Brad
PPP profiles / Rate limiting
Wed Jul 06, 2005 6:33 am
In 2.8, I was able to set TX and RX rate limits per profile but in 2.9, that does not appear to be an option. Does this mean I will have to do my rate limiting on each individual user instead of just applying a "512k/256k profile" which already had the rate limits in it to the users?
hitek146
Wed Jul 06, 2005 7:29 am
You should use the rate-limit parameter in version 2.9. In Winbox, this is found in the "Limits" tab of the profile. I haven't gotten it to work correctly, though, as it seems to apply the first rate that I specify to both TX and RX, even if I specify both of them....
Brad
Thu Jul 07, 2005 7:51 pm
Can anyone from MT confirm the use of this feature?
hitek146
Thu Jul 07, 2005 9:21 pm
It's now working properly. In fact, it was working properly before, the effects were just not apparent when using the built-in bandwidth test....
Can you not find the "Limits" tab of a profile in Winbox? Or can you not see "rate-limit" as an option when you type "ppp profile add ?", or do you find it, but are not able to get it to work properly?
[admin@MikroTik] ppp profile> add
creates new item with specified property values.
name -- Profile name
local-address -- Assigns an individual address to the PPP-server
remote-address -- Assigns an idividual address to the PPP
session-timeout -- The maximum time the connection can stay up
idle-timeout -- The time limit when the link will be terminated if there is no a
ctivity
use-compression -- Defines whether compress traffic or not
use-vj-compression -- Use Van Jacobson header compression
use-encryption -- Defines whether encrypt traffic or not
only-one -- Allow only one connection at a time
change-tcp-mss -- Change or not TCP protocol's Maximum Segment Size
rate-limit -- Data rate limitations for the client
incoming-filter -- Firewall chain name for incoming packets
outgoing-filter -- Firewall chain name for outgoing packets
dns-server -- DNS server address
wins-server -- Windows Internet Naming Service server
copy-from -- item number
comment -- short description of the item
Hitek
Brad
Thu Jul 07, 2005 9:45 pm
I see what you are talking about.. in 2.8, there was a TX bit rate setting and a seperate RX bit rate setting, you are saying to just combine both of those into the Rate Limit by doing 512000/256000?
It seems like it was much more explanatory in 2.8 as it actually says RX bitrate in bit/s. Now it just says "Data rate limitations for the client". So is this bit/s?
2.8 PPP profile options:
idle-timeout -- The time limit when the link will be terminated if there is no activity
copy-from -- Item number
comment -- Set comment for items
require-encryption -- Defines whether require encryption from the client or simply prefer it
rx-bit-rate -- Receive birate in bit/s
tx-bit-rate -- Transmit birate in bit/s
2.9 PPP profile options:
activity
hitek146
Thu Jul 07, 2005 10:46 pm
Yes, that is correct. Also, if you would be using RADIUS, you are supposed to be able to use "Rate-limit" to specify both data-rates as one parameter, or "Ascend-data-rate" and "Ascend-xmit-rate" to separately specify the receive and transmit data rates, old style... Many people(myself included) have not been able to get the "Rate-limit" parameter to work when using RADIUS, so we are using the Ascend set of parameters....
This may be of some help:
http://www.mikrotik.com/docs/ros/2.8/gu ... nt#13.4.16
Hitek
Users browsing this forum: Bing [Bot] and 110 guests
