hecklertm
WPA on a VAP
Sat Aug 13, 2005 12:01 am
I have been looking at the 2.9 manual, and I am not clear on whether you could setup a virtual AP, and then enable WPA only for the particular VAP.
Therefore, first time clients could connect with no encrytion and once validated they would be given the PSK to use for future connections using the WPA encrpyted AP.
I do not see anywhere that you could assign which adapter to apply the encryption on. Any ideas?
tneumann
Re: WPA on a VAP
Sat Aug 13, 2005 1:33 am
The encryption settings are tied to the security-profile. You may set individual security-profiles
for each AP interface, including virtual ones.
--Tom
Users browsing this forum: Baidu [Spider], eworm, guido2020, MCN, sindy and 96 guests
