engineertote
problem with upgrade RB800 OS from 4.2 to 4.5
Sun Feb 07, 2010 11:51 am
Hi all
i have RB800 need to upgrade it from OS4.2 to 4.5 .. i have downloaded the new packages from Mikrotik web site and past it in the file list via winbox and then reboot the RB800 ,, the new packages now uploaded to the file list but the OS still show 4.2 , bellow the results :
[admin@MikroTik] > file print
# NAME TYPE SIZE CREATION-TIME
0 4.5/advanced-t... package 140409 jan/02/1970 00:02:04
1 4.5/ppp-4.5-pp... package 335481 jan/02/1970 00:02:06
2 4.5/routerboar... package 184773 jan/02/1970 00:02:06
3 4.5/routing-4.... package 485335 jan/02/1970 00:02:07
4 4.5 directory jan/02/1970 00:02:04
5 4.5/security-4... package 433159 jan/02/1970 00:02:07
6 4.5/system-4.5... package 8387200 jan/02/1970 00:02:16
7 4.5/calea-4.5-... package 24307 jan/02/1970 00:02:04
8 4.5/ups-4.5-pp... package 66855 jan/02/1970 00:02:16
9 4.5/dhcp-4.5-p... package 152119 jan/02/1970 00:02:05
10 4.5/user-manag... package 485720 jan/02/1970 00:02:16
11 4.5/gps-4.5-pp... package 14163 jan/02/1970 00:02:05
12 4.5/wireless-4... package 681752 jan/02/1970 00:02:17
13 4.5/hotspot-4.... package 233683 jan/02/1970 00:02:05
14 4.5/ipv6-4.5-p... package 277472 jan/02/1970 00:02:05
15 4.5/mpls-4.5-p... package 246301 jan/02/1970 00:02:05
16 4.5/multicast-... package 234144 jan/02/1970 00:02:06
17 4.5/ntp-4.5-pp... package 150171 jan/02/1970 00:02:06
[admin@MikroTik] > system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 routeros-powerpc 4.2
1 system 4.2
2 wireless 4.2
3 routerboard 4.2
4 hotspot 4.2
5 X ipv6 4.2
6 advanced-tools 4.2
7 mpls 4.2
8 security 4.2
9 routing 4.2
10 ppp 4.2
11 dhcp 4.2
[admin@MikroTik] >
is there something i have to do for upgrade correctly .
Ahmed
MTCNA , MTCTCE , MTCRE , MTCINE
roc-noc.com
Forum Veteran
Forum Veteran
Re: problem with upgrade RB800 OS from 4.2 to 4.5
Sun Feb 07, 2010 12:53 pm
Did you reboot with 'system reboot' or just remove power and power back up?
I upgraded a pair of RB800s with the PPC combined pacage without problems.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
engineertote
Sun Feb 07, 2010 1:01 pm
Hi
i did through system--reboot ,, i also after that when its not upgraded turn it power off and on and both are same ..
but the package i download it is " All packages " not the combined packages .. is this affect ?
Regards
Tom
Ahmed
ste
Sun Feb 07, 2010 1:32 pm
Hi all
Flags: X - disabled
1 system 4.2
2 wireless 4.2
3 routerboard 4.2
4 hotspot 4.2
5 X ipv6 4.2
7 mpls 4.2
8 security 4.2
9 routing 4.2
10 ppp 4.2
11 dhcp 4.2
[admin@MikroTik] >
Does the log says anything like "broken package"?
Chupaka
Sun Feb 07, 2010 2:40 pm
yes, in '/log print' you will see the reason
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
duvi
Sun Feb 07, 2010 4:44 pm
You only need to upload routeros-powerpc-4.5.npk and then reboot.
normis
Mon Feb 08, 2010 9:54 am
if that a Folder I see?
RouterOS doesn't support folders
upload all NPK files to the root level of the file tree.
engineertote
Mon Feb 15, 2010 2:42 pm
Thanks ,, i did and its succefully upgraded .
Ahmed
Users browsing this forum: No registered users and 154 guests
