Gennadiy51
RB450G + ROS v4.3 work not correct.
Tue Dec 08, 2009 11:12 am
My RB450G + ROS v3.30 work very good. When I installing total packages v4.3 do not work all ethernet ports. If I disabled ipv6-4.3.npk, all ethernet ports begin to work, bat if I change names or MAK-ADDRESes of ethernet ports and reboot router, first port not storred changes.
X86 (Intel 566 MHz Slot1), RB450G, RB493G, hAP ac lite, hAP ac^2, hAP ac, wAP ac.
sergejs
Re: RB450G + ROS v4.3 work not correct.
Tue Dec 08, 2009 3:36 pm
The problems will be fixed in the next RouterOS version (4.4).
Gennadiy51
Thu Dec 24, 2009 11:44 pm
I have downloaded and installed the 4.4 version of RouterOS. The problem is fixed indeed. Thank you.
Users browsing this forum: Bing [Bot], sindy, ysha and 91 guests
