kameelperdza
Have a damaged my RB??
Fri Oct 30, 2009 7:44 pm
i almost broke my rb433 and it felt like if i can cry becoz of the dissapointment.
But luckily it did not.
What went wrong is i replace the r45 plug on the poe side. The plug keep sliding out so i decided to replace it.
Im running a straight cable from the poe device to my rb433. The setup is like this......light orange,orange,light green,blue,light blue,green,light brown,brown.
I accidently swop the green with the blue wires and could not understand why the rb wont poweron.
I did fix the connector and the device stil wont go on, but after awhile it went back on.
Could this have damaged my routerboard? I dont hope so.
On the poe device it shows the following....
1 = data
2 = data
3 = data
4 = + Volt
5 = + Volt
6 = data
7 = ground
8 = ground
I accidently raplaced 3 with 4 and 5 with 6.
The rb is working fine again. Please dont tell me that i have damaged the rb. But please tell me if i did.
Give me some karma
GuJack20
Trainer
Trainer
Re: Have a damaged my RB??
Sat Oct 31, 2009 9:29 pm
You sent voltage to the data part of the chip. The only way you can be sure that the RB isn't damaged is to run a bandwidth test from a PC to the RB. If everything works fine (i.e both ways, no packets dropping etc etc) than the RB isn't damaged.
I have never experimented changing the pins so i can't give you a straight answer, sorry :(
--Do you remember that guy who gave up? Neither does anybody else!
Chupaka
Sun Nov 01, 2009 2:06 pm
thanks god you haven't swap 6 and 7 %)
and yes - do simple testing to see whether it's working or not
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Users browsing this forum: Google [Bot] and 88 guests
