MUM Europe 2020
uwe_guenther
Web Proxy sends wrong HTTP Version number to the WebServer
Mon Jul 12, 2004 10:22 pm
Hello at forum.mikrotik.com,
I use Mikrotik 2.8.11 with transparent web proxy. Some costumers have problems with some webshops (e.g. neckerman.de). So I disable the transparent web proxy for this costumers.
Further I did some investigetion and I figured the following out:
If the WebBrowser did the Following Request:
GET / HTTP/1.1
Accept: text/*
Host: http://www.abcdefg.de
The WebServer sees:
GET / HTTP/1.0
Accept: text/*
Cache-Control: max-age=259200
Connection: keep-alive
Via: 1.1 my.proxy.net:3128 (squid/2.5.STABLE4)
X-Forwarded-For: 10.0.0.2
Can some one explain me why web proxy changes the HTTP Version from 1.1 to 1.0? Is this a BUG or a Feature?
Best Regards Uwe
normis
Tue Jul 13, 2004 10:44 am
This is because the Mikrotik Webproxy uses squid.
Squid is HTTP 1.0 compliant, but understands most HTTP 1.1 headers for
cache control. And HTTP version number is peer-to-peer dependent and not end-to-end.
Bill
Tue Jul 13, 2004 5:45 pm
Are they using Internet Explorer? Under the Advanced Tab for Internet Options is a check box to use HTTP 1.1 with web proxies. It is about half way down the list. Check that and see if it helps any.
uwe_guenther
Tue Jul 13, 2004 8:21 pm
Hello Bill,
the Browser doesn't know about the proxy. I use the transparent proxy feature with dst-nat rule. Say the MT Router will redirect all Port 80 requests to the internal web proxy of the MT Router. So you doesn't have to setup the browser for a proxy usage.
Thanks Uwe
uwe_guenther
Tue Jul 13, 2004 8:23 pm
Hello Normis,
I am right in reading your answer, that Squid doesnt support HTTP/1.1?
Thanks Uwe
Users browsing this forum: No registered users and 123 guests
