nfillon
need the changelog of firmware 2.20 RB 600
Wed Jan 20, 2010 8:54 pm
Hello, need the changelog of firmware 2.20 RB 600.
normis
Re: need the changelog of firmware 2.20 RB 600
Thu Jan 21, 2010 9:26 am
What's new in 2.25:
*) fixed etherboot on RB493;
*) fixed occasional lockup of kernel image loading on RB400 series;
*) added disable UART feature;
What's new in 2.24:
*) added support for RB816;
What's new in 2.23:
*) added support for RB750G;
*) added support for RB800;
What's new in 2.22:
*) fixed support for RB750;
What's new in 2.21:
*) added support for RB750;
What's new in 2.20:
*) added support for RB450G;
What's new in 2.19:
*) fixed support for MLC NAND chip;
*) fixed memory issue on RB600;
What's new in 2.18:
*) fixed via-rhine disappearing on RB532 and RB564;
*) added support for RB493AH;
What's new in 2.17:
*) added support for MLC NAND chip;
What's new in 2.16:
*) fixed bug - boot from NAND on RB532A could fail (bug introduced in 2.13);
*) fixed bug - etherboot on RB433/RB450 at 10Mbit did not work;
honzam
Thu Jan 21, 2010 12:55 pm
LAN, FTTx, Wireless. ISP operator
honzam
Sat Jan 23, 2010 11:00 pm
What are the changes in the firmware 2.24 for the RB800?
Why can not you write changelog as it was before? To file http://www.routerboard.com/files/rb-2.24/CHANGELOG?
normis
Mon Jan 25, 2010 8:38 am
nothing new. I updated the post above. only support for new products added. that's all
honzam
Mon Jan 25, 2010 9:34 am
Where to download 2.25? Thanks
normis
Mon Jan 25, 2010 9:37 am
All firmware updates are integrated into the software. Upgrade RouterOS to v4.5 and then type "/system routerboard upgrade". It will then update to the latest version that's available for your board model. NOTE: different boards have different versions. For some v2.23 is the latest version.
honzam
Mon Jan 25, 2010 10:44 am
I just wanted to firmware 2.25 for the platform mipsbe. But I do not yet upgraded to 4.x. On routerboard.com is so far only firmware 2.23.
normis
Mon Jan 25, 2010 10:45 am
if it's not on the webpage (routerboard.com) then there is no newer version for your model.
rodneal
Mon Mar 08, 2010 4:40 am
Now that is very cool - just remember that you have to remove all previous copies from files before or it will only recognize those.
So much easier and I learned it here!!
Thanks, Normis!!
roc-noc.com
Forum Veteran
Forum Veteran
Mon Jul 19, 2010 4:08 am
Can we get a regular location for RouterBoot changelogs that gets updated?
Thanks,
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
normis
Mon Jul 19, 2010 8:11 am
honzam
Wed Jan 19, 2011 8:20 pm
Where is changelog for 2.29 ?
normis
Thu Jan 20, 2011 11:39 am
Updated
honzam
Mon Jan 24, 2011 5:50 pm
Updated
and 2.30? Website is again outdated
normis
Mon Jan 24, 2011 5:55 pm
check again
honzam
Mon Jan 31, 2011 2:43 pm
Some bug in 2.30? It was a download, but not now
http://www.routerboard.com/pricelist.php
normis
Mon Jan 31, 2011 2:45 pm
Some bug in 2.20? It was a download, but not now
which product?
honzam
Mon Jan 31, 2011 9:22 pm
I meant 2.30. Error in previous post
All mipsbe version offers only 2.29
normis
Tue Feb 01, 2011 10:09 am
it means there is no newer version available, apparently there was a mistake previously. only PPC has v2.30
honzam
Tue Feb 08, 2011 12:30 pm
and 2.31?
normis
Tue Feb 08, 2011 12:40 pm
Updated
honzam
Fri Feb 11, 2011 9:58 am
Normis: Please could you write RouterBOOT changelog automatically whenever released a new version?
We have 5.0RC9 and RouterBOOT 2.32
normis
Fri Feb 11, 2011 10:01 am
as you can see from previous changelog lines, the changes are not important for existing users about 98% of the time. the changes usually add support for new products. v2.32 has no changes that I can reveal
MichelePietravalle
Trainer
Trainer
Wed Nov 30, 2011 10:51 am
What about 2.38? thanks!
normis
Wed Nov 30, 2011 10:56 am
new product added
MichelePietravalle
Trainer
Trainer
Wed Nov 30, 2011 10:59 am
Users browsing this forum: matxanh and 78 guests
