meverest
flapping link or icmp problem of some kind
Thu Jul 15, 2004 12:32 pm
Hi folks,
My router has a strange problem, look at this ping from my workstation to router:
C:\Documents and Settings\mike>ping -t 192.168.1.126
Pinging 192.168.1.126 with 32 bytes of data:
Reply from 192.168.1.126: bytes=32 time=699ms TTL=64
Reply from 192.168.1.126: bytes=32 time<1ms TTL=64
Reply from 192.168.1.126: bytes=32 time=556ms TTL=64
Reply from 192.168.1.126: bytes=32 time=414ms TTL=64
Reply from 192.168.1.126: bytes=32 time=270ms TTL=64
Reply from 192.168.1.126: bytes=32 time=128ms TTL=64
Reply from 192.168.1.126: bytes=32 time=986ms TTL=64
Reply from 192.168.1.126: bytes=32 time=841ms TTL=64
Reply from 192.168.1.126: bytes=32 time=700ms TTL=64
Ping statistics for 192.168.1.126:
Packets: Sent = 15, Received = 15, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 986ms, Average = 306ms
Control-C
^C
this result is over ethernet, but I get exactly the same thing over wifi interface connection.
any suggestions how i might diagnose further or what i should be looking for?
thanks & regards, Mike.
sten
Forum Veteran
Forum Veteran
Re: flapping link or icmp problem of some kind
Sat Jul 17, 2004 12:57 am
Tell us what Hardware you have and your relevant config. Guess work is boring. ;)
_// Sten Daniel Sørsdal
meverest
Sat Jul 17, 2004 3:29 am
Yes, guesswork can be that way <ahm> :lol:
The hardware is ECS p6lx-a+ mainboard with PII 350. 3x PC-100 32M ram, one netgear wg311 and one rtl8029 generic brand ethernet.
the only other thing is some unidentified agp video adapter.
i haven't even started swapping out bits as i was kinda hoping someone might be able to give me a clue or 2. i haven't come across this sort of thing before, and i am (of course) quite unfamiliar with this router OS as it is my first eval copy.
thanks for the response!
regards,. Mike.
meverest
Sat Jul 17, 2004 4:12 am
hey,
what's really wierd, is that when i log on to the router terminal and ping back to the workstation, i get this:
Terminal vt102 detected, using multiline input mode
[admin@Hoth] > ping
address: 192.168.1.1
192.168.1.1 64 byte ping: ttl=128 time=2 ms
7 packets transmitted, 7 packets received, 0% packet loss
round-trip min/avg/max = 2/2.0/2 ms
[admin@Hoth] >
looks just fine from that end - now i'm completely confused! how can it be?
regards, Mike.
meverest
Sat Jul 17, 2004 1:31 pm
OK!
I swapped out that netgear 54g card for an older 11b, and now it all works fine again.
I assume that there was some driver problem with that card - it loaded up as atheros, but i suppose it was no good.
cheers, Mike.
Users browsing this forum: fposavec, gastonet, mohkhalifa and 93 guests
