MUM Europe 2020
ckgth
Is there a Routing bug in 4.5 ?
Fri Jan 29, 2010 6:32 pm
The lokal Interface shows 'unreachable' and the Route to the loopback on the other side too:
The System ist RB/1000 with ROS 4.5.
changeip
Re: Is there a Routing bug in 4.5 ?
Fri Jan 29, 2010 6:54 pm
11.0.0.1 is a /32 on loop, so 11.0.0.2 isnt in the same subnet, therefore unreachable because there is no gateway to it.
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
fewi
Fri Jan 29, 2010 6:59 pm
11.0.0.2 (please don't use other people's assigned IP space?) resides on the router on the other side of the /30 on eth2, it's supposed to be reachable via a static route to 10.0.1.25. Since the directly connected route on eth2 shows unreachable that static is also unreachable. Don't know why though, since the interface is showing as running.
ckgth
Fri Jan 29, 2010 7:18 pm
of course. The gateway to 11.0.0.2/32 is 10.0.1.25/30. What is wrong there?
ckgth
Fri Jan 29, 2010 7:28 pm
do you think there is a cable problem?
I Think there is a problem of auto-negotation and/or full-duplex on RB/1000.
I have test. Without auto-negotation on 100 MB full-duplex firm it works!
a public one it is okay 11.0.0.0 wet. But it gives up no routes (from the outside).
Users browsing this forum: mkx and 122 guests
