someuser
radius server not responding
Tue May 04, 2010 9:29 am
I've configured my RB750G to authenticate with Usermanager.
I can't get it to work. HotSpot works fine, Yet I can't seem to get Radius Server (usermanager) to take over.
If I create users in usermanager and and use a created account, I'm able to get on internet, only after
logging in with "trial" account or admin account via HotSpot, Not a big surprise there.
I've enabled UserManager Router IP in Walled Garden etc..
I cannot get user manager to work.
Keep getting " radius server not responding.
There's not problem pinging it.
Any help greatly appreciated.
BTW, using Beta2
export of /radius
/radius
add accounting-backup=no accounting-port=1813 address=192.168.88.1 \
authentication-port=1812 called-id=uptown disabled=no domain=\
"mydomain".com realm="" secret=123456 service=login,hotspot timeout=300ms
/radius incoming
set accept=yes port=3799
export of /hotspot
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot \
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap \
name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=\
1 status-autorefresh=1m transparent-proxy=no
/ip hotspot profile
add dns-name=login.uptown.com hotspot-address=192.168.88.1 html-directory=\
hotspot http-proxy=0.0.0.0:0 login-by=http-chap,trial name=hsprof1 \
nas-port-type=wireless-802.11 radius-accounting=yes \
radius-default-domain="mydomain".com radius-interim-update=received \
radius-location-id=uptown radius-location-name=uptown radius-mac-format=\
XX:XX:XX:XX:XX:XX rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
trial-uptime=1d/1d trial-user-profile=default use-radius=yes
add dns-name=login.hotspot.com hotspot-address=192.168.88.1 html-directory=\
hotspot2 http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=\
cookie,http-chap,trial name=hsprof2 nas-port-type=wireless-802.11 \
radius-accounting=yes radius-default-domain="mydomain".com \
radius-interim-update=received radius-location-id=uptown \
radius-location-name=uptown1 radius-mac-format=XX:XX:XX:XX:XX:XX \
rate-limit="" smtp-server=0.0.0.0 split-user-domain=no trial-uptime=\
30m/1d trial-user-profile=default use-radius=yes
/ip hotspot
add address-pool=default-dhcp addresses-per-mac=2 disabled=no idle-timeout=5m \
interface=ether2-local-master keepalive-timeout=none name=hotspot1 \
profile=hsprof2
/ip hotspot service-port
set ftp disabled=no ports=21
/ip hotspot user
add disabled=no name=admin password=1234 profile=default
/ip hotspot walled-garden
add action=allow comment="place hotspot rules here" disabled=yes
add action=allow disabled=no dst-host=http://"mydomain".com dst-port=3799 \
path="/user\?signup=uptown"
path=/ server=hotspot1
/ip hotspot walled-garden ip
add action=accept disabled=no dst-address=192.168.88.1 dst-host=\
[admin@RB750G] /ip hotspot>
Chupaka
Re: radius server not responding
Tue May 04, 2010 12:22 pm
/radius monitor 0
also, if it's on your local router, maybe use 127.0.0.1 instead of 192.168.88.1?..
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
someuser
Tue May 04, 2010 10:28 pm
[/attachment]
/radius monitor 0
I've changed IP to 127.0.0.1.
Still nothing new.
Here's an export (/radius monitor 0) from a different but similar setup with RouterOS (box not RB750G).
[admin@MikroTik] /radius> monitor 0
pending: 0
requests: 3
accepts: 0
rejects: 0
resends: 0
timeouts: 3
bad-replies: 0
last-request-rtt: 0s
So, might it be something in firewall?.
Here's pics of user profile.
I"ve actually purchase credits from my own paypal account and shows the user good to go.
But again, when I'm presented with the intial login (hotspot) page, and I enter the usermanager generated ("prefix09juy") username,
I can't login on that login page.
Also, if I go to the http://routerIP/user?signup=uptown page and use that username, it shows the above user paid and good to go.
I have setup the NTP client since then so the time is up to date.
To get past all this. Can I create a user in usermanager (say unlimited) that doesn't need to "credits". Similar to "bypass" in HotSpot database?
Chupaka
Wed May 05, 2010 2:10 pm
do you have any blocking rules in input and output firewall filter chains?
bigguns
Sun May 30, 2010 10:44 pm
Is there any information on this issue because I'm having the same issues.
sergejs
Mon May 31, 2010 2:28 pm
Set 127.0.0.1 for /radius and /tool user-manager router.
Do you have /ip firewall nat rules for masquerade?
ahooper
Fri Sep 20, 2013 6:09 am
I am having the same issue.
Has anyone found a resolve this this yet?
It appears that the usermanager radius is not working at all, I am seeing the hand off in the status but they just time out then get the message radius server not responding.
I also tried to us NTRadPing and reconfigured UserManager to accept messages from my machine but again no response.
I am using the latest version v6.4 on an RB750G
ahooper
Fri Sep 20, 2013 6:13 am
Correction, I have managed to get a response from NTRadPing Test Util so the radius is working just not for requests sent via the localhost.
ahooper
Fri Sep 20, 2013 6:38 am
Well a quick and nasty fix.. It appears that the reason this happens is that when you have a hotspot in the new version the radius seems to not work for 172.0.0.1 but will work for the IP of the hotspot but if you do this the firewall MASQ will fire the request out the gateway.
Fix for me was to add an IP /32 to the hotspot interface then use that instead. Seems to be working.
onlysuraj
Wed Dec 04, 2013 4:44 pm
dear sir, i have the same problem ?
yes i have done this /ip firewall nat rules for masquerade
i have done all the setting well but i can log in through usermanager users but i can log in by the users that are created in winbox
error :protocol is not working and radius is not responding
please help mikrotik i have been working to configure usermanager last one month but not luck
thanks
suraj
Users browsing this forum: AM1, Baidu [Spider], Bing [Bot], lmcarriles, robsgax, rogerlie and 117 guests
