stek
OpenVPN in server mode ??
Tue Mar 09, 2010 11:51 am
I can read on the wiki (http://wiki.mikrotik.com/wiki/OpenVPN), that OpenVPN is not supported in server mode (multi client to server).
I tried out and I'm able to connect more RB-client to one RB-server with OpenVPN.
Then, I'm asking: is the wiki incorrect ? or what?
Regards
Stefano
mrz
Re: OpenVPN in server mode ??
Tue Mar 09, 2010 12:33 pm
There is definitely a mistake. You can connect more than one client to OVPN server.
stek
Tue Mar 09, 2010 12:41 pm
Ok, then there is a mistake in the MUM presentation:
VPN technology: IPsec, OpenVPN, PPTP - which is better? by Pawel Cieplinski
(AkademiaWIFI.pl, Poland)
http://mum.mikrotik.com/presentations/P ... ademia.pdf
regards
Stefano
normis
Tue Mar 09, 2010 12:42 pm
That presentation is about OpenVPN in general. In RouterOS it does support this mode.
stek
Tue Mar 09, 2010 12:45 pm
Now I'm really confused!
Is supported or not?
and what is not supported?
Stefano
normis
Tue Mar 09, 2010 12:46 pm
stek
Tue Mar 09, 2010 12:49 pm
The presentation is saying that OpenVPN on MT dosen't support server mode, exactly like writted in the wiki.
But forunately is a mistake!!
Stefano
normis
Tue Mar 09, 2010 12:50 pm
apparently this person took the information from wiki, we will notify him of his mistake, thanks for pointing it out.
cieplik206
Trainer
Trainer
Tue Mar 09, 2010 2:08 pm
Hello
In this case it is a mistake then. I have to confess that my experience in OpenVPN in RouterOS is poor, but in general I implemented few times OpenVPN on Debian / OpenWRT. My Goal was to talk about VPN in general. I took information from WIKI as granted without verification. Thank you for your comment.
Pawel Cieplinski
https://www.wispcasts.com - Mikrotik Video Tutorials.
The best place where you can improve your skills!
Facebook - F/wispcasts
Twitter - @wispcasts
duvi
Tue Mar 09, 2010 2:19 pm
Are you sure about this?
I have one rb running ovpn-server, and 2, sometimes 3-4 ovpn client rbs connecting to it at the same time.
normis
Tue Mar 09, 2010 2:20 pm
did you read the rest of the discussion, particularly the post above yours?
roadracer96
Forum Veteran
Forum Veteran
Tue Mar 09, 2010 2:32 pm
Right now there are 84 ovpn connections to my RB1000.
Yes, it works.
stek
Tue Mar 09, 2010 3:30 pm
ok,
many tnks
Stefano
jschulze
Tue Mar 09, 2010 6:10 pm
Roadracer,
would you care to share your config ? We currently have 50 tunnels (OpenVPN) to a RB1000, but the RB1000 does not manage to stay alive for longer then a day or 2 and then it crashes. This has been turned into a support call for Mikrotik who seem to think there is a memory leak. I wonder what your uptime is ?
roadracer96
Forum Veteran
Forum Veteran
Tue Mar 09, 2010 9:16 pm
I had the same problem and had a support ticket open with MT support. I think I figured it out, though. try changing the profile to "only-one=no"
I think the server was colliding with itself when assigning IPs to clients if they disconnected and reconnected before openvpn realized they were gone. Since I changed this, I havent had a lockup. I was having it happen at LEAST weekly, normally ever 2-3 days, and sometimes twice/day. Right now, I am at 10 days since the last restart and that restart was an accident (didnt pay attention to what router I was in). So it has been 14ish days since I have seen it happen.
I use 2048bit certs for every client, require client cert, clients are a /32 point to point link, server address for every client is the same. AES-128 w/ SHA.
Here is the profile I use for 82 of the 86 connections:
/ppp profile
add change-tcp-mss=no comment="" local-address=10.16.128.1 name=Customer \
only-one=no use-compression=no use-encryption=required \
use-vj-compression=no
/interface ovpn-server server
set auth=sha1 certificate=fw-1 cipher=aes128,aes192,aes256 default-profile=\
Customer enabled=yes keepalive-timeout=60 mac-address=FE:1D:10:11:78:AB \
max-mtu=1500 mode=ip netmask=32 port=1194 require-client-certificate=yes
clients are authenticated via RADIUS to a FreeRADIUS server w/ MySQL backend behind the RB1000.
Like I said, Im at almost 10 days of uptime right now and ~100gb of traffic has traversed the firewall. RouterOS v4.5
Users browsing this forum: sindy, UpRunTech and 94 guests
