as7aab
how I can configure openVpn client
Sun Mar 21, 2010 8:56 pm
because I have account on strongvpn.com website and they give me setting to connect it is call openvpn program and config file
how I can use this setting on Mikrotik
Note: I have five files in the config folder 2 with crt extension and 2 files with .key extension and one with .ovpn extension and all of this five files is require to connect
I have paid copy for mikrotik level 6 ver 3.23
and this a screen shoot for the router os
thank you
as7aab
Re: how I can configure openVpn client
Mon Mar 22, 2010 5:31 pm
up :(
normis
Tue Mar 23, 2010 9:03 am
as you see with the color red, you need to specify WHERE TO connect.
as7aab
Wed Mar 24, 2010 3:06 am
I know the Ip that I need to connect to but the problem is that I have 2 files in the vpn config with .crt extension but mikrotik have just one field for certificate
also where I can use the other 2 .key files
conclusion: I have this four files and I do not know where I can put them
1- XX.crt is the certificate authority
2- XX.crt - my client certificate
3- XX.key - my private key
4- XX.key is tls-auth key
I uploaded the files to server by ftp but where I can setup them
and the mikrotik setting what is AUTH and cipher is it keys files
thank you normis
as7aab
Wed Mar 24, 2010 3:08 am
I had update the router OS to the latest ver but it is still the same !
roadracer96
Forum Veteran
Forum Veteran
Wed Mar 24, 2010 4:30 am
Import your CA certificate into the client
import your client certificate into the client
import your client private key into the client. Should end up with a "KR" next to it, use this certificate when connecting.
OpenVPN doesnt support TLS auth keys in MT for some reason.
bigguns
Sun Oct 17, 2010 10:13 pm
Did you ever manage to get this working? I'm getting stuck.
Users browsing this forum: Google [Bot], RoyAlbinus and 128 guests
