MUM Europe 2020
xezen
Long time Member
Long time Member
ros 4.9
Fri May 14, 2010 8:45 am
so what do people say about ros 3.9
so far i found it works for me with no problems i would like to upgrade my whole network
even the rb133c ad i di the labtest and it works fine not as fast as 2.9 was but it works
thay will be replace soo anyway
so what do other people say about v4.9 ros
If i dont No Ask someone That Does!
Belyivulk
Re: ros 4.9
Fri May 14, 2010 11:02 am
4.9 works for us on the 3 routers we use it on :) I think its too soon to mass upgrade though! just my feelings
rmichael
Forum Veteran
Forum Veteran
Re: ros 4.9
Sun May 16, 2010 8:05 pm
As far as wireless is concerned ROS 4.9 is better than 4.5 for Nstreme WDS. With 4.9 I get better CCQ, better startup (it does not seem to go through B before switching to G speeds) and no "excessive data loss" on links below 22dB SNR.
Hope that helps :)
xezen
Long time Member
Long time Member
Re: ros 4.9
Mon May 17, 2010 3:16 pm
so far so good thnks but would like to here other comments like pptp firewall pppoe ospf etc thanks for the info
Hotz1
Re: ros 4.9
Tue May 18, 2010 6:59 pm
LOL, I was forced to upgrade all our equipment to 4.9 after 4.7 took two of our production boxes offline, and downgrading didn't solve the problem. FWIW, we have had no issues with 4.9, though we aren't doing anything terribly sophisticated with it: just bridging, WDS, VLAN, hotspot, nstreme-dual, and some minor scripting.
Principal, Engineering
Cape Ann Communications, Inc.
Gloucester, MA, USA
Users browsing this forum: Google [Bot], hngjared, Jobinuw, mscarpitti and 100 guests
