cravetou
Big PPPOE Problem Thats Needs an Expeart
Thu May 06, 2010 7:02 pm
hello expert
My server working for fine and everything with pppoe is work but the problem is that when i connect to the server for a period of time i lost the connection (no ping for the server no ping for the dns) and the pppoe connection still connected on the pc this problem happen from time to time not for a fix period of time and in the same time if i login using hotspot everything work fine.
i try...
1- many version of ROS.
2- changing all the cables.
3- changing the Router (i use RB1000).
4- attach the pc directly to the Router interface.
I'm will be happy for your reply
Thank you very much in advance
rodolfo
Long time Member
Long time Member
Re: Big PPPOE Problem Thats Needs an Expeart
Thu May 06, 2010 9:00 pm
have you tried to change the pc ?
rodolfo
IZ0UQV
cravetou
Fri May 07, 2010 1:16 am
sure i did that and i'm talking about 1000 user suffering from this problem
missinlnk
Fri May 07, 2010 6:22 pm
What version of RouterOS are you running? How does the problem show itself? Do all the customers have problems at the same time, or is it varied where it seems like only a few people have a problem but that it's constantly happening? What's between the RB1000 and your customers? How is that network configured?
cravetou
Fri May 07, 2010 6:35 pm
dear missinlnk
i use many version of ROS as i told u , the problem happed with all the user but not in the same time .
after the RB1000 thers is a switch but i told u its happed even i attahed to the router interface.
THanks
missinlnk
Sat May 08, 2010 12:32 am
We'll need a little more information than that. Can you show us your PPPoE config? What is left in your log files when the PPPoE users are forced to disconnect?
omidkosari
Trainer
Trainer
Sat May 08, 2010 11:33 am
hello expert
i try...
Only use pap for authentication . uncheck other methods and problem will be solve
tgrand
Long time Member
Long time Member
Sat May 08, 2010 4:42 pm
Open a command line and run the following command:
interface pppoe-server export file=pppoeconfig
It will create a text file. Open this text file and copy the contents, then paste it into the forums.
This way we can help diagnose the problem.
cravetou
Sun May 09, 2010 9:21 am
this is the export as file...
/interface pppoe-server server
add authentication=pap,chap,mschap1,mschap2 default-profile=default disabled=\
no interface=ether4 keepalive-timeout=10 max-mru=1480 max-mtu=1480 \
max-sessions=0 mrru=disabled one-session-per-host=no service-name=\
service1
cravetou
Sun May 09, 2010 9:30 am
hello expert
i try...
Dear
sorry for that but are certain 100% this is gonna solve may problem do you face the same problem and this is solve it
plz advice me
omidkosari
Trainer
Trainer
Sun May 09, 2010 11:41 am
yes . i am sure . and don't forget karma + :D
t3wera
Sun May 09, 2010 4:21 pm
u have 2 way to solve ur proplem
change the RJ that u put it in ur pc or u put in switch
if u don`t understand me try change the RJ in this line
second way go to winbox
interface click in all real interface change ur arp from enable to proxy arp
WArrning don`t use pap this will let u easy to any one hacked in ur server
haider74
Mon May 10, 2010 12:59 am
i have the same problem :(
and i saw the [RX Errors] begin to increase as pic attached
cravetou
Mon May 10, 2010 12:04 pm
hello
This user r wire or wire less.
and r u sure its the same problem cuz i can see there is tx and rx from this user??
thanks
Nando_lavras
Mon May 10, 2010 3:54 pm
Mark only CHAP authentication in PPPoE Profile, problem solved.....
haider74
Mon May 10, 2010 4:55 pm
hello
thanks
hello again
i use both wire and wireless
when the ping stop and service stop
i watch this RX Errors increase
when ping and service back the RX Errors have no change
i use the same setting of you
i hope somebody help us...
omidkosari
Trainer
Trainer
Mon May 10, 2010 5:31 pm
Your problem is different . i don't suggest that solution for you .
cravetou
Mon May 10, 2010 5:57 pm
I think i aggree with u
haider74
Mon May 10, 2010 11:00 pm
ok
every thing is clear to you what is my solution?
Users browsing this forum: AndyBern, eworm, Google [Bot] and 184 guests
