Hellbound
Long time Member
Long time Member
Prepaid card - automatic expiration.
Thu Jul 28, 2005 8:20 pm
hi guys.
I want to print monthly access prepaid card which will only expire one month after the first login.
how to do that?
thanks
ofasa
Fri Jul 29, 2005 1:01 am
RADIUS
Hellbound
Long time Member
Long time Member
Fri Jul 29, 2005 1:26 am
is there anyway to do that without radius? I can't afford another server on network,
thanks
normis
Fri Jul 29, 2005 9:20 am
hotspot manager online service: http://www.mikrotik.com/download.html#hotspot
it is free and very useful.
Hellbound
Long time Member
Long time Member
Fri Jul 29, 2005 11:30 am
so it is not actually possible to do so with version 2.8 or 2.9? without additional software and server, and I've notice hotspot manager needs radius? or how exactly does it work?
savage
Fri Jul 29, 2005 11:58 am
Mikrotik is a router, not a authentication server. It's only normal that MT would not support this.
Regards,
Chris
normis
Fri Jul 29, 2005 12:03 pm
@Hellbound
wait! wrong. you only need to set up your router to connect to the `hotspot manager`. it IS a radius, you don't need anything else. just create an account on the hotspot manager and start using it, you don't need anything else.
Hellbound
Long time Member
Long time Member
Fri Jul 29, 2005 12:05 pm
and where exactly hotspot manager installed? on mikrotik.com?
normis
Fri Jul 29, 2005 12:06 pm
yes. it is an online service, you log in, connect to your router, add your users and start controlling them and gathering statistics.
Users browsing this forum: andersonv, Bing [Bot], Josephchimi and 40 guests
