rmichael
Forum Veteran
Forum Veteran
NTP package bug (ROS 4.9)
Mon May 24, 2010 3:59 am
ROS 4.9 with ntp package will not sync with windows ntp server (windows 7 pro's w32time; announceflags=5)
After removing ntp package (i.e. ntp client only) routerboard will sync with windows ntp server.
PS.: same deal with v4.5...
sergejs
Re: NTP package bug (ROS 4.9)
Wed May 26, 2010 1:23 pm
I do not have Windows 7 here to make the same test.
But are you able to sync any other Linux or other OS NTP client to your server?
janisk
Wed May 26, 2010 3:15 pm
not familiar with windows services too, but you could try to play around with settings on RouterOS NTP client and on your NTP server. As far as i can tell, all NTP client modes (client from ntp package) are working correctly.
rmichael
Forum Veteran
Forum Veteran
Wed May 26, 2010 7:26 pm
The situation is that the Windows 7 server is running unchanged and ntp package will not sync with it but regular ntp client will.
thanks.
sergejs
Thu May 27, 2010 9:36 am
Yes, I understand that.
Are you able to sync any other device, Linux/Windows to your NTP server?
rmichael
Forum Veteran
Forum Veteran
Thu May 27, 2010 10:36 am
Sure, ubuntu 10.4, Nanostation5M 5.1.2 and 5.2, pfsense 1.2.3.
janisk
Thu May 27, 2010 1:16 pm
and what configuration you have set on NTP client in RouterOS? do you have any RouterOS device that takes time from that server that works with other versions but 4.9?
rmichael
Forum Veteran
Forum Veteran
Thu May 27, 2010 9:58 pm
As I said all routerboards running 4.5 and 4.9 can connect using default ntp client. ntp package client will not sync. There is not much to configure on ntp package client, just IP of the server and mode (all tested).
There's also nothing in debug log for NTP. This is a new setup and I don't have any other ROS versions on my network currently.
bigguns
Fri May 28, 2010 8:37 am
Actually I am having issues where my RB800(v4.9) isn't syncing it's timeclock to the required address. Again nothing in the logs.
Users browsing this forum: dioeyandika, Josephchimi, TomjNorthIdaho and 30 guests
