MUM Europe 2020
rgpmikrotik
RB750 vs RB750G
Fri Jun 11, 2010 10:52 pm
I want to know the differences between the RB 750 and RB750G, the only one is the gigabit support?
thanks in advance
andrescamino
Re: RB750 vs RB750G
Fri Jun 11, 2010 11:31 pm
hello rgpmikrotik
The rb750g has 80MHz Atheros 7161 CPU instead of with AR7240 CPU which means that the 750g can have more throughput
roc-noc.com
Forum Veteran
Forum Veteran
Re: RB750 vs RB750G
Fri Jun 11, 2010 11:42 pm
The RB750G CPU is about 2 times faster than the RB750 CPU.
The RB750 CPU is either 300MHz or 400MHz. The RB750G CPU is 680MHz.
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
rmichael
Forum Veteran
Forum Veteran
Re: RB750 vs RB750G
Sat Jun 12, 2010 3:23 am
Are RB750 400MHz versions still produced? I thought that was just the first production batch that was 400MHz.
roc-noc.com
Forum Veteran
Forum Veteran
Re: RB750 vs RB750G
Sat Jun 12, 2010 3:31 am
Our first batch was 400MHz, 2nd batch was 300MHz, third was 400MHz again, and I haven't checked since.
I am guessing that they use 300MHz CPUs when the 400MHz version is in short supply.
Tom
888-762-5662
roc-noc.com
Forum Veteran
Forum Veteran
Re: RB750 vs RB750G
Sat Jun 12, 2010 10:19 pm
FWIW I just checked our current RB750 stock and they are 400MHz CPUs with ROS 4.9.
Tom
888-762-5662
rmichael
Forum Veteran
Forum Veteran
Re: RB750 vs RB750G
Thu Jun 17, 2010 12:42 pm
RB750 vlan support is not as comprehensive as that of R750G
http://wiki.mikrotik.com/wiki/Manual:Sw ... p_Features
cib3k
Re: RB750 vs RB750G
Wed Oct 20, 2010 1:48 am
Hi guys,
Sorry for resurrecting an old topic and also being kinda off-topic. When buying a RB750, is there any way of telling if the CPU is the 300MHz or the 400MHz version? I mean without looking inside the unit or powering it up. Thanks.
rmichael
Forum Veteran
Forum Veteran
Re: RB750 vs RB750G
Wed Oct 20, 2010 12:25 pm
Vendors supposedly know that by serial number.
Chupaka
Re: RB750 vs RB750G
Wed Oct 20, 2010 5:00 pm
[admin@MikroTik] > /system routerboard settings print
        cpu-frequency: 680MHz
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
cib3k
Re: RB750 vs RB750G
Wed Oct 20, 2010 8:38 pm
@Chupaka
The idea was to find out without powering up the unit.
Basically, I want to buy a RB750 from an online store. I already asked the vendor directly about the CPU speed - he doesn't know. I can also ask him for information written on the unit or on the package, but I can't ask him to power it up.
Users browsing this forum: Google [Bot], MSN [Bot] and 99 guests
