normis
SCSI and SAS support in RouterOS
Tue Feb 16, 2010 12:50 pm
There are many different adapters and drivers, if you would have to choose, what would be the most popular SCSI/SAS controller model to support? What server class hardware is the most popular in your area, the most available and reasonably priced? If we would add support for one or two controllers, which ones would they be?
Please share your experience and opinion
Chupaka
Re: SCSI and SAS support in RouterOS
Tue Feb 16, 2010 12:59 pm
it reminds me of the topic about USB UPSes :( sorry for my pessimism
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
rickhodger
Tue Feb 16, 2010 1:05 pm
At the very least, support the megaraid, megaraid_sas drivers and 3ware drivers.
They will cover most SCSI/SAS RAID controllers available. For example, almost all Dell PERC SCSI controllers use the megaraid drivers, and all the Dell PERC SAS (eg. 6/6i) controllers use the megaraid_sas drivers, and HP use LSI controllers which also use the megaraid drivers. The next most common one I know of and have seen is the 3ware cards, which are quite often used in custom, home-made or industrial chassis. These are very mature, stable drivers and should pose no problems.
nz_monkey
Wed Feb 17, 2010 12:46 am
Suport for megaraid.ko and ahci.ko would be nice.
If deploying x86 hardware we always use Dell or Axiomtech and this will cover both of them.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet NSE7 | Extreme Networks ENA
brianlewis
Sun Feb 21, 2010 6:14 pm
Support for Intel SATA for CDROM installs would be helpful. Currently if you boot the ISO image on an x86 system with Intel chipset/SATA and SATA DVD drive, it gives a 'FATAL ERROR: no CD-ROM found', although it does show 'Found hard drive as SATA 0' so its loading the controller, but currently seems to only support IDE CDROM drives. Motherboards don't come with IDE controllers anymore!
Loading drivers
Looking for harddrives...
Found harddrive as SATA 0
Press ENTER to reboot
Router OS v4.5 ISO IMAGE
DVDRW SATA DRIVE
nz_monkey
Mon Feb 22, 2010 12:28 am
ahci.ko should fix the issue with sata cd-roms.
kapulan
Thu Mar 04, 2010 10:06 pm
Smart array 5i Plus
1 Vote
Integrated scsi adapter proliant G servers.
keefe007
Fri Mar 05, 2010 4:31 am
HP SmartArray
3Ware
Areca
krtko
Sat Mar 06, 2010 8:48 am
LSI Logic® LSISAS 1068
fujitsu siemens blade servers
namery
Thu Mar 11, 2010 2:54 pm
magaraid for dell servers please
Eising
Tue Mar 16, 2010 1:53 pm
cciss and hpsa for HP SmartArray please!
The road to hell is paved with good intentions.
gustkiller
Mon Apr 12, 2010 10:55 pm
Mikrotik Certified Consultant
kapulan
Thu Apr 15, 2010 12:21 pm
New information the scsi support? Start Implement ros5 ?
dssmiktik
Forum Veteran
Forum Veteran
Thu Apr 15, 2010 10:47 pm
What's the status of SATA support in v5? hard disk and cdrom support?
mindragon
Tue Apr 20, 2010 5:51 pm
Support for the VMWare SCSI drivers would be nice.
normis
Mon May 10, 2010 1:23 pm
We added some SCSI drivers in v5beta2, can somebody please test with a demo key or 24h trial?
csickles
Mon May 10, 2010 4:10 pm
Any info on which drivers ??
Things that make you go "Hmmmmmmmm"...
Craig
normis
Tue May 11, 2010 9:16 am
3w-9xxx
arcmsr
megaraid
but I can't say they work 100%, please test if you have a device
csickles
Tue May 11, 2010 4:21 pm
So...
3-Wire
VMWare
Dell SATA/ SAS
K...
I have a 2950 laying arround...
I will scrounge up some memory for it (I raided it for my 2900) and see if she loads up..
(Tonight if all goes well....)
Craig
vgrigori
Thu May 13, 2010 12:10 pm
3w-9xxx
arcmsr
megaraid
Please include driver for SCSI adapter 'Adaptec aic7899' (Dell PowerEdge 2650 servers)
I have a lot of this servers.
I PROMISE to test this release and send the FULL test report
Thnx
leon84
Mon May 17, 2010 5:55 pm
I have this server:
4 x Dell PowerEdge 750
4 x Dell PowerEdge 850
4 x Dell PowerEdge 1750
2 x Dell PowerEdge 1850
3 x Dell PowerEdge 2950
2 x Dell PowerEdge R310
I would like to run Mikrotik Router OS on these servers all with DELL Perc RAID controller.
It is very important for me to have raid support in router os.
I hope you insert this feature in the next release....
nz_monkey
Mon May 17, 2010 11:12 pm
The Dell Perc6i cards use megaraid.ko not sure about the older servers, the oldest any of our clients have is 2950.
JwTPN
Wed May 19, 2010 1:21 am
another vote for the HP smart array series..
Justin Wells
Dodgy Contractor
New Zealand
aresibo
Sun May 30, 2010 3:08 pm
Dell PowerEdge RAID Controller /PERC/ :)
Horus
Mon May 31, 2010 2:25 pm
HP Smart Array 5i, please.
normis
Mon May 31, 2010 2:27 pm
did you miss my post about added SCSI drivers?
please somebody test
csickles
Tue Jun 01, 2010 7:00 am
My Dell 2950 Got Shanghighed for a remote access server...
Testing with VMWare 4.0Rev1
Craig
csickles
Tue Jun 01, 2010 7:11 am
Under VMWare 4.X ...
SCSI drivers fail (also paravirtual)..
IDE mode loads fine...
Craig
janisk
Tue Jun 01, 2010 2:02 pm
do Vmware virtual scsi use one of named drivers?
manners
Thu Jun 10, 2010 6:00 pm
Could we have the drivers included for the lenovo thinkserver
this seems to use the LSI SAS1064E controller which i can only assume is not supported as of yet, or if it is the driver do not seem to work,
I have tried to install using netinstall and using the 5.2beta.iso,
Netinstall - crashes with the error no harddrives found FATAL ERROR
The ISO - Crashes before it actually loads any drivers or looks for HDD's
Many thanks
normis
Fri Jun 11, 2010 8:02 am
Does anyone actually care about SCSI support? All I see here is requests, but nobody has tested the drivers we included by popular demand ...
csickles
Fri Jun 11, 2010 9:01 am
I no longer have an open server with the supported hardware..
We are a HP shop...
I HAD a couple of Dells (2900 and 2950) but they got shnagged before I could load them...
The 2900 ended up at my house as my VMWare host, and the 2950 ended up as a remote access server (term Serv) for work...
HP SCSI / SAS / SATA array adapters I can test...
Craig
Horus
Fri Jun 11, 2010 1:02 pm
I can test HP Smart array 5i
Eising
Mon Jun 14, 2010 8:57 pm
It took me a while to find a server recently that actually was able to boot RouterOS. Most of the devices I would want to install RouterOS on are HP servers, and they all run some sort of SAS.
andryan
Sun Jun 20, 2010 12:33 am
I will test the arcmsr driver on Monday, I have 1 spare server lying around with ARC-1210 card in it.
ihernandez
Wed Jun 23, 2010 8:12 am
Did anyone test the drivers?, I do not have available Dell servers so I can't test but Normis is right it appears nobody is testing so far
Regards,
Ignacio
ibizamale
Thu Jun 24, 2010 4:57 pm
Hiya all,
Sorry to sound like a Novice but i have a question.
We have just purchased a Dell Server it has a 146GB SAS drive.
When i try and install RouterOS 4.10 or 5.0 beta3
It errors with:
"FATAL ERROR: no harddrives found"
i am using the ISO from the full package
any ideas.
andryan
Fri Jun 25, 2010 5:20 am
I forgot to report back here.
My server is a Tyan S5211 barebone with ARC-1210, installer was able to detect the RAID card and it installed properly without any issue/error.
ibizamale
Fri Jun 25, 2010 11:52 am
Hiya All,
Just wondering if there was any updates on my question about the SAS drive please.
Regards
Lakis
Forum Veteran
Forum Veteran
Thu Jul 01, 2010 10:25 pm
PLs drv. suport for HP Smart array 5i
normis
Fri Jul 02, 2010 8:22 am
Hiya All,
Regards
we could only add the drivers I listed above. If your device doesn't work, I can't help, sorry.
normis
Fri Jul 02, 2010 8:23 am
I read that's it's a PCIe->SATA converter. This topic is about SCSI. Are you sure?
fsoaress76
Sun Jul 04, 2010 4:01 pm
Dell PowerEdge R610
Loading drivers...
looking for harddrives
FATAL ERRO no harddrivers found
yusabdu
Mon Jul 05, 2010 1:04 pm
Loading drivers...
janisk
Mon Jul 05, 2010 3:20 pm
please be detailed about what hardware exactly you are trying out, and what driver you thing this hardware will use.
fsoaress76
Tue Jul 06, 2010 1:10 am
Dell PowerEdge R610
Placa Controladora PERC 6/i SAS RAID, 2x4 Conectores internos, 256MB Cache
yusabdu
Tue Jul 06, 2010 12:56 pm
I use HP ML370 with SCSI adapter
gustkiller
Tue Jul 06, 2010 10:03 pm
Hp smartarray 200i
dhallam
Wed Jul 07, 2010 11:08 pm
HP Raid support would be great; we have just been investigating the PCI-e sata CF card option for
two new HP DL380's so for us HP/Array support would be fantastic!
normis
Thu Jul 08, 2010 8:54 am
so nobody actually has the previously requested
3w-9xxx (3Ware)
arcmsr (Areca)
megaraid (for Dell servers)
which we already support ?
Lakis
Forum Veteran
Forum Veteran
Fri Jul 09, 2010 11:39 pm
HP Raid support would be nice
omidkosari
Trainer
Trainer
Sat Jul 10, 2010 11:51 am
I think it is not a good way that mikrotik wants everyone request their drivers before releasing major version but after that they simply says not supported .
We can see there are a lot of driver requests every day . i suggest two ways to overcome such problems . The driver support should not limit only to pre major versions time .
1- There should be at least an API for other developers to release their own drivers.
2- Mikrotik release some driver files independently from mikrotik minor versions and users may download them from mikrotik site and simply upload it to RouterOS .
namery
Tue Jul 13, 2010 5:14 pm
Thanks Normis
Dell 2950 with sas raid it is working
namery
Thu Jul 15, 2010 1:44 pm
Resources PCI
Device Vendor Name
- 11:0d.0 ATI Technologies Inc ES1000 (rev: 2)
- 0b:00.1 Intel Corporation 82575GB Gigabit Network Connection (rev: 2)
- 0b:00.0 Intel Corporation 82575GB Gigabit Network Connection (rev: 2)
- 0a:00.1 Intel Corporation 82575GB Gigabit Network Connection (rev: 2)
- 0a:00.0 Intel Corporation 82575GB Gigabit Network Connection (rev: 2)
- 09:04.0 Integrated Device Technology, Inc. PES12N3A PCI Express Switch (rev: 14)
- 09:02.0 Integrated Device Technology, Inc. PES12N3A PCI Express Switch (rev: 14)
- 08:00.0 Integrated Device Technology, Inc. PES12N3A PCI Express Switch (rev: 14)
- 07:00.0 Broadcom Corporation NetXtreme II BCM5708 Gigabit Ethernet (rev: 18)
- 06:00.0 Broadcom EPB PCI-Express to PCI-X Bridge (rev: 195)
- 05:01.0 Intel Corporation 6311ESB/6321ESB PCI Express Downstream Port E2 (rev: 1)
- 05:00.0 Intel Corporation 6311ESB/6321ESB PCI Express Downstream Port E1 (rev: 1)
- 04:00.3 Intel Corporation 6311ESB/6321ESB PCI Express to PCI-X Bridge (rev: 1)
- 04:00.0 Intel Corporation 6311ESB/6321ESB PCI Express Upstream Port (rev: 1)
- 03:00.0 Broadcom Corporation NetXtreme II BCM5708 Gigabit Ethernet (rev: 18)
- 02:00.0 Broadcom EPB PCI-Express to PCI-X Bridge (rev: 195)
- 01:00.0 LSI Logic / Symbios Logic MegaRAID SAS 1078 (rev: 4)
- 00:1f.1 Intel Corporation 631xESB/632xESB IDE Controller (rev: 9)
- 00:1f.0 Intel Corporation 631xESB/632xESB/3100 Chipset LPC Interface Controller (rev: 9)
- 00:1e.0 Intel Corporation 82801 PCI Bridge (rev: 217)
- 00:1d.7 Intel Corporation 631xESB/632xESB/3100 Chipset EHCI USB2 Controller (rev: 9)
- 00:1d.2 Intel Corporation 631xESB/632xESB/3100 Chipset UHCI USB Controller #3 (rev: 9)
- 00:1d.1 Intel Corporation 631xESB/632xESB/3100 Chipset UHCI USB Controller #2 (rev: 9)
- 00:1d.0 Intel Corporation 631xESB/632xESB/3100 Chipset UHCI USB Controller #1 (rev: 9)
- 00:1c.0 Intel Corporation 631xESB/632xESB/3100 Chipset PCI Express Root Port 1 (rev: 9)
- 00:16.0 Intel Corporation 5000 Series Chipset FBD Registers (rev: 18)
- 00:15.0 Intel Corporation 5000 Series Chipset FBD Registers (rev: 18)
- 00:13.0 Intel Corporation 5000 Series Chipset Reserved Registers (rev: 18)
- 00:11.0 Intel Corporation 5000 Series Chipset Reserved Registers (rev: 18)
- 00:10.2 Intel Corporation 5000 Series Chipset FSB Registers (rev: 18)
- 00:10.1 Intel Corporation 5000 Series Chipset FSB Registers (rev: 18)
- 00:10.0 Intel Corporation 5000 Series Chipset FSB Registers (rev: 18)
- 00:07.0 Intel Corporation 5000 Series Chipset PCI Express x4 Port 7 (rev: 18)
- 00:06.0 Intel Corporation 5000 Series Chipset PCI Express x8 Port 6-7 (rev: 18)
- 00:05.0 Intel Corporation 5000 Series Chipset PCI Express x4 Port 5 (rev: 18)
- 00:04.0 Intel Corporation 5000 Series Chipset PCI Express x8 Port 4-5 (rev: 18)
- 00:03.0 Intel Corporation 5000 Series Chipset PCI Express x4 Port 3 (rev: 18)
- 00:02.0 Intel Corporation 5000 Series Chipset PCI Express x4 Port 2 (rev: 18)
- 00:00.0 Intel Corporation 5000X Chipset Memory Controller Hub (rev
Resources USB
Device Vendor Name Serial Number Speed
- 4:1 UHCI Host Controller 0000:00:1d.2 12 Mbps
- 3:1 UHCI Host Controller 0000:00:1d.1 12 Mbps
- 3:2 Logitech USB Receiver 1.5 Mbps
- 2:1 UHCI Host Controller 0000:00:1d.0 12 Mbps
- 1:1 EHCI Host Controller 0000:00:1d.7 480 Mbps
- 1:2 480 Mbps
- 1:5 Dell DRAC5 0000000 12 Mbps
- 1:6 DELL INC. DRAC5 VIRTUAL MEDIA 1028 123456 480 Mbps
- 1:4 480 Mbps
Stores Disk
Name Total Space Free Space Status
- usb1 #<kbytes># #<kbytes># ready
- usb2 #<kbytes># #<kbytes># formatting...
Many Thanks again
arigatox
Mon Jul 26, 2010 4:12 pm
I have installed RouterOS 5.0beta4 in a IBM x3200 M2 succesfully.
[admin@MikroTik] > system resource pci print
 # DEVICE   VENDOR                                      NAME                                     IRQ
 0 04:03.0  ATI Technologies Inc                        ES1000 (rev: 2)                          10
 1 0c:00.0  LSI Logic / Symbios Logic                   SAS1064ET PCI-Express Fusion-MPT SAS ... 5
 2 03:00.0  Broadcom Corporation                        NetXtreme BCM5722 Gigabit Ethernet PC... 10
 3 00:1f.5  Intel Corporation                           82801I (ICH9 Family) 2 port SATA IDE ... 11
 4 00:1f.3  Intel Corporation                           82801I (ICH9 Family) SMBus Controller... 10
 5 00:1f.2  Intel Corporation                           82801IR/IO/IH (ICH9R/DO/DH) 4 port SA... 10
 6 00:1f.0  Intel Corporation                           82801IR (ICH9R) LPC Interface Control... 0
 7 00:1e.0  Intel Corporation                           82801 PCI Bridge (rev: 146)              0
 8 00:1d.7  Intel Corporation                           82801I (ICH9 Family) USB2 EHCI Contro... 5
 9 00:1d.2  Intel Corporation                           82801I (ICH9 Family) USB UHCI Control... 11
10 00:1d.1  Intel Corporation                           82801I (ICH9 Family) USB UHCI Control... 10
11 00:1d.0  Intel Corporation                           82801I (ICH9 Family) USB UHCI Control... 5
12 00:1c.2  Intel Corporation                           82801I (ICH9 Family) PCI Express Port... 5
13 00:1c.1  Intel Corporation                           82801I (ICH9 Family) PCI Express Port... 10
14 00:1c.0  Intel Corporation                           82801I (ICH9 Family) PCI Express Port... 5
15 00:1a.7  Intel Corporation                           82801I (ICH9 Family) USB2 EHCI Contro... 11
16 00:1a.2  Intel Corporation                           82801I (ICH9 Family) USB UHCI Control... 11
17 00:1a.1  Intel Corporation                           82801I (ICH9 Family) USB UHCI Control... 10
18 00:1a.0  Intel Corporation                           82801I (ICH9 Family) USB UHCI Control... 5
19 00:01.0  Intel Corporation                           3200/3210 Chipset Host-Primary PCI Ex... 5
20 00:00.0  Intel Corporation                           3200/3210 Chipset DRAM Controller (re... 0
Everything is working fine. Uptime 20hrs with a usermanager authenticating 100 users.
Thanks!
normis
Wed Jul 28, 2010 10:15 am
thank you for the reports, much appreciated! it would be great if you could post the controller models in our wiki
http://wiki.mikrotik.com/wiki/Supported ... .2FRAID.29
csickles
Fri Sep 10, 2010 10:59 pm
I have a Cisco C200 or 210 comming as a lab play thing..
They run the LSISAS1064e Lets see if it runs !!!
And YES I WILL be taking pictures !!!
Craig
Eising
Sun Sep 12, 2010 8:33 pm
Is there any news regarding HP's cciss driver? Is it supported, or will it be supported?
gustkiller
Mon Sep 13, 2010 3:59 am
We have lots of HP servers that need cciss (smart array) driver
beukot
Wed Sep 15, 2010 12:38 pm
cciss, aac and ips support will be very nice.
ciss0: <Compaq Smart Array 5i> port 0x2000-0x20ff mem 0xf7ec0000-0xf7efffff,0xf5ef0000-0xf5ef3fff irq 16 at device 1.0 on pci0
ciss0@pci0:1:0: class=0x010400 card=0x40800e11 chip=0xb1780e11 rev=0x01 hdr=0x00
    vendor     = 'Compaq Computer Corp (Now owned by Hewlett-Packard)'
    device     = 'CISSB SMART2 Array Controller'
    class      = mass storage
    subclass   = RAID
ips0@pci3:1:0:  class=0x010400 card=0x028c1014 chip=0x02509005 rev=0x02 hdr=0x00
    vendor   = 'Adaptec Inc'
    device   = 'ServeRAID Controller'
    subclass = RAID
aac is Adaptec AdvancedRAID Controller driver (IBM ServeRAID 8i/k/s).
gustkiller
Sat Oct 02, 2010 5:08 pm
Please,
Add these scsi drivers, we have a bunch of hp servers, and i´m curretly running mikrotik on these via USB, but i´m afraid about kingston thumb drive reliability. and these servers only have that storage controller that doesnt have legacy mode.
http://cciss.sourceforge.net/
Smart Array E200i (SAS Controller) (rev: 0)
gustkiller
Thu Oct 07, 2010 3:53 pm
ppl with DELL servers .. i'm trying a new RoS pre release that supports HP SAS Controller.(Smart Array)
i created via controler a Logical drive but mikrotik doesnt recognized it. ppl with dell megaraid controller , what you did to have the disk recognized in mikrotik?
gustkiller
Thu Oct 07, 2010 4:01 pm
with the drivers, i shouldnt have problem with any kind of raid i did, becouse the Operational system will see the logical drives created in SaS controller as an physical disk. :(
We have about 30 Hp servers and 12 of them are these big ml350 servers with that controller. these where bought to be our core routers. 2gbits internet feed :(
tmcaldwell
Wed Oct 13, 2010 2:43 am
3w-9xxx
arcmsr
megaraid
Thnx
I just tried V5.0rc1 on my PowerEdge 2650. I'm loading from a CD created using the .iso image. The install cannot find the hard drive. I tried with the controller in SCSI mode ( and formatted the drive ) and in RAID mode ( formatting the drive, and creating a container. ) No joy either way.
Is there another version I should try ?
Thanks,
Todd
rveerappan
Tue Oct 26, 2010 8:43 pm
Tested V5.0rc1 on DL380 G3. Controller not recognized.
I saw the 5i controller is not supported right now.
Is there any time-line to have support for HP Smart Array 5i controller?
We are trying to run some fiber gige in a reliable platform. We do need some popular scsi controller support of HP in Mikrotik.
Also, adding DELL and IBM scsi controllers won't hurt.
Thank you.
normis
Wed Oct 27, 2010 8:59 am
All we can do, is include the standard driver. If it doesn't work, we can't do much.
regardtv
Wed Oct 27, 2010 4:55 pm
Hi normis.
Based on a quick count from everyony posting in this thread I'd say the next driver for inclusion should likely be the cciss driver.
I have hardware on hand to test that with.
Regardt
gustkiller
Wed Oct 27, 2010 5:46 pm
as i posted before, o have an hp that should have work with the ciss driver like any other linux, and tested the pre-release version and it did not worked .. doesnt recognize the Virtual drive.
mySYS
Fri Oct 29, 2010 3:46 pm
We have also lots of HP Proliant Servers with Smart Array Controllers inside.
If you need some tryouts or drivertests for the Smart Array Series we can help out with some time and hardware (-:
Today I am at a school with abaout 4500 pupils to implement traffic optimization on base of mikrotik but the server is a DL360 with Smart Array *grrr*
Yours, Martin
gustkiller
Fri Oct 29, 2010 4:04 pm
we too have a lot of ml 350 with smart arrays. now i´m using USB STICK to run mikrotik on it. :(
rveerappan
Fri Nov 12, 2010 7:56 pm
OK, then please consider including cciss driver in your next v5 rc.
djgod
Fri Nov 26, 2010 6:26 pm
HP Smart Array 6i drivers.... pls...
If you haven't drivers includes, include a way that can we add user drivers to MK...
dannyw123xyz
Mon Dec 13, 2010 12:17 pm
I've tried the 5.0rc5 on vmware using both the LSI and Bus Logic SCSI adapters and no luck 'can't find harddisk'. Maybe it doesn't have these drivers in this release. The version you mention above is an earlier beta release. If you think this one has a SCSI adapter please send a link to it and I'll gladly download and test.
Cheers
Danny
weaselll
Mon Feb 21, 2011 1:44 am
5.0rc10 not working on dell poweredge 2650 with megaraid ( hdd not found )
normis
Mon Feb 21, 2011 8:29 am
did it work ever before with RouterOS?
AIVAS
Fri Feb 25, 2011 2:10 pm
Got a Dell PowerEdge 2850 at work, Doesn't understand the Dell PERC 4 card in it. (VID=0x1028, DID=0x0013)
I have a 3 Ware 9650se unit kicking around at work recently, I'll plug it in with a few 80gb hdds and see what it finds. :)
For the record, this server seems to like the 4GB SB stick I used to boot it. :)
trakkasure
Sun Feb 27, 2011 9:40 pm
Is there any thought to iSCSI? Seems it would be less problematic since it's software. And it's a standard. And cheaper overall for an administrator to manage/maintain.
I use a managed array system. So this would be optimal.
It's nice to be able to extend my space as needed, create snapshots if required.. and oh yea.. get the FBI off my back when they have a CALEA request by giving them a snapshot copy off of the array.
crysss
Tue Mar 08, 2011 11:00 pm
so ... mikrotik v5.0 will have scsi support in the end or not ???? or at least for my servers ( dell poweredge 2650 and 2850 ) both with megaraid...
do you know when v5.0 will be finish and stable ???
TNX ... MIKROTIK IS THE BEST! :P
wpeople
Sat Apr 02, 2011 6:31 pm
any news about porting the CCISS driver?
for the the archive: the linux driver is backward compatible to ALL HP SmartArray controller.
There generic driver would work with SA6xx, SA 5i, SA 6i SCSI controller as well as
SA E200(i), P400/P410i.
If the driver is not many years old, it would support also P600 and P800 controllers (however, i'm sure you will not pay that extra fee for a router...)
So, please include the driver (if it's not already included in ROS 5.0). That will allow use to use a refurbished dual-xeon, hot swap HDD, hot swap power supply for few hundred bucks!
ps: what eats few hundred watts...
wpeople
Tue Apr 05, 2011 1:04 pm
HP DL380G3 (SA5i) just tested: netinstall did not found the raid volume
we also tried to net-install to USB drive, worked well (however cannot boot, since BIOS has no option for USB boot (?))
That mean HP DL380G3 completely unusable for Mikrotik (it has no internal power connector for standard devices, so SATA/Flash cannot work)
Chupaka
Tue Apr 05, 2011 2:55 pm
try to install on another computer. I was just setting up a new router, NetInstall didn't see my USB Flash. I connected it to another motherboard, installed there - and then my main platform successfully booted up from that flash. NetInstall uses limited set of drivers
wpeople
Tue Apr 05, 2011 3:08 pm
as i said, install is completed well, but DL380G3 unable to boot from USB (only virtual USB drive via ILO). I will try to boot the installed stick on another box :-)
ps: what if I:
- netinstall the machine to a supported platform
- use Knoppix (or other live system) to mount the rootfs
- copy the x86 binary of the cciss driver (from a same kernel version)
would it boot? maybe someone did it? (what keeps away Mikrotik to make package like binary of common raid drivers?)
Chupaka
Tue Apr 05, 2011 3:15 pm
I mean, install to HDD, not USB Flash
wpeople
Tue Apr 05, 2011 10:10 pm
hmmm... i think, it can load initrd, but without ccisss driver cannot mount the rootfs
i will give a try for install to desktop PC (ide/sata), and dd over network to server by live linux.
would report the results :-)
EMOziko
Fri May 13, 2011 9:01 am
anybody tried install routeros on SCSI SCA80 drives?
We want new versions of The Dude!!!!!!!
method
Fri Jul 29, 2011 9:39 pm
Can anybody can add driver for dell PE1750, old and popular scsi controller.
Or maybe someone knew how to install mikrotik on this server ????
Please help.
antoniogc
Tue Aug 23, 2011 10:31 am
Good morning, you can install RouterOS on an HP RAID Controller onboard 5i SmartArray and DELL POWEREDGE 2650, a greeting.
wpeople
Tue Aug 23, 2011 3:18 pm
to a HP SmartArray 5i? how?
trol4o
Wed Aug 31, 2011 2:14 pm
+1 to cciss (HP Smart Array)
By the way, I've found a way to boot from USB on servers that doesn't support it - like HP G3. You have to create a custom boot manager on CD, which boots USB drive afterwards - it sound complicated, but really isn't - I have several of those servers running without any problems.
By the way, when Radius server (with Userman) is run from USB drive, there are many problems - timeouts and so on. Which is one of the reasons we desperately need cciss drivers. Please at least announce your intentions - will such a driver be available at some point in time or not.
JJX
Tue Sep 06, 2011 9:53 am
I have Dell PowerEdge 850 and I get also error "FATAL ERROR: no harddrives found" while installing mikrotik 4.17
wpeople
Wed Sep 21, 2011 1:41 pm
jjx: try to install ROS5 (preferably latest)
trol4o: HP G3 cannot boot from USB. (BIOS not support is) yes, it can be booted from CD (and from CD, probably USB drive can be asked for boot as rootfs) but, i think
it does not worth the work (and have many additional failure points, like CD and USB).
I've just take some math, and if you need to pay for power, it's much better to have a brand new intel 1U server, that have a G3 server. (intel entry servers eats 1/3 of the power as HP G3 servers - and i think double CPU power, even with core i3)
trol4o
Wed Sep 21, 2011 3:00 pm
wpeople:
I don't have to pay for power anywhere, so G3 is a good choice. About booting from CD, then USB - it's very simple once you get the hang of it, I've prepared an ISO image for that task, simply burn it to CD and off it goes.
Anyway, the only time the CD is used is at boot time. I have several of those servers working for a long time and never had any problems.
Still waiting for SCSI driver though :)
hugosantos
Wed Oct 05, 2011 9:32 pm
Dear
PorwerEdge bought a Dell R710 with the following settings:
-01 Intel ® Xeon ® 5500 series Dual Core;
- Intel-5520;
- PERC 6i RAID Controller and SAS 6/iR;
-02 SAS HDD 250GB 1500rpm in RAID 1;
-Memory-8GB DDR3-1333;
-Card-Network Interface Broadcom ® NetXtreme ® II 57.711 two-door, direct connection, 10 Gbit Ethernet and PCI-Express and flush iSCSI TOE
But when trying to install the new RouterOS v5.7 Stable during the installation of the error: "FATAL ERROR: No hard disk"
We are very concerned because this router is the edge of our network, and have millions of customers who are depending on this change.
We are customers for a long time and ask the MikroTik verify that an immediate solution to this problem.
Here you can find models of controllers used by Dell in order to streamline the process for the new update with the correctness of the MikroTik:
http://www.dell.com/content/topics/topi ... =en&cs=555
Does anyone have any suggestions of what can be done? Ja I disabled the RAID setup Dell put the same error persists.
Please help me! :(
Chupaka
Thu Oct 06, 2011 3:42 pm
try to install ROS on another machine, then boot ready system on this platform
Nick Kett
Thu Oct 27, 2011 4:13 pm
Befor I splash out to buy some surplus Dell PowerEdge 1850 with 2 x 146GB SCSI Hard Drives and Integrated Raid (PERC4) with 256mb Cache, does anyone know if ROS is likley to see the drives?
Also if the GigEther drivers will allow L2MTUs greater than 1500 ?
csickles
Thu Nov 03, 2011 6:30 am
HP DL360 G4p works great....
Keep in mind this is a SATA model... so,,,,
But it sees the onboard NICs and hardware just fine....
I added a 2nd supply and CPU and a 4 port broadcom 64Bit PCI and it is stable as a rock...
These are inexpensive and not too hard to find...
Craig
tokr
Mon Nov 21, 2011 5:27 pm
Please, will support SAS 1068 (LSI) - in Dell M610?
Thanks Tom
markom
Fri Dec 23, 2011 4:31 pm
Is there any chance for adding support for Inter raid and Adaptec raid. I have just install MtOS 5.11 on supermicro ATOM based and it have both Inter and Adaptec raid on but I cannot use it because mikrotik does not recognize raid volume.
it would be great to have 2 SAS disks on raid for security reasons
tapalcapo
Mon Mar 26, 2012 4:45 am
I tried to install version 5.14 on my Dell PowerEdge R610.
Try installing from CD-ROM.
Try to install via USB.
Try installing using NetInstall.
In all these ways failed to install the system.
Remove the HD I put in a common PC, install the system and when I put the HD in my DELL R610 system remains in "LOADING".
Install version 5.11 and is equal, the system remains in "LOADING".
Any suggestions?
tapalcapo
Mon Mar 26, 2012 5:45 am
I installed the system on a Flash Memory (USB) and the place my DELL R610, boot and OS system: rip well but does not detect the disks but if you see the Dell SAS controller.
If I do the same with the HD system will not boot, stays in LOADING.
Attachment system images installed on USB flash memory in the Dell R610.
plentyofbug
Fri Feb 13, 2015 1:36 am
For god sake please make an x86 driver for intel C202 chipset, thanks!
IntrusDave
Fri Feb 13, 2015 3:24 am
I would agree with the megaraid.. I would say that 8 out of 10 servers that I order or build include an LSI controller.
On that note, most of them are being deployed for VMWare ESXi now. It makes management MUCH simpler and makes better use of resources. I would personally like to see the RouterOS for x86 have a vmware tools package before SAS/SCSI support.
David Joyce
Network & Security Engineer
Intrus Technologies, LLC.
Rancho Cucamonga, CA, USA
didito
Thu May 21, 2015 1:37 am
Hello mikrotik has support for PERC h330 SAS?
Users browsing this forum: Google [Bot], Guscht and 136 guests
