norocel
Help configure ppp-server
Fri Jan 15, 2010 10:55 am
I need a dial-in server.
ROS 3.22
My modem is "3COM U.S. Robotics 56k Faxmodem" conected to serial port 1 (COM1)
/ port
set serial0 name="serial0" baud-rate=57600 data-bits=8 parity=none stop-bits=1 \
flow-control=hardware
set serial1 name="serial1" baud-rate=38400 data-bits=8 parity=none stop-bits=1 \
/ interface ppp-server
add name="ppp-in1" max-mtu=1500 max-mru=1500 port=serial1 \
authentication=pap,chap,mschap1,mschap2 profile=Dial_In modem-init="" \
ring-count=1 null-modem=no disabled=no
interface ppp-server> monitor 0
status: "reseting modem..."
In the log window:
serial1 sent ATH
serial1 sent +++
Modem is not respoding.
What is the problem?
10x in advance
Chupaka
Re: Help configure ppp-server
Fri Jan 15, 2010 11:15 am
update to the latest version and check
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
norocel
Fri Jan 15, 2010 11:46 am
updated already
same result.
Users browsing this forum: mobinsaffarpour, nolitolits, nplus and 117 guests
