Equis
Forum Veteran
Forum Veteran
Multicore
Mon Apr 19, 2010 3:11 am
Hello
I ant to use pptp server with multicore cpu
this is not supported yet.
Would an option be to install 4 meterouters and have pptp server on that?
Chupaka
Re: Multicore
Thu Apr 22, 2010 6:00 pm
well, not Metarouters, but KVMs. and yes, it should work
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Equis
Forum Veteran
Forum Veteran
Re: Multicore
Fri Apr 23, 2010 2:09 am
With the KVM is there a performance big hit with network traffic?
I only need about 20mbit for each KVM
Thanks Again
Chupaka
Re: Multicore
Fri Apr 23, 2010 2:51 am
20 Mbps?.. how much KVMs? one router should be quite enough :)
p.s. as far as I know, nobody have tested such configs in terms of performance...
Equis
Forum Veteran
Forum Veteran
Re: Multicore
Fri Apr 23, 2010 3:00 am
for me its not how much traffic but how many tunnels.
I Have over 1000 pptp and cpu is maxed on a p4
csickles
Re: Multicore
Sat Apr 24, 2010 1:23 am
Sounds like a Xeon is you future.
Things that make you go "Hmmmmmmmm"...
Craig
martini
Re: Multicore
Sat Apr 24, 2010 4:45 am
Tested on ESX4 with i85476 and msi-x and multiqueue per ethernet port, work very good.
3 virtual router (5.0 beta), traffic 200-300 Mb/s
Users browsing this forum: Google [Bot] and 79 guests
