goddy
HOW TO USING WINBOX TO CONFIG HOTSPOT
Wed Aug 17, 2005 1:30 pm
Hi
Can someone me to config hotspot thru the winbox.The last time I tryed I messed up and had to reset my router.
Peace to max,am out like that
sergejs
Wed Aug 17, 2005 1:37 pm
go to ip hotspot, and than "setup" button :wink:
follow setup guide, that's all.
goddy
Wed Aug 17, 2005 3:54 pm
Hi
check this setup if correct?
hotspot interface=omini-directional
enable universal client=yes
log method=enable-address
gateway=172.0.0.0.
ip pool=10.0.0.1-
ssl=yes
passpharess=his
transparent web-proxy=yes
local cache=yes
dns name=d***
another port=8081
sankofa411
Wed Aug 17, 2005 11:27 pm
Go to this link and read on the setup
http://www.mikrotik.com/docs/ros/2.8/ip/hotspot
or run the setup and follow the info below and punch in your own figures to correspond to your network
[admin@MikroTik] > ip hotspot setup
hotspot interface: ether1
local address of network: 192.0.2.1/24
masquerade network: yes
address pool of network: 192.0.2.2-192.0.2.126
select certificate: none
ip address of smtp server: 0.0.0.0
dns servers: 192.0.2.254
dns name: hs.example.net
name of local hotspot user: admin
password for the user: rubbish
[admin@MikroTik] >
ajmal
Thu Aug 18, 2005 7:17 am
If u wans access router via winbox you have to do as following
set hotspot port as
/ip services set hotspot 80
and www port as
/ip services set www 8081
and define ip address on router's local interface like
192.168.1.1/29 as wel as 192.168.1.2/26 ip on your local PCs from where to access winbox.
now download winbox keeping address 192.168.1.1:8081
double click on winbox and put 192.168.1.1:8081 in winbox
or follow the following link for more details
sergejs
Thu Aug 18, 2005 8:31 am
I suggest upgrade to 2.9 version and configure HotSpot.
goddy
Thu Aug 18, 2005 2:05 pm
hi
are u saying that setting hotspot it should always be set to ether1?Not the omini?
normis
Thu Aug 18, 2005 2:08 pm
no! you have to set in on that interface where you will have the hotspot users . duh :)
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 82 guests
