omidh
Max PPPoE Session
Tue Oct 27, 2009 4:06 pm
Hi
how many pppoe sessions Mikrotik can support suppose that we use mikrotik as pppoe server?
i want to know about its dependencies for example on rb 1000 or just router board software on ordinary PC with 3 GHZ CPU and 2 GB of RAM.
gmsmstr
Trainer
Trainer
Re: Max PPPoE Session
Tue Oct 27, 2009 4:31 pm
We have PowerRouter 732s running 3000+ PPPoE Sessions, and 2282s with over 9k..
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
omidh
Tue Oct 27, 2009 6:07 pm
are these router OS same as rb's? i mean configurable via winbox and command syntax are the same?
and how about router board software installed on ordinary PC?
thanks a lot.
gmsmstr
Trainer
Trainer
Tue Oct 27, 2009 6:10 pm
They run RouterOS without issues! http://www.mikrotikrouter.com. I have also done quite a few, around 800 on a RB1000... Its also important to note that standard PC hardware is sometimes not the same, as you have changes in drivers, PCI Buss limitations, etc. So, hard to say.
Users browsing this forum: dcalanchini, EnAbb, Google [Bot] and 177 guests
