cata02
Upnp
Tue Apr 27, 2010 9:53 pm
Is Upnp supposed to work on 4.6?
i've enabled it, added internal interface, added firewall rules. the mikrotik is discovered ok as an igd but any upnp call to it fail.
running netmon tracing reveals some http not found responses.
running any upnp port forwarding tool fails.
this tool seems mature: http://www.wiseorbit.com/, it fails (emule config fails, vista network check tool fails -- microsoft tool, etc.).
what's going on?
cata02
Re: Upnp
Tue May 18, 2010 7:59 am
anyone?
i've tested it with 4.6 and 5 beta 2 with no luck.
duvi
Re: Upnp
Tue May 18, 2010 10:04 am
You should also add external interface.
cata02
Re: Upnp
Tue May 18, 2010 10:56 am
ok.
wouldn't that be required only for disabling the internet connection?
duvi
Re: Upnp
Tue May 18, 2010 12:54 pm
Don't know, I never enable "Allow to disable internet connection".
[admin@MikroTik] > /ip upnp export
/ip upnp
set allow-disable-external-interface=no enabled=yes show-dummy-rule=yes
/ip upnp interfaces
add disabled=no interface=ADSL type=external
add disabled=no interface=bridge-private type=internal
mrz
Re: Upnp
Tue May 18, 2010 1:00 pm
Yes, you have to add also external interface otherwise UPNP will not work.
cata02
Re: Upnp
Tue May 18, 2010 10:40 pm
seems to work now.
i've added the external interface.
will test more.
Users browsing this forum: Bing [Bot], Google [Bot], HakanE, msatter, Onigma and 133 guests
