amobadder
Two different queuing
Tue May 11, 2010 12:44 pm
I have DNS server with IP address 192.168.2.2/24, I want my client to have unlimited bandwidth to the DNS server but limited connection to the internet.
I tried to use perroute packet to mark packet and use simple queue to unlimited it but does not work any advice.
Thanks in advance
sergejs
Re: Two different queuing
Tue May 11, 2010 1:46 pm
Do you use simple queues?
Add first simple queue,
/queue simple add target-address=your_local_subnet dst-address=DNS_Server (do not forget to set queue-type to default), add queue simple rules to limit the bandwidth for your clients below the rule.
amobadder
Wed May 12, 2010 8:44 am
When I add my my_local_subnet in the simple Queue for example upload 64K and download 128K, my question is does every client in the subnet will be limited to 64K/128K or all the subnet will share 64k/128K.
I more detail, I need to know does every client in this subnet can use 64k/128k in the same time.
thanks
sergejs
Wed May 12, 2010 2:44 pm
Subnet will be limited to 64k/128k
If you want to assign 64k/128k to every subnet user, you should use PCQ,
http://wiki.mikrotik.com/wiki/Manual:Queues_-_PCQ
amobadder
Mon May 24, 2010 11:08 am
How can i control Traffic via domain name example www.gmail.com
Chupaka
Mon May 24, 2010 9:24 pm
no way. you need Squid or something
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
martini
Mon May 24, 2010 9:30 pm
you may use mark packet (mark udp and tcp 53 port)and then create simple queue with this mark an unlimited bandwidth at top of your users queue
amobadder
Wed May 26, 2010 8:42 am
Why (udp and tcp 53 port) i think http and https (tcp 80, tcp 443)
sergejs
Wed May 26, 2010 10:59 am
I do not think it will limit www.gmail.com traffic to the specific amount of bandwidth, neither port 80/443 will give a result.
Firewall/Queue does not offer option to limit by exact domain name, the most recommended solution to do the bandwidth limitation for www.gmail.com.
- find all IP addresses used by www.gmail.com;
- add them to address-list;
- setup mangle to mark by address-list;
- setup queue for mangle mark.
BrianHiggins
Long time Member
Long time Member
Thu May 27, 2010 4:11 pm
UDP / TCP 53 are the ports used by DNS, the OP wants to allow unlimited bandwidth to his DNS servers, so creating a packet mark on this traffic, then assigning a unlimited queue to that mark and putting it at the top is exactly correct.
as for limiting traffic to gmail, either implement a full web proxy suite, or try and get all the IPs of gmail and put them into a queue. it'll work, but require you to validate the IPs you are limiting are still correct pretty frequently (I'd say at least once a month)
-Brian
http://www.aditumims.com
Complete web based ISP in-a-box solution, designed specifically for Multi-Tenant properties, works great for WISPs too.
Users browsing this forum: andkar, Bing [Bot] and 101 guests
