conjurer
New x86 instalation, how is better?
Tue Mar 02, 2010 11:13 am
i am going to install routerOs on usb flash.
I want to put in in production machine. So i am wondering, if routerOs install depends on hardware that i am instaling on?
Will there be a diffenrence if i:
install it on production machine from cd, or
make netiinstall on from any other computer?
AFAIK windows adaptes to hardware (multiprocesor/single procesor), when instaling, and i think same thing (selects modules to load on boot).
Chupaka
Re: New x86 instalation, how is better?
Tue Mar 02, 2010 8:35 pm
you can install it on any machine. if another machine's parts are not supported, then they are unsupported at all
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
gmsmstr
Trainer
Trainer
Wed Mar 03, 2010 12:49 am
There is a supported hardware list. That includes Supported and Tested solutions. so you don't have to just hope, you can purchase a unit, pull it out of the box, plug it in the rack and start configuration. That it. We make some at http://www.mikrotikrouter.com, but it is also listed on the supported hardware list.
Dennis Burgess, MCTCE, MTCNA, MCTCTE, MTCWE, MTCNIE, A+, N+, MCP, MTCSE Mikrotik Certified Consultant / Trainer
Need Mikrotik Support: http://www.linktechs.net -- Link Technologies, Inc.
-- Author of "Learn RouterOS: Second Edition"
conjurer
Wed Mar 10, 2010 10:43 am
Thanks for answers.
I have allready tested ROS with my hardware. It ran as fast as debian, so now i am with debian, ant the hardware is in production. So i want to install ROS to flash drive on other system, with older procesor.
SO i was wondering if ROS instaler makes any optimizations depending on hardware.
For example when you compile linux kernel you can specify procesor type, and additional x86 features.
janisk
Wed Mar 10, 2010 10:54 am
no, nothing that specific. Autoconfiguration will make everything you need, even if you move the storage medium to other hardware. (just check if everything is ok with license, or install without license, fire up your machine and then add license to the installation.
conjurer
Wed Mar 17, 2010 3:58 pm
So autoconfiguration takes place everytime system boots? Or only after install?
Users browsing this forum: sheo3e and 88 guests
