. Graphing has no data - flatlining. Yet I see traffic in the Total RX Bytes and the Total TX Bytes.
All this and customers are happily surfing away.
Also, scheduler does not execute script. Set it up - set the time - time passes - script makes note that it ran but actually does not as there is no result
Scripts created in '/system scripts' do work.
All this worked in ROS 3.10
Any way to reinstall the OS or what to do?
Chupaka
Re: Total bytes not accumulating in queue | scheduler not proces
Mon Oct 12, 2009 10:51 am
if you do not change anything ('unlimited' bandwidth and 'default-small' type), queue is not actually installed. you may change queue type to 'default', for example
as for scheduler - check needed Policies for that schedule
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Users browsing this forum: lamclennan, RONL and 123 guests
