jfunk
OpenVPN ethernet bridge requires an IP? Why?
Thu Oct 15, 2009 9:53 pm
I'm trying to set up an OpenVPN client on a Miktrotik to connect to a Linux server. It seems that every aspect of a normal configuration is somehow wrong in the eyes of the Mikrotik. UDP is wrong, client certs are wrong, shared passwords are good, compression is bad.
So I'm playing along, I changed the server to tcp, I wrote a password authentication system, I disabled LZO.
Now the Mikrotik is connecting, but it immediately disconnects:
terminating... - no ip address provided
I'm using mode=ethernet, with the intention of adding the interface to a bridge. Why would an IP be required? That makes no sense. It's layer 2.
Is there a way around this?
XTLMeth
Re: OpenVPN ethernet bridge requires an IP? Why?
Fri Oct 16, 2009 6:15 am
I have nothing against mikrotik but I would advise you stay away from teh openvpn server. I have it deployed with 10 users and I have to reboot the routerboard every 28 days or so because openvpn just stops working. I have seen this a couple of times with other deployments as well so I know it's not an isolated indecent.
Users browsing this forum: aeichhorn, almdandi, Lifz and 64 guests
