MUM Europe 2020
astounding
VLANs: Tagged and untagged frames inbound on eth interface
Wed Dec 09, 2009 8:22 pm
In 4.x does anyone yet know if mixed tagged and untagged inbound traffic on a single ethernet interface can be easily split/separated yet?
I'm still hoping for the day I can create a bunch of VLAN interfaces atop that single eth. interface to capture tagged traffic AND simultaneously apply a bridge directly to the ethernet and have it ONLY capture untagged traffic. Or perhaps have a VLAN work-around whereby a special VLAN interface (maybe use vlan-id=0 perhaps?) can be created that captures untagged traffic on an eth. port.
In 3.x (and I suspect it's still true in 4.x), inbound mixed tagged/untagged traffic will ALL be captured by the bridge applied to the eth. interface, and the VLAN interfaces will see nothing. And if I recall correctly, attempting to layer VLAN interfaces atop a bridge didn't work either.
Goal:
[admin@mikrotik] > /interface vlan print
Flags: X - disabled, R - running, S - slave
 #    NAME                  MTU   ARP        VLAN-ID INTERFACE
 0 R  eth1_untagged7        1500  enabled    0       ether1
 1 R  eth1_vlan8            1500  enabled    8       ether1
 2 R  eth1_vlan9            1500  enabled    9       ether1
 3 R  eth2_vlan7            1500  enabled    7       ether2
 4 R  eth2_vlan8            1500  enabled    8       ether2
 5 R  eth2_vlan9            1500  enabled    9       ether2
[admin@mikrotik] > /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
 #    INTERFACE              BRIDGE              PRIORITY PATH-COST  HORIZON
 0    eth1_untagged7         vlan7_bridge      0x80     10         none
 1    eth1_vlan8             vlan8_bridge      0x80     10         none
 2    eth1_vlan9             vlan9_bridge      0x80     10         none
 3    eth2_vlan7             vlan7_bridge      0x80     10         none
 4    eth2_vlan8             vlan8_bridge      0x80     10         none
 5    eth2_vlan9             vlan9_bridge      0x80     10         none
 6    ether3                 vlan9_bridge      0x80     10         none
In the above example, ether1 would have mixed tagged/untagged traffic, ether2 only tagged traffic, and ether3 only untagged traffic. The above example assumes a new feature vlan-id=0 to create a VLAN subinterface to capture untagged traffic on a mixed tagged/untagged port.
So... is this possible yet in 4.x (not using vlan-id=0, but the ability to split/separate out untagged from tagged traffic)?
If not, is there any chance of a feature like this (probably easiest to do it with a vlan-id=0 hack) in future versions?
Thanks!
Aaron out.
astounding
*** FEATURE REQUEST ***
Thu Dec 10, 2009 11:20 pm
This thread should be properly retitled as a FEATURE REQUEST:
Add the ability to add a pesuedo VLAN zero to an interface that captures untagged traffic.
Thanks!
Aaron out.
Users browsing this forum: No registered users and 104 guests
