MrIC
have problem on routerboard 750G help please
Fri Mar 26, 2010 4:49 pm
hello there
i just got new routerboard 750g
it was have routeros ver 3.31 so i tried to update it to 4.6
i downloaded the file from mikrotik website then i uploaded it to files and restarted the routerboaed
then i can't get dhcp ip and can't login into routerboard with mac or ip " winbox can't find any routerboard attached "
so can someone help me in this ?
thanks in advance
BTW : that's not the first RB750G i got i have 3 routerboards all of them works fine
nickshore
Re: have problem on routerboard 750G help please
Fri Mar 26, 2010 5:03 pm
Trying using netinstall to install it again, you have to press the reset switch as it boots.
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
MrIC
Fri Mar 26, 2010 5:30 pm
but i think that netinstall will remove the old key and i will need a new key , is that right ?
" sorry but i didn't used netinstall before "
GuJack20
Trainer
Trainer
Sat Mar 27, 2010 7:46 pm
No problem for the key. It is a Routerboard so it will have the key.
Your problem, maybe its something that has to do with the version 4.6 i don't know but don't always hurry to install the latest version. What do you need from the v.4.6 that the v.3.31 does not have??
--Do you remember that guy who gave up? Neither does anybody else!
MrIC
Sun Mar 28, 2010 6:14 pm
thank u i used netinstall and everything works fine
Users browsing this forum: Google [Bot] and 75 guests
