omar87
Hotspot page template
Sun Jan 10, 2010 3:52 pm
guys it is impossible to provide me hotspot page template like crystal login page and I will do some change on it please I need to change my hotspot page and make a new page for our company .
thanks, :shock:
fewi
Re: Hotspot page template
Sun Jan 10, 2010 6:46 pm
I don't know what a 'crystal page' is.
The Hotspot login page the router generates is fully functional. Just change its looks. If you don't know how to hire a webdesigner.
omar87
Sun Jan 10, 2010 7:17 pm
fewi I have some experience about the design but I need a simple page and I will do edit on the page . I have attached pictures for you to see which design I needed
reinerotto
Mon Jan 11, 2010 12:49 am
You need to change the standard login-page for the hotspot, as supplied from MT.
But you have to edit it directly, not using tools like NVU etc.
BUT: Do not tamper around with the "weired" code you see, which is NOT HTML.
In case, you do not know, what this "weired" code stands for, you should learn it from the docs first.
omar87
Mon Jan 11, 2010 9:28 am
reinerotto I designed the page but I don't know from where can I get the username and password code
omar87
Mon Jan 11, 2010 9:44 am
normis
Mon Jan 11, 2010 10:52 am
1. install and enable Hotspot in your RouterOS router
2. download the Hotspot folder from the Files folder
3. Edit the Login.html page
The default login page is as good a template as any
omar87
Mon Jan 11, 2010 5:15 pm
normis I fnish every thing and I designed hotspot page and the page ready but my point here!!! how can I upload the new hotspot page in a Hotspot file in FTP
normis your advice
fewi
Mon Jan 11, 2010 6:13 pm
Make sure FTP is enabled under IP/Services. Make sure you're permitted by the firewall to access the router via FTP. Open the router IP in an FTP client and provide a username and password permitted FTP access. Find the folder that your Hotspot profile names for the HTML files. Upload files to that folder.
All of that is covered in the manual.
omar87
Mon Jan 11, 2010 8:17 pm
fewi can you give me the steps please and if you have link for the manual that will be better to help me
and thank you for the advice
fewi
Mon Jan 11, 2010 9:23 pm
omar87
Mon Jan 11, 2010 10:38 pm
fewi the size for my hotspot page is 1.92 KB is that good because my frined tell me the mikrotik router mabye will be st :shock: uck sometimes if the size big.
fewi
Mon Jan 11, 2010 10:45 pm
a) 1.92KB is tiny
b) why don't you just go ahead and try it out?
omar87
Mon Jan 11, 2010 11:18 pm
ok as you say I will try but I need know something I read some topics from the manual but how I can add the hotspot page from where and how?
I need your steps not manual steps and thank you for your effort with me
please your advise
omar87
Tue Jan 12, 2010 11:36 pm
I opened the hotspot folder and I removed the default login page and replaced with the new login page and I uploaded the folder after then I open the internet!!! nothing no login page no internet so I entered to mikrotik by mac address and maked my account bindings -bypass-and worked again on the FTP still same problem ,so I returned to the old page and it worked.
so why my new page doesn't work is there any one know what the problem and what can I do to let my new page work ?
fewi
Tue Jan 12, 2010 11:54 pm
Post the output of "/file print", "/ip hotspot print detail" and "/ip hotspot profile print detail" with the new pages installed.
omar87
Wed Jan 13, 2010 10:28 am
fewi can you give me your email address like skype or any chat messenger because I need your help directly not in the forum.
car1cow
Sat Jan 16, 2010 3:44 pm
As salam,
Send me an email I think I can help you out.
omar87
Sat Jan 16, 2010 5:44 pm
ok that will be good for me
add me I will wait you and your help my friend
thanks'
huzz
Fri Sep 30, 2011 9:13 am
Greetings,
is anybody willing to share the template ?
Please do send at huzaifa[at]kudrati[dot]net
Thanks,
Huzz
sayedesa
Mon Oct 03, 2011 3:23 pm
this is my email address naimat_khan75@yahoo.com plz if any one can speak urdu than plz send me your email address i need your help
dunga
Mon Oct 03, 2011 5:29 pm
any better login templete you can send it to my email plz, my email is obinna4god@yahoo.com.
faisal
Thu Oct 20, 2011 11:01 am
as salam walicom
i am naimat khan plz agar koi urdu speaker ho tu meri help kare meri id hai
naimatdawood@hotmail.com
skype naimat_khan75
dunga
Thu Dec 29, 2011 7:36 pm
Hello all,
Can someone just upload his login page template, i need to build and create from there.
I am faced with a task of modifying the login page to suite the firms product and services with picture, i need some that has a banckground picture.
Thanks your help will be appreciated. Fewi, you can be of help just do something
jnciexin
Tue Nov 19, 2013 5:01 pm
thank you~~~~
sinagaularsawa
Fri Oct 03, 2014 12:48 pm
Here's available free mikrotik login template
http://adf.ly/sZV5z
kzla
Thu Sep 24, 2015 2:25 pm
I was tinkering with hotspot page and just made this
Users browsing this forum: MSN [Bot] and 71 guests
