200120022003
PPTP dialup with specify interface (WAN)
Mon Mar 08, 2010 10:17 am
Router OS machine:
59.149.208.152 (Wan01)
59.149.208.153 (Wan02)
59.149.208.154 (Wan03)
Remote VPN machine:
202.14.67.4 (PPTP Server)
I want to dial up 3 VPN connection to 202.14.67.4 with specifty interface.
E.g. Wan01 -> 202.14.67.4 & Wan02 -> 202.14.67.4 & Wan03 -> 202.14.67.4
How can I do that ? Thank you !
Old Message
How can I dial up a PPTP Client with specify interface ?
I am using RB450G and 3.25 router os, thank you !
Some people suggest me to use ip route to select the interface.
I have 3 WAN and dialup 3 VPN separately to one VPN Server.
So, the suggestion is not work, any one can help me ?
200120022003
200120022003
Re: PPTP dialup with specify interface (WAN)
Mon Mar 08, 2010 4:09 pm
Can anyone help me , thank you ~
NAB
Trainer
Trainer
Mon Mar 08, 2010 9:39 pm
Sorry, but you simply haven't given enough information for anybody to be able to help you.
dog
Mon Mar 08, 2010 10:12 pm
I suppose he has 3 internet connections to the same ISP and in order to get WAN access he needs to dial in via PPTP but has to make sure that each PPTP client uses a specified connection.
200120022003
Tue Mar 09, 2010 8:30 am
Yes.
Router OS machine:
Remote VPN machine:
Chupaka
Sun Mar 14, 2010 1:25 pm
unfortunately, it's not possible in current version
you may write to support and ask for a possibility to select source address of pptp client (like Update Source in BGP Peers, etc). then you will be able to use Policy Routing to select appropriate route based on source address
for now, you should use three different routers (KVM virtualization? :) )
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
sergeyklenov
Wed Nov 04, 2015 4:44 pm
Any news with this topic?
Users browsing this forum: Bing [Bot], Google [Bot] and 47 guests
