axiang
ROS on the Intel NIC support dropped?
Thu May 27, 2010 6:36 am
I have downgraded from 5.0 to 4.9 of the Internet card or there is a problem more frequently if the data or other communications or packet loss would disrupt the use of Broadcom NIC relatively better not have this problem on the
I have a network port as DHCP services do not only do agents have access about a problem a few hours later
2 01:02.1 Intel Corporation 82546GB Gigabit Etherne... 12
3 01:02.0 Intel Corporation 82546GB Gigabit Etherne... 3
82546EB Gigabit Etherne... The same problem
我是中国人
omega-00
Re: ROS on the Intel NIC support dropped?
Thu May 27, 2010 7:04 am
I was just posting over here earlier having tested one of the new Intel cards and confirmed it's working
[admin@Testbox] /system resource pci> print
# DEVICE   VENDOR                   NAME        IRQ
1 05:00.0  Intel Corporation        82574L Gigabit Network Connection (rev: 0)             11
2 04:00.0  Intel Corporation        82574L Gigabit Network Connection (rev: 0)             10
http://forum.mikrotik.com/viewtopic.php ... 00#p209700
Perhaps you should send a supout.rif through to them (try one from v4.9 and v5.0beta2) so they can see what the problem is.
martini
Thu May 27, 2010 5:24 pm
its worked, but on intel cards there are packet DROP, especially if on router configured many firewall rules, on Broadcom chip all works ok, "0" packet drop
Users browsing this forum: No registered users and 97 guests
