Syonyk
Is there a way to port forward Winbox to another MT?
Thu Jun 30, 2005 1:30 am
Trying to figure this one out, or if it's even possible.
I have a Mikrotik with a public IP address. It runs NAT, and behind it there's another Mikrotik. Is there a way to forward Winbox through the Mikrotik so I can use Winbox on both routers? If I forward port 8129 (?) I can't access the first one. Is there a way to change the authorization port used to connect Winbox?
I only have one public IP, and the network layout can't be changed.
-=Russ=-
changeip
Thu Jun 30, 2005 2:17 am
Don't think so . . . i think the only option is to setup a vpn to the mt and then use the inside ip to connect.
Sam
Users browsing this forum: No registered users and 82 guests
