havaltech
Packet Loss when users taking full bandwidth
Thu May 13, 2010 4:01 pm
Hi Guys,
I have Mikrotik Routerboard1000 we are connected 10 computers with it, each user have limited bandwidth with 256Kbit down and 128Kbit up using simple queues. everything is working fine user have internet and taking their limited bandwidth. the problem when users taking full bandwidth i mean 256Kbit ping to outside even to mikrotik router become worse many packet loss. is there anyway when can make users do not have packet loss even if they used full bandwidth?
P.S.: we have this problem if only one user connected also i mean it is not related to international bandwidth.
Best Regards,
haval
Chupaka
Re: Packet Loss when users taking full bandwidth
Thu May 13, 2010 4:21 pm
make your queues longer ))) then ping will be higher, but drop should decrease
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
havaltech
Thu May 13, 2010 4:32 pm
Dear Chupaka,
what you mean by make your queue longer shall increase the limitation?
Regards,
haval
Chupaka
Thu May 13, 2010 6:20 pm
increase queue length in queue type
havaltech
Thu May 13, 2010 10:14 pm
Dear Chupaka,
After i increased queue size now ping going higher but there is no packet loss as you said. thank you very much.
Best Regards,
Haval
Chupaka
Fri May 14, 2010 12:11 am
you may also create additional queue for icmp, so that ping be always good and not shaped =)
havaltech
Fri May 14, 2010 2:49 am
Dear Chupaka,
How i can creat an additional queue for ICMP?
Regards,
haval
Chupaka
Fri May 14, 2010 3:54 pm
create additional queue, set some routing mark and set this mark to all icmp packets in Mangle...
havaltech
Fri May 14, 2010 5:52 pm
Dear Chupaka,
After i did below config as you said now when users using their full bandwidth the ping even not going higher will stay at it is normal value. just wanted to share my confing. let me know if something wrong but it is working fine for me.
Mangle
ip firewall mangle add protocol=icmp action=mark-connection new-connection-mark=ICMP-Traffic chain=forward
ip firewall mangle add connection-mark=ICMP-Traffic action=mark-packet new-packet-mark=ICMP chain=forward
Queue Tree
queue tree add name=Download parent=Local-Interface
queue tree add name=Upload parent=global-out
queue tree add name=ICMP-RX parent=Download packet-mark=ICMP max-limit=512K priority=1
queue tree add name=ICMP-TX parent=Upload packet-mark=ICMP max-limit=512k priority=1
Chupaka thanks for your great answers.
Best Regards,
Haval
Chupaka
Fri May 14, 2010 6:20 pm
actually,
/ip firewall mangle add protocol=icmp action=mark-packet new-packet-mark=ICMP chain=forward
is quite enough
p.s. don't forget about Karma =)
THG
Fri May 14, 2010 8:31 pm
Don't forget to do the same thing with ACK packets.
Equis
Forum Veteran
Forum Veteran
Fri May 14, 2010 9:58 pm
Hello
How do you do a queue with ack packets?
THG
Sat May 15, 2010 4:47 pm
I'm lazy, so I've made it simple. I mangle small packets and give it high priority. It's not the best solution, because every small packets will get high priority, e.g. ACK/NACK, ICMP, VOIP etc. Maybe someone else has a better suggestion. :)
Equis
Forum Veteran
Forum Veteran
Mon May 17, 2010 1:11 am
Hello
Thanks for that
Can you paste fw rule?
THG
Mon May 17, 2010 2:49 am
Something like these rules.
add chain=forward packet-size=0-128 \
    action=mark-connection new-connection-mark=small-packets passthrough=yes \
    comment="" disabled=no
    action=mark-packet new-packet-mark=small-packets passthrough=yes comment="" \
    disabled=no
Equis
Forum Veteran
Forum Veteran
Mon May 17, 2010 3:20 am
Thanks heap for that
I'll give it a go
soamz
Fri Jun 10, 2016 1:51 pm
I have the same issue. Customers PPPoE disconnects when full bandwidth is being used.
or they are experiencing ping cut, means ICMP drop.
So, simply add those 3 rules in terminal ???
    disabled=no
Users browsing this forum: Baidu [Spider], gkk, xeonabc and 91 guests
