alexspils
RouterOS v4 released
Tue Oct 13, 2009 12:06 pm
What's new in 4.0:
*) IT87XX hardware monitoring sensor support;
*) kvm allows to choose emulated nic model;
*) hotspot - fixed redirect after login in case if client gets new IP address
(problem introduced in 3.28);
*) hotspot - fixed redirect after login in case if client gets new IP address;
*) console - commands like 'monitor', 'torch' and others that periodically
refresh information sometimes failed to work when started from
the scheduler;
*) console - scheduled scripts no longer require 'test' policy to run;
*) console - fix issues with scripts that contain lines with trailing spaces;
*) console - add back compatibility with old scripts that use space instead
of '=' to separate argument name and value;
*) console - following fixes:
- accept item numbers when prompted by command to specify item;
- argument names without '=' were matched even when expecting unnamed
value; this broke code such as:
:foreach i in=1,2,3 do {}
here 'i' was matched as argument name "in";
- 'tab' key did not automatically append '=' after complete argument
names;
any success upgrade story are welcome :)
macgaiver
Re: RouterOS v4 released
Tue Oct 13, 2009 2:17 pm
Upgraded, no problems!
Just keep in mind to log into the router after and update your license from XXXX-XXX to the new XXXX-XXXX style. Or else your license will expire in 72hours
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
Chupaka
Tue Oct 13, 2009 3:03 pm
RouterOS 4.0, released 13-OCT-2009
wow! at least they write release date )))
2.9.51 R.I.P. :(
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Eising
Tue Oct 13, 2009 3:16 pm
Netinstall seems to crash for me. I can upgrade with no problems though.
The road to hell is paved with good intentions.
uldis
Tue Oct 13, 2009 3:22 pm
please provide more detailed info how does it crash.
xezen
Long time Member
Long time Member
Tue Oct 13, 2009 3:31 pm
i found a problem with v4
and that is that there is no data in the change log
:lol:
http://www.mikrotik.com/download/CHANGELOG_4
tanks team
If i dont No Ask someone That Does!
Eising
Tue Oct 13, 2009 3:38 pm
When I launch netinstall from my router (an RB450), it finds the machine that runs netinstall, and the error I have attached appears ("recvfom failed: An existing connection was forcibly closed by the remote host. (10054)"). When clicking Ok netinstall closes. The router seems not to notice and tries to fetch the image, yet nothing happens. Even if I start up netinstall again, the router will never get to the point where it installs.
Eising
Tue Oct 13, 2009 3:42 pm
Hmm, disregard my error for now. I think it's my own network.
normis
Tue Oct 13, 2009 3:44 pm
:lol:
tanks team
works for me
xezen
Long time Member
Long time Member
Tue Oct 13, 2009 3:47 pm
the link works but data not updated
it is the last data i have
What's new in 4.0rc1:
*) incorporated all the bugfixes since v3.30;
*) port remote-access - added 'log-file' property. If value is a non-empty
string, then all data that is read from the port is appended to a file
with that name, regardless of the active remote connection;
*) console - removed '/user' from the output of top level '/export' command,
still can be exported by '/user export';
should look somthing like this if im correct
What's new in 4.0:
the scheduler;
names;
xezen
Long time Member
Long time Member
Tue Oct 13, 2009 4:08 pm
What's new in 4.0:
temp cant be (v) must be (degree c)
and fan speeds cant be (v) must be (rpms)
but it seems to be right values
works well i think
NAB
Trainer
Trainer
Tue Oct 13, 2009 4:44 pm
I'll go one better.....
Wow, magic!!
xezen
Long time Member
Long time Member
Tue Oct 13, 2009 5:03 pm
what motherboard you got?
as here all is right on teminal but not winboxx try it out and see
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
xezen
Long time Member
Long time Member
Tue Oct 13, 2009 5:06 pm
i found that 4 seems to run better as in the past winbox cpu use to run 10-14%
but now 1-3%
thants reel cool im going to test this on a rb133c routerboard to see what it does as 2.9.51 is so outdated but runs the best on that board
omega-00
Tue Oct 13, 2009 5:08 pm
Any more details on what this is about? :-?
Edit: http://wiki.mikrotik.com/wiki/Virtualization - KVM virtualisation.
Chupaka
Tue Oct 13, 2009 8:05 pm
haha, flush your proxy cache =)
rmichael
Forum Veteran
Forum Veteran
level4 lic
Tue Oct 13, 2009 8:12 pm
Just to confirm - buying any board with level4 - after Oct-13 2009 - entitles one to free upgrade to ROS V5 correct?
thanks.
roc-noc.com
Forum Veteran
Forum Veteran
Re: level4 lic
Tue Oct 13, 2009 10:05 pm
thanks.
And if so, how do you handle upgrades on distributor inventory? :|
I would like to suggest that all Mikrotik RouterBoards which are not EOL, are moved up to the new license levels. (all RB/CRD, RB4xx, RB6xx, RB750 and RB1000.) That would solve my inventory issue. You can leave RB/CRD out if necessary because that is using the older RB1xx series MIPS processor.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
hilton
Long time Member
Long time Member
Wed Oct 14, 2009 7:45 am
Upgrade to 4.0 on x86 cleaned out all the gateway/gateway interfaces in my routes.
So the routes are still there but they reference nothing, so nuffin is working.......
Eish.
Nb, my own server so not a client's but still worth knowing about.
Regards
Hilton
uldis
Wed Oct 14, 2009 12:22 pm
Eish.
please make the support output file and send it to support.
normis
Re: level4 lic
Wed Oct 14, 2009 2:47 pm
thanks.
Tom
ALL RouterOS installations with legitimate RouterOS Keys can now upgrade to v4
sergejs
Wed Oct 14, 2009 3:13 pm
xezen, the problem will be fixed in the next RouterOS version with volts.
rmichael
Forum Veteran
Forum Veteran
Re: level4 lic
Wed Oct 14, 2009 9:07 pm
thanks.
Tom
The question however is: how are you going to determine eligibility for free ROS V5 upgrade for hardware with level 4 lic purchased since current version of ROS is V4. (and perhaps, if it matters hardware still comes with v3 preinstalled)
hci
Long time Member
Long time Member
Thu Oct 15, 2009 12:17 am
Is OS version 4.x more CPU intensive then 3.x? On a heavy loaded PPPoE server we have seen an increase in CPU load but we changed out hardware at same time so not sure.
M
Chupaka
Thu Oct 15, 2009 2:23 am
others say that v4 is less cpu intensive than v3 =)
Myron
Thu Oct 15, 2009 3:09 am
i notice this V4 less of CPU process!! cool.. that's why i love mikrotik :lol:
rodneal
Thu Oct 15, 2009 4:12 am
v4 ROCKS!@!!
I love MT!!
V4rc was a little shaky but v4 fixed it - yeeehhhaaaahhhh!
Now what about the bios 2.23 I've heard rumors about?? and how far back will this upgrade go?? RB112 series??
Thank you - Normis!
Rod
hilton
Long time Member
Long time Member
Thu Oct 15, 2009 7:18 am
Eish.
Just an update. I removed and added back the routes and yet the gateway interface option just seems to disappear with time.
I can't tell you when it vanishes but it does. I will send support a supout but for now it's back to 3.30 as 4.0 is completely unusable.
Regards
Hilton
Chupaka
Thu Oct 15, 2009 7:16 pm
btw, Netinstall of v4 still contains 'MIKROTIK ROUTEROS V3 SOFTWARE ROUTER SYSTEM' license
isn't it time to remove version from the license? when v3 was released, there was license about v2 in it ))
rpress
Thu Oct 15, 2009 7:49 pm
I was excited to see the temperature monitoring, and it does work correctly in the terminal.
However I can't bring up the numbers in SNMP, they just show as zero. Is there another OID to use? I want to add a notification with The Dude for an overtemperature alarm.
normis
Fri Oct 16, 2009 8:41 am
we'll look into this. edit: apparently what you got over SNMP is temperature values for RB230 (old product), SNMP support for PC is not yet made, there are some difficulties with it.
hilton
Long time Member
Long time Member
Fri Oct 16, 2009 9:46 am
Support has confirmed that this is a bug in winbox and will be fixed in 4.1
I think it only applies to x86.
Regards
Hilton
Chupaka
Fri Oct 16, 2009 1:59 pm
in Winbox? so, all is working, you just cannot see it in Winbox?
rodneal
Fri Oct 16, 2009 3:43 pm
When do we expect v4.1?? Mon or Tuesday?
Rod
hilton
Long time Member
Long time Member
Fri Oct 16, 2009 6:10 pm
Yes that is my experience. Had me fooled for some time, I've learnt to trust winbox over the years and never thought to check via ssh or terminal.
Regards
Hilton
hilton
Long time Member
Long time Member
Fri Oct 16, 2009 6:12 pm
Rod
How about now. Go check out the download page.
Regards
Hilton
rodneal
Fri Oct 16, 2009 9:43 pm
Ok - from rock-an-roll to singin the blues.
I just instructed our engineers to roll back v4.1- to v3.30
We've been noticing a ripple across the network and figured v4.1 would fix it - no go.
It would drop 1 on the primaries and 2 on the next tower and 3-10 on the towers and cpes after that.
This started 2weeks ago with the update of v4rc - v4 helped some it seemed and v4.1 didn't make a difference.
Of course the network slowed to a crawl - and of course the complaints have rolled in.
Here's hoping v3.30 takes us back.
Rod
xezen
Long time Member
Long time Member
Fri Oct 16, 2009 10:32 pm
thanks for the changes in 4.1 but still testing it as i just loaded it up today will let you know if i pic up any problems
but thanks for the update but at this rate of updating versions we will have to go to 4.100 before we move over to 5
as we cant upgrade ever 48 hours? :lol: :lol: :lol: :lol:
thansk anyway team
CarulloS
Sat Oct 17, 2009 12:19 am
Can you clarify... I have some 2.9.50 installs I tried to upgrade to v4 and I can't because it tells me so when I try in the log.
Thanks,
Scott
Users browsing this forum: george72, Google [Bot] and 51 guests
