KennyB
Long Distance Links
Sun Jul 03, 2005 1:03 am
Hello all,
I have a question about the rb532 and the sr5 400mw wireless card. Anyone using it?
Here is the scenario. I have a project to do a highbandwidth link. Actually 3 links. 2 are 11 miles long and one is 23 miles long. I know I can do the 23 mile with no problem as I am currently doing one with 16mb thruput non nstream. I would like to make this new one nstream and try and get 20-40mb. These are 5.8mb radios currently. So my questions are has anyone used the new 532 boards and the sr5 to get the boosted speed? And does anyone have any experience with true nstream with 2 antennas (one rec, one xmit) in real world that can say that it actually does increase bandwidth?
I know the 523 is new, but does anyone have any feedback on their reliability?
thanks for any help and info
Kenny
Kenny
stephenpatrick
Forum Veteran
Forum Veteran
Sun Jul 03, 2005 5:35 pm
Hi Kenny,
For that sort of distance you need Nstreme or Nstreme2.
Nstreme is CPU-intensive (though MT say they have a new version in the works) so don't try this on a slow CPU platform.
I haven't tried the new RB500 series, which is supposed to be faster than the older low-power platforms but even so, I think that might be pushing things.
Personally, I'd go for a 600MHz to 1GHz CPU platform, 5Ghz band with Turbo channel bonding (if you need the throughput, as you say you do), Nstreme for starters.
I'd suggest get it all working with Nstreme before trying Nstreme2 unless you are supremely confident ... at least that proves the single RF path, antennas, LOS, RF environment etc.
Regards
CableFree - Wireless Excellence - Microwave, E-band Radios, Free Space Optics, High performance Radios & Routers
http://www.cablefree.net
variable
Sun Jul 03, 2005 10:32 pm
i am using the rb532 and wds briding with the sr5 on ros2.9rc5. been running at 23mb UDP HDX for 2 weeks stably
stephenpatrick
Forum Veteran
Forum Veteran
Mon Jul 04, 2005 1:28 am
Very interesting!
What's the CPU usage doing that?
Assume you are using Nstreme, yes?
Any encryption set?
Regards
marksx
Tue Jul 05, 2005 5:54 pm
we have reached up to 60Mbps on overclocked 333MHz RB532, 42Mbps on normal 266MHz, so this is NOT ENOUGH for nstreme dual, I'm waiting for new RouterBoard 3xx series with ~1GHz CPU, that would be enough :-)
tully
Tue Jul 05, 2005 6:05 pm
As I have written before, we are working on a new wireless package that will enable Nstreme to go faster on low power platforms. Should be ready for you to test in a week or so. Possibly 20-40% faster.
John
uldis
Wed Jul 13, 2005 5:41 pm
New wireless package is ready to download:
Regular (i386) http://www.mikrotik.com/download/wireless-2.9rc7.npk
RB500 (mips) http://www.mikrotik.com/download/wireless-2.9rc7-ns.npk
What's new:
* Improved wireless in general.
* Increased nstreme performance - use less CPU resources.
We will also put a document with performance results of this package compared to older package.
We have archieved 80Mbps throughput of UDP traffic (bandwitdh test) in one direction.
Setup: Nstreme DUAL (framer-policy=exact-size) link using 5ghz-turbo, distance 3km
On one side 1.7Ghz Celeron, on the other side RB500 running at 333Mhz.
tneumann
Wed Jul 13, 2005 7:49 pm
Is this the wireless package that is included in the routeros-2.9rc7 download, or is it different and must be installed separately even if the router is already running routeros-2.9rc7 ?
--Tom
uldis
Thu Jul 14, 2005 10:17 am
--Tom
This package isn't included in the regular RouterOS v2.9rc7. If you have installed the v2.9rc7 with regular wireless package then you should upload this test package to the routers FTP and reboot it - do 'system reboot'
Users browsing this forum: Bing [Bot], FANTASMA1721, hapoo, MSN [Bot] and 44 guests
