ZamNam
limiting the number of udp sessions
Thu Feb 18, 2010 5:21 pm
how can i limit the number of udp session for a specific ip address or mac address in the firewall filter ?
thank u in advance
Chupaka
Re: limiting the number of udp sessions
Thu Feb 18, 2010 5:30 pm
yep, it it possible to expand 'connection-limit' firewall matcher to non-tcp connections?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
fewi
Thu Feb 18, 2010 5:53 pm
[admin@MikroTik] > /ip firewall filter
[admin@MikroTik] /ip firewall filter> add chain=forward src-address=10.1.0.1 protocol=udp connection-limit=11,32 action=drop
failure: connection limit works only with tcp
Nope. connection-limit only works with TCP.
Chupaka
Thu Feb 18, 2010 6:40 pm
MT Staff?..
cartes
Sat Feb 20, 2010 11:13 pm
UDP is a connection-less protocol, meaning there is no concept of "connection", and therefore, "connection-limit" cannot be applied.
Chupaka
Sun Feb 21, 2010 1:08 am
sure. but we can see udp 'connections' in Firewall Connections. why can't we limit by number of such 'streams'? also, you NAT whole udp 'connection', not every packet of it - so there ARE concept of 'udp connection' in RouterOS =)
angboontiong
Fri Jun 01, 2012 1:39 pm
Hi...
any news about this?
thanks...
mrz
Fri Jun 01, 2012 1:53 pm
Starting already from v5.7 connection-limit can be used to limit other protocols, too.
angboontiong
Fri Jun 01, 2012 6:08 pm
let say we set the limit to 20 session, but on the connection we can see the testing ip just running on 10 tcp connection...
we try the connection limit, it will effect the services like youtube even just under 10 tcp session...
am i doing the wrong thing?
and, would you mind to provide wiki link for reference...
thanks...
Benik3
Sun Oct 13, 2013 8:50 pm
So this should work?
chain=forward action=add-src-to-address-list p2p=all-p2p connection-state=new protocol=udp
     address-list=UDP over limit address-list-timeout=0s connection-limit=100,32
Chupaka
Mon Oct 14, 2013 5:39 pm
yes
Users browsing this forum: Bing [Bot] and 113 guests
