unm
PPPOE server and Mikrotik-Rate-Limit
Tue Feb 02, 2010 9:05 am
Hi all,
I have mikrotik ver. 4.4. I am using pppoe server + radius(freeradius). Radius set Mikrotik-Rate-Limit for client.
And i want to know, can i set for client pppoe, diffrent Mikrotik-Rate-Limit to diffrent route, for example:
route 10.0.2.0/24 : Mikrotik-Rate-Limit -> unlim
route other : Mikrotik-Rate-Limit -> radius set
Madrox
Re: PPPOE server and Mikrotik-Rate-Limit
Tue Feb 02, 2010 9:47 am
Im looking for this to, so that my local part of the network get higher speed. use pppoe rate on out from our network.
CrazyMonkey
Wed Feb 03, 2010 11:50 pm
I also have a question on this. Does the rate limit apply to the session as a group or to the users of the session?
i.e. set a 50 meg limit and this 50 meg applies to all 10 ppp users, 10 users get 50 meg or... is it 50 meg per user?
regards
CM
Chupaka
Thu Feb 04, 2010 7:07 pm
queue with 'Rate' parameters is created dynamically for each connected user, not for the group of users
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
CrazyMonkey
Thu Feb 18, 2010 12:21 pm
What would the easiest way be to rate limit the group/profile?
Regards
R
Users browsing this forum: carlosaat, dleo, hapoo, meazz1, MSN [Bot], nemoonpc and 200 guests
