Here's an example doing API command "/interface/wireless/getall ?name=wlan1" under RouterOS 4.4:
<<< '/interface/wireless/getall' (26)
<<< '?name=wlan1' (11)
<<< '.tag=2' (6)
<<< END-OF-SENTENCE
>>> '!re' (3)
>>> '.id=*3' (6)
>>> 'name=wlan1' (10)
>>> 'mtu=2290' (8)
>>> 'l2mtu=2290' (10)
>>> 'mac-address=AA:BB:CC:DD:EE:FF' (29)
>>> 'arp=enabled' (11)
>>> 'disable-running-check=false' (27)
>>> 'interface-type=Atheros AR5413' (29)
>>> 'radio-name=TestRadio' (23)
>>> 'mode=ap-bridge' (14)
>>> 'ssid=TestRadioSSID' (18)
>>> 'area=' (5)
>>> 'frequency-mode=manual-txpower' (29)
>>> 'country=united states' (21)
>>> 'antenna-gain=0' (14)
>>> 'frequency=5180' (14)
>>> 'band=5ghz-10mhz' (15)
>>> 'scan-list=default' (17)
>>> 'rate-set=default' (16)
>>> 'supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps' (44)
>>> 'supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps' (73)
>>> 'basic-rates-b=1Mbps' (19)
>>> 'basic-rates-a/g=6Mbps' (21)
>>> 'max-station-count=2007' (22)
>>> 'ack-timeout=dynamic' (19)
>>> 'tx-power-mode=default' (21)
>>> 'periodic-calibration=default' (28)
>>> 'periodic-calibration-interval=60' (32)
>>> 'dfs-mode=none' (13)
>>> 'wds-mode=dynamic' (16)
>>> 'wds-default-bridge=bridge1' (26)
>>> 'wds-default-cost=100' (20)
>>> 'wds-cost-range=50,150' (21)
>>> 'wds-ignore-ssid=false' (21)
>>> 'update-stats-interval=disabled' (30)
>>> 'default-authentication=false' (28)
>>> 'default-forwarding=false' (24)
>>> 'default-ap-tx-limit=0' (21)
>>> 'default-client-tx-limit=0' (25)
>>> 'proprietary-extensions=post-2.9.25' (34)
>>> 'wmm-support=disabled' (20)
>>> 'hide-ssid=true' (14)
>>> 'security-profile=supersecureprofile' (35)
>>> 'disconnect-timeout=00:00:03' (27)
>>> 'on-fail-retry-time=00:00:00.100' (31)
>>> 'preamble-mode=both' (18)
>>> 'compression=false' (17)
>>> 'allow-sharedkey=false' (21)
>>> 'station-bridge-clone-mac=00:00:00:00:00:00' (42)
>>> 'ht-ampdu-priorities=0' (21)
>>> 'ht-guard-interval=any' (21)
>>> 'ht-extension-channel=disabled' (29)
>>> 'ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15' (118)
>>> 'ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7' (60)
>>> 'ht-txchains=0' (13)
>>> 'ht-rxchains=0' (13)
>>> 'ht-amsdu-limit=8192' (19)
>>> 'ht-amsdu-threshold=8192' (23)
>>> 'hw-retries=15' (13)
>>> 'frame-lifetime=0' (16)
>>> 'adaptive-noise-immunity=ap-and-client-mode' (42)
>>> 'hw-fragmentation-threshold=0' (28)
>>> 'hw-protection-mode=none' (23)
>>> 'hw-protection-threshold=0' (25)
>>> 'running=true' (12)
>>> 'disabled=false' (14)
>>> 'comment=' (8)
>>> '.tag=2' (6)
>>> END-OF SENTENCE
Now here's the same command's API output under 4.10 (which is the same as under 4.9):
<<< '.tag=2' (6)
<<< END-OF-SENTENCE
>>> '!re' (3)
>>> '.id=*2' (6)
>>> 'name=wlan1' (10)
>>> 'mtu=2290' (8)
>>> 'l2mtu=2290' (10)
>>> 'mac-address=00:11:22:33:44:55' (29)
>>> 'arp=enabled' (11)
>>> 'antenna-mode=ant-a' (18)
>>> 'running=true' (12)
>>> 'comment=' (8)
>>> '.tag=2' (6)
>>> END-OF SENTENCE
Notice how many more of ALL settings "getall" returns?
*sigh* Please, MikroTik, please make sure "getall" returns ALL parameters. Please?
Aaron out.
