normis
RouterOS 5 beta
Thu Apr 01, 2010 7:40 am
To test early preview of Webfig, open browser at the address http://ROUTER_IP/webfig/
(use the trailing slash).
What's new in 5.0beta1 (2010-Mar-31 10:36):
*) updated drivers and kernel (to linux-2.6.32.5);
*) ssh is now completely rewritten (supports connection forwarding, only DSA keys);
*) added support for SSTP protocol (PPP over TLS);
*) added support for multiple Intel Ethernet cards;
*) added support for IPv6 over PPP
(enabled by default if ipv6 package is installed),
link-local addresses are assigned, and server can issue IPv6 global prefixes
to clients per ppp secret or RADIUS reply (Framed-IPv6-Prefix);
*) added proper support for MPLS over PPP (by default it is now disabled);
*) fixed RB800 temperature;
*) silentboot feature updated;
*) WinBox - any file dropped on WinBox will be uploaded to router;
*) multicast - fixed possible crash during PIM startup;
*) report platform name in "/sysrem resource";
*) fixed problem - vlans were not working on RB750 ether1;
*) fixed mac address handling on RB750, some specific arp requests did not work;
*) more than two dns servers allowed in /ip dns;
*) sniffer and torch could process packet from other interfaces;
*) ospf - fixed DR and BDR election;
*) ospf - changed "/routing ospf route" to show type 2 metric instead of
internal metric for type 2 external routes;
*) added IPv6 support to trafflow (v9 only);
*) rewritten user-manager (formerly known as userman-test);
rpingar
Long time Member
Long time Member
Re: RouterOS 5 beta
Thu Apr 01, 2010 9:44 am
tested on a N link,
no improvment on nstreme and N.
Ros
hedele
Re: RouterOS 5 beta
Thu Apr 01, 2010 10:10 am
Somehow USB does not seem to be working with 5.0 beta 1 on a RB433 UAH.
It doesn't matter which device i plug in (modem, flash disk, ...) it is not recognized in system resources usb, and umts modems also don't generate a serial port and ppp client.
So, is it possible that USB is completely broken in 5.0 beta1?
normis
Re: RouterOS 5 beta
Thu Apr 01, 2010 10:20 am
it doesn't show in resources, but it should work in ppp
hedele
Re: RouterOS 5 beta
Thu Apr 01, 2010 10:27 am
But how should i configure a ppp client if I don't have a usb serial port?
normis
Re: RouterOS 5 beta
Thu Apr 01, 2010 10:31 am
send supout.rif file to support please
hedele
Re: RouterOS 5 beta
Thu Apr 01, 2010 10:35 am
Did that a few minutes ago, should already be in your ticketing system :)
Additional info:
I just did an upgrade from 4.5 to 5.0 beta1 with the usb modem attached during the upgrade.
after 5.0 beta1 boots up, the usb serial port is still recognized and working.
if i unplug/replug the usb modem, the serial port is not recognized anymore, and reboots do not fix it.
normis
Re: RouterOS 5 beta
Thu Apr 01, 2010 10:38 am
modem could be missing because of a driver change, but USB disks should definitely work
hedele
Re: RouterOS 5 beta
Thu Apr 01, 2010 10:45 am
OK i just tried another usb flash stick and it works.
well, maybe the other one is broken.
I think the modem driver is still working, because if I upgrade from 4.5 to 5.0 and the modem is connected, it works normally after the upgrade until I unplug it for the first time, afterwards it is no longer recognized. well, maybe some strange hotplug issue...
uldis
Re: RouterOS 5 beta
Thu Apr 01, 2010 10:47 am
The first flash drive worked in v4.x? If yrs, then plug it in the v5 and make the support output file and send it to us. Maybe you have a support output file from v4.x where that flash drive was working?
About the usb modem, after remover try to delete the port and reboot the device and check again. We will look into that issue.
hedele
Re: RouterOS 5 beta
Thu Apr 01, 2010 10:59 am
Hi uldis,
no the first flash drive is now not working anywhere :)
Seems like a strange coincidence but it really looks broken now.
deleting the usb ports and rebooting does not bring the usb ports back by the way.
if you want, I can give you remote access to one of my RB433 until tomorrow, tomorrow I need to install it at a customer :)
NetworkPro
Re: RouterOS 5 beta
Thu Apr 01, 2010 11:52 am
When I open WebFig it just sais
WebFig Beta
and nothing happens?
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
normis
Re: RouterOS 5 beta
Thu Apr 01, 2010 11:54 am
1. don't forget the trailing slash
2. wait ...
NetworkPro
Re: RouterOS 5 beta
Thu Apr 01, 2010 1:48 pm
OK I'm in. The #<age>#, #<script># etc stuff is not working but you know that already...
Its a little sluggish. I like the original WinBox when it works really fast so I can do my job lightning fast and I can feel how fast it is, you know?
normis
Re: RouterOS 5 beta
Thu Apr 01, 2010 1:51 pm
things in #red# don't work yet, it's an early preview.
NetworkPro
Re: RouterOS 5 beta
Thu Apr 01, 2010 1:58 pm
It doesnt work with HTTPS it just reloads, I need to config everything securely since a lot of radio links are sniffable etc.
NetworkPro
Re: RouterOS 5 beta
Thu Apr 01, 2010 4:18 pm
Install in VMWare (latest) from ISO stops at this screen: Image and keyboard capslock light just blinks.
P.S. - same halt with Sun VirtualBox :lol:
lol :)
compctech
Re: RouterOS 5 beta
Thu Apr 01, 2010 5:06 pm
Having same issues as NetworkPro is having with VMWare. Tried on 3 different systems with the ISO for x86. Is this a know issue?
Regards,
Compctech
fremd
Re: RouterOS 5 beta
Thu Apr 01, 2010 6:38 pm
PPP Secrets and PPP Active don't work in webfig :( It's say "Cannot call method 'toString' of undefined"
0ldman
Re: RouterOS 5 beta
Thu Apr 01, 2010 10:56 pm
R52NH 433 AP, R52N 411 client.
Changing the AP to 10MHz or 5MHz mode apparently doesn't change the channel width. The CPE associates just fine without changing channel width and continues to move too much data for half and quarter channel.
sserdarb
Re: RouterOS 5 beta
Thu Apr 01, 2010 11:41 pm
Hi, I'm new in forum. I see the v5 update and i updated my level4 licensed crossroads with v5 remotely and now i can't reach my routerboard i can't ping it from modem but i can see its signal but can't connect so what can i do reouterboard is 300km far away from me:( thanks.
fewi
Re: RouterOS 5 beta
Thu Apr 01, 2010 11:49 pm
MAC telnet, if you have something that connects to it layer 2 that you can reach. Otherwise it sounds like it's serial cable time.
I don't think it's a good idea to put the first public beta of a completely new release on something that you don't consider the equivalent of a lab device.
NetworkPro
Re: RouterOS 5 beta
Fri Apr 02, 2010 12:11 am
I put it on production routers some times so when the final is out - I know for 100% that it would work. And if it fails - I go and downgrade. But its a beta and not an alpha so it should be not so bad. It should work on 95% or more of the routers...
sserdarb
Re: RouterOS 5 beta
Fri Apr 02, 2010 1:00 am
I think i am hurried up too much:( i find the problem by connecting it my other routerboard remotely and now i can connect by mac telnet i see that ether 1 is not working with v5 on crossroads so now i am trying to downgrade my routerboard my knowledge is limited so i can't find an other way now there is no ip of routerboard i can't enable ip's on address's tab is there any easy way correcting this problem.
glenno
Re: RouterOS 5 beta
Fri Apr 02, 2010 3:46 am
No issues with Vmware for me. Ive run 4.6, the first 5.0beta1, and the latest 5.0beta1 on Vmware Player 3.01 build227600 on 64 bit Ubuntu 9.10.
srecko
Re: RouterOS 5 beta
Fri Apr 02, 2010 2:33 pm
I am trying to install Mikrotik 5.beta on three different PCs. For everyone coming to the freezing of the installation. Two PC are AMD and one Intel.
NetworkPro
Re: RouterOS 5 beta
Fri Apr 02, 2010 4:55 pm
So big deal. Use NetInstall or first 4.6 and then update :) Thanks for reporting.
NetworkPro
Re: RouterOS 5 beta
Sun Apr 04, 2010 12:00 am
v5b1 WinBox: Remove the 1Gbps option from interfaces when the interface does not support it.
Also, on RB450G, it was selected 100Mbits but the status showed 1Gbps. So this speed setting does nothing? Maybe its because Auto negotiation was turned on. But then it should be a fourth radio (circle with dot) button instead of a checkbox. Hah. Hahaha.
Helios
Re: RouterOS 5 beta
Sun Apr 04, 2010 9:36 pm
Problem with sequence Netflow not fixed in 5.01 beta ((
martini
Re: RouterOS 5 beta
Tue Apr 06, 2010 4:27 pm
yes, netflow not fixed
mahnet
Long time Member
Long time Member
Re: RouterOS 5 beta
Tue Apr 06, 2010 6:18 pm
Do we have the Virtual AP fixed in ROS 5 beta
NetworkPro
Re: RouterOS 5 beta
Thu Apr 08, 2010 10:55 am
Something weird is happening when I try to use the mac-scan tool and maybe the ip scan tool and maybe both at the same time. I can't re-test right now to be more exact and more sure, but if someone can test - he should.
martini
Re: RouterOS 5 beta
Thu Apr 08, 2010 8:58 pm
uncheck "autonegatiaton" and router use your selected settings - 100 MB or 1GB
NetworkPro
Re: RouterOS 5 beta
Thu Apr 08, 2010 10:56 pm
I know. My post should be a reminder to the sowftare designer(s) that teh GUI can be improved from a point of being not-logical to a point of being at least logical. And further but thats true for everything.
NetworkPro
Re: RouterOS 5 beta
Sat Apr 10, 2010 11:21 pm
FAILED MISERABLY WITH
Ethernet NIC "82557/8/9/0/1 Ethernet Pro 100 (rev: 8)"
very bad
p.s. good thing we had a spare Realtek in the machine + a person to switch the cable + a backup route to get in with SSH to change the config to the Realtek.
1 device="02:08.0" name="82557/8/9/0/1 Ethernet Pro 100 (rev: 8)"
vendor="Intel Corporation" category="Ethernet controller"
vendor-id="0x8086" device-id="0x1229" irq=10
memory=0xFF7FE000-0xFF7FEFFF,0xFF600000-0xFF8FFFFF io=0xD8C0-0xD8FF
NetworkPro
Re: RouterOS 5 beta
Sat Apr 10, 2010 11:47 pm
SSH client shows stuff from waaay-before when I scroll up the windows to see the past commands. This means that the last command output is missing and in its place there is stuff from 15 mins ago.
Chupaka
Re: RouterOS 5 beta
Sun Apr 11, 2010 3:34 am
http://forum.mikrotik.com/viewtopic.php ... 46#p200446
http://forum.mikrotik.com/viewtopic.php ... 81#p200481
for now, it's not a problem. it's 'it works as expected by the developer' :(
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
NetworkPro
Re: RouterOS 5 beta
Sun Apr 11, 2010 6:44 am
User Manager has lost the names of the Profiles. This was an upgrade from 3.30 to 5b1. Im not sure about the actual names but the profile drop list shows no names. Just empty space that I click with the mouse and select.
NetworkPro
Re: RouterOS 5 beta
Sun Apr 11, 2010 7:51 am
@ MT HQ they probably alredy know all these :)
But anyway:
UPnP "Show dummy rule" does not switch off the dummy rules.
marlow
Re: RouterOS 5 beta
Sun Apr 11, 2010 1:00 pm
You are aware, that you should be raising tickets with support@mikrotik.com for the bugs in 5.0beta1 ? Posting them here won't get them fixed.
/M
Communication is the beginning of understanding
-- AT&T
NetworkPro
Re: RouterOS 5 beta
Sun Apr 11, 2010 1:29 pm
It is still possible that a MT guy raises a ticket himself after seeing it here and testing it for himself. Normis checks the forums out often enough. I should send to the email but I am completely overwhelmed with work and so ... Besides, when people see the v5b1 weaknessess they could decide to test it themselves and therefore discover even more bugs, thats why I like the forums and to be open about it all.
lukic
Re: RouterOS 5 beta
Sun Apr 11, 2010 1:53 pm
I think, in 5.0beta1 is somehow broken dhcp-server. When i reboot, it is shown red in winbox and not working. Disable/reenable put it in a working order until next reboot. When downgraded to 4.6 everything worked. I tried to reset config and reconfigure whole router in 5.0beta, but it didn't helped..
here is export config:
add add-arp=yes address-pool=pool1 authoritative=after-2sec-delay \
bootp-support=dynamic disabled=no interface=bridge1 lease-time=3d name=\
dhcp1
/ip dhcp-server config
set store-leases-disk=5m
add address=10.12.0.0/22 comment="" dns-server=10.1.2.192,10.32.0.5 domain=\
mag-net.sk gateway=10.12.3.254 netmask=22 wins-server=10.1.2.192
add address=10.12.20.0/22 comment="" dns-server=10.1.2.192,10.32.0.5 domain=\
mag-net.sk gateway=10.12.23.254 netmask=22 wins-server=10.1.2.192
add address=10.12.0.128/24 broadcast=10.12.0.255 comment="" disabled=no \
interface=bridge1 network=10.12.0.0
add address=10.11.0.130/24 broadcast=10.11.0.255 comment="" disabled=yes \
interface=wlan2-link network=10.11.0.0
add address=10.12.4.254/24 broadcast=10.12.4.255 comment="" disabled=no \
interface=bridge1 network=10.12.4.0
add address=10.12.23.254/22 broadcast=10.12.23.255 comment="" disabled=no \
interface=bridge1 network=10.12.20.0
do you see any logical problem here?
NetworkPro
Re: RouterOS 5 beta
Sun Apr 11, 2010 2:14 pm
My DHCP servers are working but they dont have add arp
I see you have /22 and so on - check the addresses with a subnet calc again just to be sure :)
I just discovered that in User Manager it does not count the Active Sessions right. What are those supposed to be anyway? For example one RB450G had earlierl 4 A Users and 0 A Sessions (after db rebuild and logoff and logon). And another x86 had them right. Aha I got it - when logged in with a "Customer" with Full (as opposed to owner) privileges - current number of A Sessions do not show (show as 0).
I need my "Customers" with Full privileges to see the number of A Sessions.
By the way, when I add users through the console, I need to logout and relogon to see them in usermanager web interface?
marlow
Re: RouterOS 5 beta
Sun Apr 11, 2010 2:18 pm
He interacts with people here, correct. He will not raise the ticket for you.
/M
-- AT&T
NetworkPro
Re: RouterOS 5 beta
Sun Apr 11, 2010 2:29 pm
How do you know he will not ? :) Why do you say "for me" its not for me :) it's for their profit out of their product :)
p.s. the tickets via email has a purpouse of getting a supout and keeping a track of users via their email. MT dont need these to check the beta and fix it.
marlow
Re: RouterOS 5 beta
Sun Apr 11, 2010 2:37 pm
Because if you check his posts around the forum, he always asks people to raise the ticket with support@mikrotik.com, as most of the developers don't read this forum and I know from experience, that posting here doesn't get bugs fixed.
Posting here only helps you establishing an issue by interacting with other Mikrotik users.
/M
-- AT&T
NetworkPro
Re: RouterOS 5 beta
Sun Apr 11, 2010 2:51 pm
OK then these bugs will remain in final release. I dont have time to send the email :)
NetworkPro
Re: RouterOS 5 beta
Sun Apr 11, 2010 10:57 pm
With User Manager one "Customer" login name can used from one location at a time, otherwise - erros occur...
martini
Re: RouterOS 5 beta
Tue Apr 13, 2010 11:21 am
Anybody have working PCQ shaping on v5 beta ??
In setup with packet mark and PCQ traffic dont shaping, but if i choose any other queue type (ethernet default or wireless) - shaping start to work
NetworkPro
Re: RouterOS 5 beta
Tue Apr 13, 2010 12:08 pm
It seems working here. Nobody has phoned to complain and the PCQ counters are moving etc etc. I can see it in WinBox that stuff is as normal .. ?
martini
Re: RouterOS 5 beta
Tue Apr 13, 2010 1:42 pm
yes, PCQ counters are moving, and queue counters moving, but traffic does not shaping, but if i downgrade to 4.6 (without any other config change) - alll start to work
roadracer96
Forum Veteran
Forum Veteran
Re: RouterOS 5 beta
Tue Apr 13, 2010 6:45 pm
Any word on when the SSTP client in MT is going to be operational?
mrz
Re: RouterOS 5 beta
Wed Apr 14, 2010 9:36 am
What problems exactly do you have with SSTP client? Did you contacted support about that problem?
NetworkPro
Re: RouterOS 5 beta
Wed Apr 14, 2010 3:30 pm
Mangle action jump does not work, stays Invalid even after the chain has one rule. (prerouting)
roadracer96
Forum Veteran
Forum Veteran
Re: RouterOS 5 beta
Wed Apr 14, 2010 5:39 pm
No, because you are already aware of it...
http://forum.mikrotik.com/viewtopic.php?f=1&t=40535
Chupaka
Re: RouterOS 5 beta
Wed Apr 14, 2010 5:51 pm
and the answer is right there =)
edmidor
Re: RouterOS 5 beta
Wed Apr 14, 2010 7:30 pm
How often MT does code drops on Beta5?
NetworkPro
Re: RouterOS 5 beta
Wed Apr 14, 2010 7:44 pm
code drops?
edmidor
Re: RouterOS 5 beta
Wed Apr 14, 2010 8:10 pm
Sub-releases with bug fixes... Beta presumes having bugs
Chupaka
Re: RouterOS 5 beta
Wed Apr 14, 2010 8:27 pm
regularly, unpredictably =)
NetworkPro
Re: RouterOS 5 beta
Fri Apr 16, 2010 3:30 am
PCQ seems working still. If you give me login I will look at yours.
-> Userman in the Beta works slooooow when I change the IP address (in Constraints)
-> My partner added a Bridge to the second PPPoE Server in the LAN and some VLANs disappeared from WinBox but they were still passing traffic. A reboot and WinBox went to normal.
martini
Re: RouterOS 5 beta
Fri Apr 16, 2010 10:02 am
Hello NetworkPro, can you post your PCQ config on v5 beta ? or send me email "martiniy at gmail.com"
NetworkPro
Re: RouterOS 5 beta
Fri Apr 16, 2010 1:26 pm
I can sell it to you. It makes magic and the Users are happy.
martini
Re: RouterOS 5 beta
Fri Apr 16, 2010 4:50 pm
yes, send it to mee please, (martiniy at gmail.com)
Chupaka
Re: RouterOS 5 beta
Fri Apr 16, 2010 5:42 pm
sell, not send =)
martini
Re: RouterOS 5 beta
Fri Apr 16, 2010 5:58 pm
sell ??? )) ok, i can buy PCQ config for 1500000 euro-dollars-pounds )
xins
Re: RouterOS 5 beta
Mon Apr 19, 2010 9:20 am
nice work for beta :)
now we can just use web browser in our phones etc etc
just add terminal in webfig :)
Im so small
marlow
Re: RouterOS 5 beta
Mon Apr 19, 2010 2:24 pm
Why would you want the terminal in webfig ? Don't you have putty or something the likes on your phone already ?
/M
-- AT&T
kleku
Re: RouterOS 5 beta
Thu Apr 22, 2010 1:02 am
My 433AH 5beta1 just died after downgrading to 4.7 :(
Same operation on rb600 ok.
#mikrotik-pl @ IRCnet
erastusec
Re: RouterOS 5 beta
Thu Apr 22, 2010 8:14 am
Would be nice to have an hart beat monitor that can hardware reset the boards.
THG
Re: RouterOS 5 beta
Fri Apr 23, 2010 8:38 am
lol :)
I fixed it, I made my own ISO image. :)
mindaugasr
Re: RouterOS 5 beta
Sun May 09, 2010 9:12 am
lol :)
Can You tell me how You fix it? I have same problem, beta does not work on any virtual computers software. Thanks
janisk
Re: RouterOS 5 beta
Tue May 11, 2010 2:10 pm
/system watchdog
Just careful with what you are setting up there, you can end with endlessly rebooting router (eg, enter wrong ip address to check)
THG
Re: RouterOS 5 beta
Wed May 12, 2010 9:27 am
No, too complicated to explain. :)
Download this CD image and install, then upgrade to the latest beta.
http://uploading.com/files/ac3abcdf/mik ... eta1a.iso/
THG
Re: RouterOS 5 beta
Thu May 13, 2010 4:55 am
Here is Version 5 Beta 2 for VMware installation.
http://uploading.com/files/bm14ddf4/mik ... eta2a.iso/
mindaugasr
Re: RouterOS 5 beta
Thu May 13, 2010 9:59 am
Thanks for suggestions.
With Your image i'm able to install beta 1, but upgrade does not change to beta2. Pleas see attachment. Maybe You have any suggestions?
Very thanks.
Best regards,
Mindaugas
THG
Re: RouterOS 5 beta
Thu May 13, 2010 11:35 am
You cannot upgrade in trial mode.
mindaugasr
Re: RouterOS 5 beta
Thu May 13, 2010 2:55 pm
Thanks, for support!
omega-00
Re: RouterOS 5 beta
Thu May 20, 2010 9:10 pm
Just wondering if the v5 stable release will have support for IPv6 compatible versions of any of the following:
- ssh access to mikrotik
- winbox access to mikrotik
- support for ipv6 records in /ip accounting
- support for ipv6 based queue rules and/or queue tree
If this isn't exactly the right thread to be asking this I'll move it, but it seemed the best of the v5beta ones. ^_^
marlow
Re: RouterOS 5 beta
Thu May 20, 2010 10:26 pm
None of those features are in the beta, so I reckon that'll be unlikely, unless you start opening tickets for it.
/M
-- AT&T
mrz
Re: RouterOS 5 beta
Fri May 21, 2010 7:52 am
IPv6 queue trees are already possible.
omega-00
Re: RouterOS 5 beta
Fri May 21, 2010 8:04 am
Thanks for that, tested and confirmed, queue tree (not simple queue) supports ipv6 traffic (as marked under the ipv6 firewall).
Chupaka
Re: RouterOS 5 beta
Fri May 21, 2010 2:58 pm
THG
Re: RouterOS 5 beta
Sat May 22, 2010 9:48 pm
Many people downloaded my install cd for vmware. Not a single complaint yet, so I guess it works for those people who downloaded it. However, it would be of interest if anyone could confirm if it was useful for anything else than vmware installations. I read somwhere that this issue also ocurred to some computers (i don't really remember where I read it).
NetworkPro
Re: RouterOS 5 beta
Sat May 22, 2010 9:51 pm
Your experience I re-used to boot a NetInstall-ed HDD. I replaced linux and initrd with the ones from 4.9 and it worked.
leoelan
Re: RouterOS 5 beta
Thu May 27, 2010 2:23 pm
What should I do if there is on the server pc (intel server board model: s34420gpv, memory: kingston kvr1333d3n9/2g 2G * 2, hdd: sata2 320Gb, proccessor intel: core i5). how to test me RouterOS 5 beta2, I can not even install?
NetworkPro
Re: RouterOS 5 beta
Fri May 28, 2010 9:29 am
Did you try with the supplied v5 beta 1,2 iso above? Did you try with v4.9 iso? Did you try with NetInstall over bootp? Did you try with NetInstall over a floppy? Did you try to touch some configs for the IDE/SATA controller in BIOS? Did you update the BIOS? I always needed to update Intels sh!t. If you cant use onboard IDE/SATA - use USB.
duke007
Re: RouterOS 5 beta
Thu Jun 10, 2010 6:53 pm
Hi. Probably my own stupidity...
I recently upgraded the routeros on my RB333 from 2.9 to 3.30 and then to 4.10 because the 3.30 that was installed had no user manager. After installing 4.10 I noticed that radius and the user manager could not communicate with each other anymore. The I installed routeros 5 beta 2 but the problem still persists. Radius has been set up on the RB333 for ppp and the ip address is 127.0.0.1 with a secret and the usermanager is also on the RB333, here I added the router with ip=127.0.0.1 and the same secret. When I try to connect the ppp I get an error telling me that the radius server timed out. Does anyone have any advice for me please???
mangust
Re: RouterOS 5 beta
Tue Jun 29, 2010 12:11 pm
Seems that IRQ balancer & PCI MSI are not pretty stable.
I'd also read about memory usage problem in Beta 3.
I need to decide what to use. Really need MSI , but looks that B2 is more stable.
Normis – Are you going to provide b4 in NEAREST feature?
dbaker
Re: RouterOS 5 beta
Fri Jul 09, 2010 11:04 pm
I have been doing some testing with 5.0beta4 and have had great success. I see a definite speed improvement in testing especially on the upload side. To give some background we have always been a Cisco shop, but I have been working hard to change the views of my colleagues. Little by little we are changing, at least the wireless side, over to Mikrotik using Ubiquiti radio cards. I now have all of the backhaul radios switch over to Mikrotik and have started to replace the CPE with Mikrotik as well. Unfortunately my APs are still Cisco 1240AG Series Access Points (feel free to bash) running IOS 12.3(7)JA3. In our configuration each user has a VAP, a VLAN and a 2 /30 subnets. One /30 is private and used for management, the other is a static public IP. I had a situation come up and needed to replace a CPE so I grabbed one of my 411AH boards that I had been testing on our internal wireless network, which is all Mikrotik, and went out to the customers. The Mikrotik connected up like a champ, but I could not pass any traffic. The MAC showed up in the Cisco bridge table, but even after clearing the ARP on the 3560 switch I could not see anything coming from the Mikrotik. No MAC no ARP no nothing, but I did have a great connection. I tried several different configurations but with no luck at all – puzzling since I have them working in other locations. As a last resort I downgraded from the 5.0Beta4 to 4.10 and bam everything was worked and as usual was out performing the previous CPE, which was not a Mikrotik. I’m not sure what was wrong, other than the version, and had a customer breathing down my neck to get them back online. I wish I had more information that would help, but I had to get the customer back up and running. It is not a problem currently, but some of the speed improvements I am seeing in a lab setting are impressive and would love to be able to move to 5 when it is released.
sabaitechnology
Re: RouterOS 5 beta
Sun Jul 11, 2010 10:55 pm
I've been running 5 beta 2
The webfig is important to me because these boxes would be going out to people running Windows, Mac or Linux.
I'm trying to create a PPTP client through the + sign on interface. Everything comes up and I put in the information but when I hit Apply or OK button, it just says "waiting for 192.168.88.1" in the bottom left corner of the webpage and never applies the new settings. I've used both Chrome and Firefox. I'm trying to program it through the web interface and am using a Ubuntu desktop.
I can get the interface created through WinBox but need to be able to program through the web interface.
Any ideas?
normis
Re: RouterOS 5 beta
Mon Jul 12, 2010 8:03 am
Any ideas?
which model of RouterBOARD do you use ?
sabaitechnology
Re: RouterOS 5 beta
Mon Jul 12, 2010 2:54 pm
Sorry I didn't post that earlier. RB750G.
normis
Re: RouterOS 5 beta
Mon Jul 12, 2010 2:56 pm
I can repeat the problem. Thank you for reporting it. We will try to fix it in next version.
sabaitechnology
Re: RouterOS 5 beta
Mon Jul 12, 2010 3:12 pm
Thanks!
Alessio Garavano
Re: RouterOS 5 beta
Tue Jul 13, 2010 1:15 am
Is bridge filters worikng in v5 betas?
I am trying in beta1 at beta4 without not moving in the counters... only now in the gateway i can get the counters moving but only in chain INPUT, have a lot of RBs bridged with filters not counting...
Alessio Garavano
http://www.isparg.com.ar
taduikis
Re: RouterOS 5 beta
Thu Oct 14, 2010 12:57 am
Well because it's much more convenient that way. You could easily jump to virtually any computer (or a phone), they all have web browsers nowadays, open a webfig in your browser, call a terminal and execute commands. Everything is there. And since now we have lots of nice technologies like AJAX, thats not that difficult to achieve either. I'm not sure, but I think there are some AJAX terminals already, they are mostly used in VDS control environments.
charliebrown
Re: RouterOS 5 beta
Thu Oct 14, 2010 1:02 am
Since the SSH rebuild in ROS 5 does it fix the issue that caused connectbot on Android to not be able to login via SSH? cos if that's still a problem then webfig terminal is a must
Users browsing this forum: Baidu [Spider], jamrobe, leonardoCausi, liuyao, skraw, txfz and 163 guests
