sathishsa
Step by step Load balancing in v4.4 helpfull for many users.
Tue Jan 19, 2010 9:41 am
HI,
First of all many thanks to Mikrotik professionals and from a long time there is a many problem by the user in implementing the right and exact load balancing i will explain my network senario with image and also i will give the requests below what i exactly nedded
sorry for my bad diagram but i think u guys will understand, I came to know tht ECMP will drop the connections on masquerade network , So please give me the detailed GUI config if possible , if cant atlease command line config but please give the step by step detailed
Once again i appreciate the experts and professional for making this forum success
Thanks,
Sathish
Pada
Re: Step by step Load balancing in v4.4 helpfull for many users.
Tue Jan 19, 2010 5:20 pm
You could do policy based load balancing. Eg. splitting the 300 users into 3 groups of 100 - 1 group per WAN connection. See http://wiki.mikrotik.com/wiki/Load_Bala ... e_Gateways
This is not the ideal solution though.
Here's an old forum thread where persistent load balancing using ECMP has been discussed:
http://forum.mikrotik.com/viewtopic.php?f=2&t=29464
sathishsa
Thu Jan 21, 2010 3:35 pm
Please give me the response , as iam waiting for the solution from along time
Thanks,
Sathish
Chupaka
Fri Jan 22, 2010 6:38 pm
sathishsa
Fri Jan 22, 2010 8:31 pm
Thanks for your kind reply Chupka, As i heard ECMP will flush routing table and disconnect clients for every 10min
and NTH is not a perfect load balance as we specify one fied GW for each clients if load on one GW will not be balanced automatically as this leads to bandwidth wastage on another GW
please try to help me in configuring ECMP like balancing without Dropping the connections for evry couple of minutes
Thanks in advance for skillfull answer , as there is no scope of using fully routed network in my case
Thanks,
Sathish
Chupaka
Fri Jan 22, 2010 9:04 pm
http://wiki.mikrotik.com/wiki/PCC#Appli ... _Balancing have nothing to do with ECMP and Nth
you may use per-connection-classifier=both-addresses-and-ports for ECMP-like balancing, but without flushes
sathishsa
Sat Jan 23, 2010 8:52 pm
Thanks,let me try it out soon
Sathish
sathishsa
Mon Jan 25, 2010 6:22 pm
Chupka iam having A small doubt in the above concept iwant use seperate Routerboard for load balance
i want to do the load balance through tht dedicated
WAN's > Routerboard (PCC) > Mikrotik main server > local network
So after the routerboard i will attach my server, so will it work i mean PCC load balance because all the requests will come from only one IP from mikrotik main server
the above senario works, please suggest me
sathish
Chupaka
Mon Jan 25, 2010 7:49 pm
sure it will work, if you will use 'both-addresses-and-ports' classifier
but be aware about ECMP problems: banking sites may deny your users, etc...
sathishsa
Wed Jan 27, 2010 3:02 pm
ECMP ? i dont want to configure ECMP i want follow your instruction and want to implement PCC, dou you mean banking sites also denies the users if i use PCC ?
And also please explain how to configure with example , please this may help the people a lot
i mean you said clasifier etc please explain cleary thanks
Chupaka
Wed Jan 27, 2010 4:48 pm
do you do NAT on 'Mikrotik main server'?
explaination is in Manual: http://wiki.mikrotik.com/wiki/PCC#Theory
sathishsa
Wed Jan 27, 2010 7:41 pm
Yes , i do NATing
sathishsa
Wed Jan 27, 2010 7:44 pm
And also if i use 8 WAns how many group i have to divide
8/0 to 8/7
is the above senario is correct
Chupaka
Wed Jan 27, 2010 8:41 pm
Yes , i do NATing
hmmm... to what addresses do you perform NATting?.. if those lines are adsl lines - you should NAT on the router the lines are connected to...
sathishsa
Thu Jan 28, 2010 7:37 pm
I will get 8 WANS which are directly connected to internet cloud or may be ADSL but i will terminate and connect with the ADSL routers (DLINK) because in our location ADSL are provide through 1 pair copper ordinary telephone line which cant connect to Mikrotik directly So we will use some kind of ADSL routers and will dail automatically connects when they are switched on
So please proceed with the solution
My local network should be like 10.10.0.0/16
and WAN's Like 192.168.1.1 2.1 3.1 4.1 5.1 6.1......etc
So ihave to masquerade the connection
please post the solution
Chupaka
Thu Jan 28, 2010 11:16 pm
so, you will NAT twice: first on router, then on modem... it's not good practice :) I think, you should move PCC to your main router. but if you will do your scheme - then use 'action=same' instead of 'action=srcnat' on the main router - and all should work fine, on RB you should just mark routing according to PCC with 'both-addresses' classifier
sathishsa
Fri Jan 29, 2010 4:29 pm
Sorry confused , can u please tell me with much more clarity, iwill explain below which i understand please confirm me y or n
And abt my network info. i have to do natting compulsory in ADSL router as because my telecom people assigns public IP to DLink through PPPOE from normal telephone cable which i cant connect directly to mikrotik
and after tht please explain me how to skip 2nd natting in main mikrotik router, But should assign same network to all the lan people with perfect load balance
And i skipped RB in the middle because as u suggested to lower thr lookup's , as i came to know tht mikrotik has realsed 4port ethernet card so i skipped RB in the middle and i want to directly connect to main router
So, please give me much more suggestins to run my network reliably
Thank you very much for having much more time on my problem
i appreciate you tht u are giving more solution to the questions which are posing in this forums
Chupaka
Fri Jan 29, 2010 5:51 pm
your modems should be in Bridge mode, so that your router can establish PPPoE connections by himself
to connect many modems in Bridge mode, you need either many ethernet interfaces, or just a switch that supports VLANs =)
sathishsa
Sat Jan 30, 2010 7:25 am
Thank you very much , i will get the modem which supports Bridge mode which assigns public ip directly to Mikrotik router
i will attach 2 * 4 port ethernet cards and there will be one onboard ethernet card which will used for lan connections
and 8 ports for wans and will do natting in the main router only let me find how it goes , if anything doubtfull please support me
Thanks,
Sathish
sathishsa
Thanks,
Sathish
sathishsa
Sat Jan 30, 2010 7:31 am
Please Suggest the model of the ADSL2+ modems which supports Bridge mode and which helpfull to assign public ips to PC
Chupaka
Sat Jan 30, 2010 1:25 pm
I think, any modem can work in Bridge mode - it's mode where the modem is just transparent converter of ethernet to adsl, without any IP functions
sathishsa
Sun Jan 31, 2010 9:04 pm
Chupka a small conformation, can i use only one ethernet card for all 8 wans and use VLAn in the mikrotik router
8 wans >>. normal 10portswitch(unmnageble)>>> Mikrotik router 1 + 7VLANs >>>>> clients
is it works
thanks
fewi
Sun Jan 31, 2010 9:31 pm
You'd need a VLAN capable switch to plug the modems into. Each modem is on a separate VLAN and you connect the router to the switch on a link that carries all 8 WAN VLANs. Those 8 VLANs have nothing to do with how you deliver services to the clients behind the router.
Chupaka
Mon Feb 01, 2010 1:43 pm
or maybe your modems support VLANs - then unmanageable switch is enough. as a rule, they pass VLAN tags transparently
sathishsa
Tue Mar 30, 2010 3:54 pm
Hi chupka , thanks for your great solution and can u please clarify me wht to do with the load balance config if WANS are assigned the Ip thorugh DHCp
Please tell me the solution it may help me alot
Sathish
Chupaka
Tue Mar 30, 2010 4:21 pm
well... default gateway should be the same for all WANs, is it?
sathishsa
Wed Mar 31, 2010 12:08 pm
Thanks for your kind and fast reply
Please give me both the solutions, i.e what if the gateway is same for all wan's
and also what if not
sathish
Chupaka
Sun Apr 11, 2010 2:59 am
this reply is not so fast =)
if your gateways are static, you should use '/ip route add gateway=ip_address%interface' syntax when adding your routes via Terminal
lukkes
Tue Dec 07, 2010 5:45 am
hi chupaka, what about the dhcp taken gateways when two or more adsl have the same gateway? how should i use your command?
Chupaka
Wed Dec 08, 2010 8:33 pm
create static routes - you can't do that with dynamically created
lukkes
Wed Dec 08, 2010 9:51 pm
hmmm so i should program an script that take the default gateway and create the static route, but when run this script? that's the problem...
SamCurtis
Thu Dec 09, 2010 7:38 am
FAIL Ros ver 3.30
"add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=Local"
ERROR: LOCAL IS NOT A VALID INTERFACE
normis
Thu Dec 09, 2010 9:21 am
FAIL Ros ver 3.30
Do you really have an interface called "Local"? what happens if you hit Tab twice before entering the interface name? It should give you a list of valid options
SamCurtis
Thu Dec 09, 2010 12:36 pm
k, now I just feel retarted, lol, sorry
The question is, can I use an IP instead of an interface....
Im trying to load balance two gateways with two static adresses on a single interface and a dhcpserver on another and my switch doesnt support Vlans, baaawwwww there must be a way, but I have a thread open on that one so Ill take my props down teh road,
normis
Thu Dec 09, 2010 1:02 pm
You are using an old version, you can do it in newer versions, as per the manual:
http://wiki.mikrotik.com/wiki/Manual:IP ... _a_gateway
tanjil
Wed Jan 05, 2011 9:14 am
dear sir
i have 5 adsl load balance in one mikrotik..
and other mikrotik is 10 mbps with real ip
how to merge both bandwidth and distribute to my another ppppoe mikrotik
(10mbps ADSL +10mbps Realip )=20mbps...
Chupaka
Sat Jan 08, 2011 6:49 pm
need more details =)
generally: use 5 more PCC rules, marking all with the same routing-mark, and send those packets to your 10M line
tanjil
Sun Jan 09, 2011 12:12 am
hi chupaka
this load balance is working very well with 5 adsl dynamic pppoe ...
its working very nice in mikrotik.....
here is the settings ...
Total nic 6
>>5 ADSL nic is connected 5 ADSL Modem (bridge mode)
[admin@Adsl] /ip firewall mangle> pr
0 I ;;; ADSL1 PPPOE 1
chain=input action=mark-connection new-connection-mark=adsl1
passthrough=yes in-interface=pppoe-out1
1 I chain=input action=mark-connection new-connection-mark=adsl2
passthrough=yes in-interface=pppoe-out2
2 I chain=input action=mark-connection new-connection-mark=adsl3
passthrough=yes in-interface=pppoe-out3
3 I chain=input action=mark-connection new-connection-mark=adsl4
passthrough=yes in-interface=pppoe-out4
4 I chain=input action=mark-connection new-connection-mark=adsl5
passthrough=yes in-interface=pppoe-out5
2nd Rules
0 ;;; ==ALL OutPut ADSL 1
chain=output action=mark-routing new-routing-mark=adsl1 passthrough=no
11 ;;; ADSL2
chain=output action=mark-routing new-routing-mark=adsl2 passthrough=no
12 ;;; ADSL3
chain=output action=mark-routing new-routing-mark=adsl3 passthrough=no
13 ;;; ADSL4
chain=output action=mark-routing new-routing-mark=adsl4 passthrough=no
14 ;;; ADSL5
chain=output action=mark-routing new-routing-mark=adsl5 passthrough=no
then /ip route
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
10 0.0.0.0/0 pppoe-out1 1
pppoe-out2
pppoe-out3
pppoe-out4
pppoe-out5
ADC 10.10.0.0/18 10.10.0.6 AdslMain 0 (Total 10mbps)
each adsl have 2 mbps bandwidth
# NAME MTU MAC-ADDRESS ARP
0 R adsl1 1500 00:00:00:00:00:00 enabled
1 R adsl2 1500 00:cc:cc:cc:dd:99 enabled
2 R adsl3 1500 00:cc:cc:B5:D9:25 enabled
3 R adsl4 1500 00:E0:cc:cc:09:BC enabled
4 R adsl5 1500 00:27:19:cc:cc:cc enabled
5 R AdslMain 1500 00:04:75:cc:cc:cc enabled
Chupaka
Mon Jan 10, 2011 1:52 am
so you have simgle ECMP route with 5 gateways (of 2 Mbits) and want to add one more gateway with 10 Mbits. then you need to add that gateway 5 times, like this:
gateway=pppoe-out1,pppoe-out2,pppoe-out3,pppoe-out4,pppoe-out5,pppoe-10M,pppoe-10M,pppoe-10M,pppoe-10M,pppoe-10M
tanjil
Tue Jan 11, 2011 3:55 am
dear chupaka
can i merge this adsl bandwidth to another Realip gateway ?which have already 10mbps Bandwidth (static 1 Reali
Chupaka
Tue Jan 11, 2011 3:59 pm
just replace "pppoe-10M" with necessary gateway (interface or IP address)
tanjil
Tue Jan 25, 2011 12:46 am
i did for 5 pppoe but how to add one static IP (gateway) here.. i have 6 lancards!
my static Realip gateway is 10.10.0.1
and all adsl pppoe gateway is dynamic
how to load balance pppoe-out1 pppoe-out2,pppoe-out3,pppoe-out4,pppoe-out5, with 10.10.0.1 here..
pls give me a example..
Chupaka
Sun Feb 13, 2011 10:18 pm
here we go =)
gateway=pppoe-out1,pppoe-out2,pppoe-out3,pppoe-out4,pppoe-out5,10.10.0.1
sorry for the long delay - my vacation in Egypt =)
tanjil
Thu Mar 10, 2011 10:00 pm
Welcome back bro
im sorry i could not reply u
can u pls tell me step by step
i have been trying for long to do this :(
Chupaka
Fri Mar 11, 2011 2:15 am
trying what? what exactly you did and what was not working?
I'm on MUM now, but it didn't help me to become more telepathistic :(
tanjil
Wed Mar 23, 2011 8:47 pm
Dear Sir
i have load balance with 6 ADSL PPPOE connection..(using ecmp load balance) in one Mikrotik using 4.17 (Level 4)Licence version
And all of my users are connected on Anotehr Level 5 PPPOE server using mikrotik 5.0rc11
(this pppoe Servers gateway is 10.10.0.1 (another Mikrotik gateway Different ISP) Level 4 Licence....
ALL Server is Connected in my 1 Vlan
And users are connected another Vlan
Now i can Redirect only http traffic through another Squid Server (squid server gateway is (ADSL Mikrotik |Router)which is connected on this Vlan
but i cannot pass any other traffic to my ADSL router why...
can u pls tell me how to do it?
thanks...
Chupaka
Thu Mar 24, 2011 5:58 pm
be more specific. make a drawing. I cannot understand your (new?) problem
tanjil
Tue Apr 05, 2011 2:13 pm
Dear Sir
i have load balance using pcc rule in my mikrotik and its going nice ..the following rules are given
Now I want to merge or add more (adsl dyanamic pppoe 1 mbps connection) bandwidth here ....
or i want to route some traffic through new adsl pppoe bandwidth...
0 chain=srcnat action=masquerade out-interface=buct1
1 chain=srcnat action=masquerade out-interface=adsl2
;; Connection MARK
chain=input action=mark-connection new-connection-mark=buct1_conn
passthrough=yes in-interface=buct1
chain=input action=mark-connection new-connection-mark=adsl2_conn
passthrough=yes in-interface=adsl2
chain=output action=mark-routing new-routing-mark=to_adsl2
passthrough=yes connection-mark=adsl2_conn
chain=output action=mark-routing new-routing-mark=to_buct1
passthrough=yes connection-mark=buct1_conn
chain=prerouting action=accept dst-address=10.111.0.0/24
in-interface=Local
chain=prerouting action=accept dst-address=10.112.0.0/24
in-interface=Local
chain=prerouting action=accept dst-address=10.113.0.0/24
in-interface=Local
;;; Per Connection Classifier..
chain=prerouting action=mark-connection new-connection-mark=buct1_conn
passthrough=yes dst-address-type=!local in-interface=Local
per-connection-classifier=both-addresses:2/0
chain=prerouting action=mark-connection new-connection-mark=adsl2_conn
per-connection-classifier=both-addresses:2/1
chain=prerouting action=mark-routing new-routing-mark=to_buct1
passthrough=yes in-interface=Local connection-mark=buct1_conn
chain=prerouting action=mark-routing new-routing-mark=to_adsl2
passthrough=yes in-interface=Local connection-mark=adsl2_conn
1 A S 0.0.0.0/0 reachable 10.112.0.1 1 adsl2
2 S 0.0.0.0/0 reachable 10.112.0.1 2 adsl2
3 A S 0.0.0.0/0 reachable 10.111.0.1 1 buct1
4 A S 0.0.0.0/0 reachable 10.111.0.1 1 buct1
8 ADC 10.10.0.0/18 10.10.0.10 0 Local
9 ADC 10.111.0.0/24 10.111.0.2 0 buct1
10 ADC 10.112.0.0/24 10.112.0.2 0 adsl2
tanjil
Tue Apr 05, 2011 8:11 pm
is anybody can tell me
if i load balance 6 mbps +15mbps +1 mbps Link what pcc will be set?
fewi
Tue Apr 05, 2011 8:18 pm
I wouldn't recommend doing that at all. Leave out the 1Mbps link and use it just as a backup route if the 15Mbps and 6Mbps links go down.
To spread evenly across 15/6, use 5 rules that select the 15Mbps link, and 2 that select the 6Mbps link. Smallest common denominator is 3, 15/3 = 5, 6/3 = 2.
xezen
Long time Member
Long time Member
Tue Apr 05, 2011 10:15 pm
hmmmm very help full
tanjil
Wed Apr 06, 2011 11:40 am
can u pls tell me also 3/1 3/2 3/0 and 6 mbps + 2 mbps load balance settings with detail
im using 5.0 stable Level 5 (Licenced)Mikrotik
thanks
fewi
Wed Apr 06, 2011 5:14 pm
This is getting ridiculous. You are asking for help with math they teach to 8 year olds.
Each line for PCC is one unit. Find the lowest common denominator, and add the appropriate number of lines.
If you have a 6 meg circuit and a 2 meg circuit the lowest common denominator is 2. 6/2 = 3, 2/2 = 1, so you need 3 lines for the 6 meg circuit and 1 line for the 2 meg circuit.
Read the PCC wiki manual until you understand how it works. The manual is VERY clear in how it works.
tanjil
Thu Apr 07, 2011 7:01 am
yeah sometimes we asked absurd ludicrous question because of confusion also cudnt get detailed answer from here.. Like :)
anywys
If the fraction is 18/42 then simpler equivalent fractions are 9/21, 3/7 and 6/14.
However there are an infinity of equivalent fractions if the value of the denominator is increased :- 21/49, 24/56, 27/63, 30/70 etc.
here is the dEtails which is helpfull for many users may be ..
PCC Load Balance With 3 links adsl modem with bridge Mode (2 ISP Bandiwidth is 8 Mbps, 1 ISP BandWidth is 2mb)>Total 3 ISP with 18 mbps
ether1 = Local (Local Interface >Clients Access).
ether2 = wlan1 (Interface ISP1 With 8mbps Bandwidth)
ether3 = wlan2 (Interface ISP2 With 8mbps Bandwidth)
ether4 = wlan3 (Interface ISP3 With 2 mbps Bandwidth)
Total Bandwidth IS 18 mbps
Local IP:10.10.0.1/16
Interface wlan1 = 192.168.1.2/24 (IP no Adsl modem = 192.168.1.1) (using Bridge Mode)
Interface wlan2 = 192.168.2.2/24 (IP no Adsl modem = 192.168.2.1) (using Bridge Mode)
Interface wlan3 = 192.168.3.2/24 (IP no Adsl modem = 192.168.3.1) (using Bridge Mode)
add address=10.10.0.1/16 broadcast=10.10.0.255 comment="Local IP Address" disabled=no \
interface=Local network=10.10.0.0
add address=192.168.1.2/24 broadcast=192.168.1.255 comment="" disabled=no \
interface=wlan1 network=192.168.1.0 (Those Address For Access to your ADSL Modem If u dont Want.. U can Disable)
add address=192.168.2.2/24 broadcast=192.168.2.255 comment="" disabled=no \
interface=wlan2 network=192.168.2.0 (Those Address For Access to your ADSL Modem If u dont Want... U can Disable)
add address=192.168.3.2/24 broadcast=192.168.3.255 comment="" disabled=no \
interface=wlan2 network=192.168.3.0 (Those Address For Access to your ADSL Modem If u dont Want.. U can Disable)
set allow-remote-requests=yes cache-max-ttl=1w cache-size=10240KiB \
max-udp-packet-size=512 primary-dns=8.8.8.8 secondary-dns=\
8.8.4.4
/interface pppoe-client
add ac-name="" add-default-route=no allow=pap,chap comment=\
"PPPOE Cconnection 1-ISP1-wlan1(8Mbps Link)" dial-on-demand=no disabled=no interface=wlan1 \
max-mru=1480 max-mtu=1480 mrru=disabled name=pppoe-wlan1 password=xxxx \
profile=default service-name="" use-peer-dns=no user=details@perconnectionclassifierLoadbalance
"PPPOE Cconnection 1-ISP2-wlan2(8Mbps Link)" dial-on-demand=no disabled=no interface=wlan1 \
max-mru=1480 max-mtu=1480 mrru=disabled name=pppoe-wlan2 password=xxxx \
profile=default service-name="" use-peer-dns=no user=schoolboy@perconnectionclassifierLoadbalance
add ac-name="" add-default-route=no allow=pap,chap comment="PPPOE connection3-ISP1 3- wlan3(2Mbps Link)" dial-on-demand=no disabled=no \
interface=wlan1 max-mru=1480 max-mtu=1480 mrru=disabled name=pppoe-wlan3 password=xxxx \
add action=masquerade chain=srcnat comment="Masquerade pppoe-wlan1" disabled=no out-interface=pppoe-wlan1
add action=masquerade chain=srcnat comment=""Masquerade pppoe-wlan2" disabled=no out-interface=pppoe-wlan2
add action=masquerade chain=srcnat comment=""Masquerade pppoe-wlan3"" disabled=no out-interface=pppoe-wlan3
/ip firewall mangle
add action=accept chain=prerouting comment="" disabled=no \
dst-address-list=loopback in-interface=Local
add action=mark-connection chain=input comment=" Make the packet leaves via same interface(ISP18mbps) " disabled=no \
in-interface=pppoe-wlan1 new-connection-mark=wlan1_conn passthrough=yes
add action=mark-routing chain=output comment="(ISP1 8 mbps)" connection-mark=wlan1_conn \
disabled=no new-routing-mark=to_wlan1 passthrough=yes
add action=mark-connection chain=input comment="(ISP2 8mbps)" disabled=no in-interface=\
pppoe-wlan2 new-connection-mark=wlan2_conn passthrough=yes
add action=mark-routing chain=output comment="(ISP2 8mbps)" connection-mark=wlan2_conn \
disabled=no new-routing-mark=to_wlan2 passthrough=yes
add action=mark-connection chain=input comment="(ISP3 -2mbps)" disabled=no in-interface=\
pppoe-wlan3 new-connection-mark=wlan3_conn passthrough=yes
add action=mark-routing chain=output comment="(ISP3= 2mbps)" connection-mark=wlan3_conn \
disabled=no new-routing-mark=to_wlan3 passthrough=yes
Example = 10 lines for 5 mbps, 3 lines for 6 mbps bandwidth, 5 lines for 2.5 mbps, 9 lines for 18 mbps
*Note We have split Total 18 mbps(8 mbps(ISP1- 8mbps+ISP2 + 2 mbps-ISP3 > 18/2=9(the smallest no
is 2)
add action=mark-connection chain=prerouting comment="Load Balance PCC" disabled=no dst-address-type=!local in-interface=Local
new-connection-mark=wlan1_conn passthrough=yes per-connection-classifier=both-addresses-and-ports:9/0
add action=mark-connection chain=prerouting comment="" disabled=no \
dst-address-type=!local in-interface=Local new-connection-mark=wlan1_conn \
passthrough=yes per-connection-classifier=both-addresses-and-ports:9/1
passthrough=yes per-connection-classifier=both-addresses-and-ports:9/2
passthrough=yes per-connection-classifier=both-addresses-and-ports:9/3
dst-address-type=!local in-interface=Local new-connection-mark=wlan2_conn \
passthrough=yes per-connection-classifier=both-addresses-and-ports:9/4
passthrough=yes per-connection-classifier=both-addresses-and-ports:9/5
passthrough=yes per-connection-classifier=both-addresses-and-ports:9/6
passthrough=yes per-connection-classifier=both-addresses-and-ports:9/7
dst-address-type=!local in-interface=Local new-connection-mark=wlan3_conn \
passthrough=yes per-connection-classifier=both-addresses-and-ports:9/8
add action=mark-routing chain=prerouting comment=\
"===== Marking all the packets =====" connection-mark=wlan1_conn \
disabled=no in-interface=Local new-routing-mark=to_wlan1 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=\
wlan2_conn disabled=no in-interface=Local new-routing-mark=to_wlan2 \
passthrough=yes
wlan3_conn disabled=no in-interface=Local new-routing-mark=to_wlan3 \
passthrough=yes
add check-gateway=ping comment="" disabled=no distance=1 dst-address=\
0.0.0.0/0 gateway=pppoe-wlan1 routing-mark=to_wlan1 scope=30 \
target-scope=10
0.0.0.0/0 gateway=pppoe-wlan1 scope=30 target-scope=10
0.0.0.0/0 gateway=pppoe-wlan2 routing-mark=to_wlan2 scope=30 \
target-scope=10
add check-gateway=ping comment="" disabled=no distance=2 dst-address=\
0.0.0.0/0 gateway=pppoe-wlan2 scope=30 target-scope=10
0.0.0.0/0 gateway=pppoe-wlan3 routing-mark=to_wlan3 scope=30 \
target-scope=10
add check-gateway=ping comment="" disabled=no distance=3 dst-address=\
0.0.0.0/0 gateway=pppoe-wlan3 scope=30 target-scope=10
tanjil
Sat Apr 09, 2011 4:44 am
dear support
will u pls give me example of pcc load balance (fail over rules) if my one gateway down cant browse anywhere...
Users browsing this forum: kormenator and 169 guests
